AnonymousDFB1 Posted December 30, 2014 Share Posted December 30, 2014 So I'm assuming the undercarriage on my 1:72 version will be wrong? Link to comment Share on other sites More sharing options...
galgos Posted December 30, 2014 Share Posted December 30, 2014 So I'm assuming the undercarriage on my 1:72 version will be wrong? I don't know the kit Mish, if they look like the ones in Rich's post above, ie quite narrow with a large wheel centre, then Yes they're wrong, but if they look like the Brassin ones in my post above then they're right! Max Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted December 30, 2014 Share Posted December 30, 2014 I'll check when I get back to the bench tomorrow. But I'm sure Eduard just scaled down the kit. Link to comment Share on other sites More sharing options...
trickyrich Posted December 30, 2014 Author Share Posted December 30, 2014 Maybe he fitted the smaller ones to help keep the weight down! Link to comment Share on other sites More sharing options...
galgos Posted December 30, 2014 Share Posted December 30, 2014 I'll check when I get back to the bench tomorrow. But I'm sure Eduard just scaled down the kit. Julien reviewed the kit back in February Mish. From the sprue shots it appears they give you a choice of wheels - make sure you choose the right ones! Max Link to comment Share on other sites More sharing options...
Arniec Posted December 31, 2014 Share Posted December 31, 2014 OK, so now I have to get me some new wheels for the Eduard Bf-110 G2 and G4. Thanxs for the Info Max. Cheers, Link to comment Share on other sites More sharing options...
trickyrich Posted December 31, 2014 Author Share Posted December 31, 2014 I think Max has a sweet deal going with Eduard for 110 main wheels! 1 Link to comment Share on other sites More sharing options...
galgos Posted December 31, 2014 Share Posted December 31, 2014 I think Max has a sweet deal going with Eduard for 110 main wheels! Now there's an idea.......! 1 Link to comment Share on other sites More sharing options...
smuts Posted January 4, 2015 Share Posted January 4, 2015 Looks great Andy Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted January 4, 2015 Share Posted January 4, 2015 Checked yesterday, mine does indeed have wheels with smaller hubs Link to comment Share on other sites More sharing options...
trickyrich Posted January 24, 2015 Author Share Posted January 24, 2015 ok after what seems to be forever I'm back to this..... Now the rush is on to finish this on time, see some long nights ahead. First up the wheels arrived while I was away, plus lots and lots of other tasty packages!!! Gee they are different, a quick paint job and with a little more work and they done! Decaling time..... In had a few concerns about these Peddinghaus decals as I have read they can be a bit difficult and fragile to work with plus the decal carried sheet is just that, no nice individual decals here! Well I had no problems with the decals at all they went on easily and needed just a touch of setting/softening solution to get them to conform. Put they are actually quite tuff as I found out as I had to remove a couple! Ok because they are not individual decals you have to cut them out individually which is not too hard but it does leave a hard sharp edge which is quite noticeable once it’s in place, even after a coat of clear. I cannot confirm their accuracy as there are not good actual photos of this aircraft, plus some of the decal positions do not seem to line up with similar markings on other aircraft, plus there are a couple of quite obvious position errors as well! So I used various other aircraft as reference for the position of some of these decals, plus some from the Eduard set as well. Next after setting overnight, a couple of coats of clear to protect the finish, then on to the weathering and panel-line work. I just can’t find a look I’m happy with so they have been removed and added a couple of times. I’m going to give up on this as I am wasting time! Everything is just about completed on all the small bits and now just need fitting, the canopy of cause is giving me a bit of grief! I’ll be glad to see this one finished as it has been a lot harder than it looks........need to move on to something a bit simpler.........yeah right! 4 Link to comment Share on other sites More sharing options...
Mottlemaster Posted January 24, 2015 Share Posted January 24, 2015 Worth every bit of time you have given it as an Eduard 1/48 110 maes you fight for a good result and you have won hands down . Recon something like the Airfix 1/24 Typhoon would be something simpler to move on to Alistair Link to comment Share on other sites More sharing options...
galgos Posted January 24, 2015 Share Posted January 24, 2015 The Eduard kit is flawed, but then as I've found out, so is the Dragon/Cyberhobby! I remain of the opinion that the most satisfying 1/48th Bf110 to build is the ancient Monogram/Revell one despite it's inaccurate nacelles etc. You're making an excellent job of a difficult kit, stick in there buddy! Max Link to comment Share on other sites More sharing options...
Arniec Posted January 24, 2015 Share Posted January 24, 2015 That is a great looking model. You are nearly there. Great job!!! Cheers, Link to comment Share on other sites More sharing options...
smuts Posted January 25, 2015 Share Posted January 25, 2015 looks really good.. Andy Link to comment Share on other sites More sharing options...
Dermo245 Posted January 25, 2015 Share Posted January 25, 2015 Can't believe I haven't seen this before - looks awesome! Dermot Link to comment Share on other sites More sharing options...
trickyrich Posted January 26, 2015 Author Share Posted January 26, 2015 ok I'm calling this one. After what seems forever it's finally completed and the last few days were no easier than the rest. I've lost count of the number of times I've knocked some bits off and the lower antenna array has been bent sooooo many times. But she's done, not as easy as I would have expected. The Eduard model is a bit of a challenge and again not what I would have expected, though I have read other peoples frustration with the model so expected some issues. The hardest part of the build was the real lack of info one this particular aircraft, which made it all the more harder to build accurately (probably a bit of artistic license on some parts). A big thanks to Max for his help and advice. Lastly this model is dedicated to my Dad who passed away late last year......thanks for getting me into models and having the aircraft bug. enjoy, photos in the gallery and RFI sections. that reddish/pink section is just a lighting issue. 2 Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted January 26, 2015 Share Posted January 26, 2015 Wonderful work Rich, love it Link to comment Share on other sites More sharing options...
galgos Posted January 26, 2015 Share Posted January 26, 2015 Well done Rich, she looks really super! That top shot especially is very convincing. Well done for mastering a far from easy kit. Max PS excellent photographs in the Gallery! 😄 Link to comment Share on other sites More sharing options...
Stew Dapple Posted January 26, 2015 Share Posted January 26, 2015 Nice job Rich, she looks the business Cheers, Stew Link to comment Share on other sites More sharing options...
Arniec Posted January 26, 2015 Share Posted January 26, 2015 That is great looking model!!! well done!!!!! This is a very stunning looking 110. Cheers, Link to comment Share on other sites More sharing options...
mick Posted January 27, 2015 Share Posted January 27, 2015 great work Link to comment Share on other sites More sharing options...
vppelt68 Posted January 27, 2015 Share Posted January 27, 2015 Congratulations, a job hobbypiece well done! V-P Link to comment Share on other sites More sharing options...
