AndrewE Posted October 19, 2014 Share Posted October 19, 2014 Thought I would join with another Blenheim but this time the MPM Mk.IV. I shall be doing it in the box top markings. I picked this up second hand a few years ago and it came with plenty of aftermarket bits. I shall definitely use the Aeroclub props and guns but probably stick with the resin engines that come with the kit. The hardest part is going to be the canopy for which I will need to do some major surgery to replace the kit one with the Squadron vac form replacement. The rest of the kit should hopefully go together without too much trouble. Andrew Link to comment Share on other sites More sharing options...
Graham Boak Posted October 19, 2014 Share Posted October 19, 2014 From working on this kit, it does benefit from a slight widening of the fuselage to match the width of the transparent parts provided. However, how this compares with the Falcon part I can't say. 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted October 19, 2014 Share Posted October 19, 2014 Good luck with your build, would like to see how this kit goes together. All the best Chris 1 Link to comment Share on other sites More sharing options...
FZ6 Posted October 24, 2014 Share Posted October 24, 2014 Look forward to seeing how you get on with this one Andrew Link to comment Share on other sites More sharing options...
AndrewE Posted December 21, 2014 Author Share Posted December 21, 2014 Rather a slow start on this I'm afraid due to getting my WW1 anniversary build completed. Now that is out of the way I can hopefully concentrate on this full time and sneak it in before the finish on the GB. So far I have the main components together and rebuilt the nose section to accommodate the Squadron vac-form canopy. I thought I would get away with simply cutting away the canopy part of the kit supplied nose but it turned out to be too wide for the new canopy so the sides had to be cut away as well and rebuilt with plastic card. The landing and wing tip lights have all been replaced with parts from old coloured toothbrushes as well. Hopoefully updates should be rather more frequent now with only two weeks to go. 1 Link to comment Share on other sites More sharing options...
woody37 Posted December 21, 2014 Share Posted December 21, 2014 Great work on the cockpit and lights, looking forwards to seeing more Link to comment Share on other sites More sharing options...
bigbadbadge Posted December 30, 2014 Share Posted December 30, 2014 Wow there is some serious work on this one, looks fabulous, keep up the good work All the best Chris Link to comment Share on other sites More sharing options...
