1/24 scale Grumman F7F Tigercat N7654C
I think we need a new superlative when dealing with Peter's threads. I suggest "Pffffffffff!", because words often fail me. :worthy: Maybe you should consider purchasing the domain lithomodeller.com? :lol:
Superb !! :thumbsup:
I'm running out of superlatives to.
Guy
I think we need some sort of super-human smiley!
evening folks :)
thanks for your kind words
Peter,
Thank you for the more detailed (blow-by-blow) photos of this sub-assembly. One question though, how are you realizing the placards and stencils? Are these decals you've produced? Curious on how you create those...
PR
Thanks PR - all the placards are from my own airscale range - available here - even I get impressed when I blow up pictures and can read them - a testament to Ray at Fantasy Printshop..
another little bit of the story - this time rudder pedals..
..here is one - I wish I had included it on the PE I did a while back as it has a neat little Grumman logo which would have been nice to include. As it is, I can see it is ribbed, has some sort of horn off out to a piston and actually in cross section is curved..
.. I started by laminating four bits of plastic card, drilling a hole so I could pin them and keep alignment while I shaped them..
..to get the ribbed effect I tried scoring a bit of litho with different blades and onto different surfaces - I settled for scoring from the back with a blunt compass on to a cutting mat...
..made up the parts to start assembly..
..again, using a pin to help with alignment, the assembly starts...
..soon had two rudder pedals... the ribbing is a bit agricultural in close-up but I can live with it..
..I shaped some scrap sprue to represent the horns seen on each pedal and added a bolt to each the will fit to the piston..
..and primered with a pair of size 10 flying boots...
..got a bit more to do on the whole assembly and pistons etc - then I have to figure out how to fit it into the cockpit..
TTFN
Peter
  • Like 15
The ribbing is a bit agricultural? I don't know how to describe my efforts at building plastic kits if that is 'agricultural'!
Cracking work again Peter, & done so amazingly quickly!
Keith
Another great instalment great skills Peter.
Guy
evening folks :)
time for another little updatette..
..I finished the rudder assembly - the bits needed were the frames seen either side of the pedal and the actuator piston. The pics below show the frame is a folded sheet pressing with some fittings and an adjustment lever on the outboard frame only..
..I started by working out what the shape would be if I 'unfolded' the frame and then laminated some sheet so I could get them all the same shape, size and get the holes in the same place on all - here I have finished working them and have peeled off the top sheet..
..and after folding them up into the frames..
..added the parts needed to detail them..
..and assembled with the rudder pedals - an axle links all the parts together...
..the pistons were made with brass and ali tube, drilled to take some lead wire with scale hardware nuts...
..I added a wire loop at the top to mount the pistons to the frames - this won't be seen when they are fitted in the cockpit..
..painted & chipped - the parts are pretty much done..
..and roughly where they will sit in the cockpit...
..thats it for today - again a good few hours for some tiny little bits no-one will ever see...
TTFN
Peter
  • Like 15
I like that
You forgot to show us the piston seals, I hope you remembered to put them pressure side to 'out'
I 'spect you will need a hand to bleed them, I'll help if you need somebody
23/10
immaculate...
Nice work on the pedal assemblies at least you know they are in there (and us lot !).
Guy
