Rangi01
Revell's 1/72 Focke Wulf FW190 A8/R-11 Nachtjager
Hi All, well I am pleased to say that I have finished (well enough to go on the shelf for the moment) my 72nd scale FW190. Loved building her with very little in the way of fit issues, the upper wing/fuselage joint needed a shim of plasticard on either side. The only real disappointment was the canopy, moulded in 2 pieces but as the rear sliding part is molded into the fuselage the canopy cannot be posed open without surgery. Also the clear plastic was thick, scratched and distorted. A polish and dip in Klear helped a great deal but it is still not up to the quality of the rest of the kit.
Panel lines are fine and crisp with a very high level of detail and a number of options. You can complete the model as a standard A8 or the R-11 Nachtjager with 'stag-horn' style antenna. I chose the Nachtjager however the antenna are a bit too heavy to be convincing so I fabricated some new ones from stretched sprue but I am still not completely happy with them. I may replace them at a later stage.
Anyway here are the pictures, I hope that you enjoy them
C9C9268D-53AE-4D46-B19B-0675FC22D604_zps
39E0563B-0473-48BC-B5D3-2EEB896C0061_zps
F29DD798-FDF0-4B38-886C-A2AB33AD5E86_zps
2BF6DF67-1F6D-4BBA-856E-A8D9D2ED2340_zps
F9F949F4-B5B2-4B69-AC1C-B7ACF5F69B41_zps
A4DA24BC-EF5B-4B09-978F-0BBBEFEAEBD9_zps
E0254FD4-751F-4AE4-8E69-F0121AEA112A_zps
16FFAB8F-7497-427E-A9E2-A27CA5533912_zps
5FF26BE1-2FBA-4A52-BEDD-655A6B59AF8E_zps
00863034-99FC-4F54-8DD4-B84DED640CA2_zps
39FDBBD7-65C4-4043-9C76-665B391A22E4_zps
A3A40A43-BCAF-401E-835C-493175DFBDD1_zps
6CF32DDA-AFBB-4687-B91A-184F1378EB68_zps
Decals are kit supplied, with the exception of the swastika, which went down nicely but are a little thick. Paint is a combination of Tamiya and Italeri acrylics, preshaded with a dark grey and with a dark grey oil pin wash in the control surface joints and a oil dot weathering of yellow and blue on the upper surfaces.
Thanks for looking,
Shane
I agree that the canopy lets down the Revell kit and it is a bit clunkier than the Airfix or Hasegawa kits overall but you have done a very fine job on this one and your replacement aerials are a definite improvement over the kit parts. Well done.
Duncan B
I think your antennas are just fine. You couldn't expect that the original ones were perfectly straight all the time. Looks way more realistic this way. Great build!
