Alan P Posted February 3, 2016 Share Posted February 3, 2016 Realistic wear and tear! It's the holy grail of modelmaking, congratulations sir! I thought I'd never see it in my lifetime. Al 1 Link to comment Share on other sites More sharing options...
perdu Posted February 3, 2016 Share Posted February 3, 2016 Each and every time I look in here my 'awesome level' gets hammered I'm loving the channelling, to think I needed machinery to do that at work in my youth I love this aeroplane, and I'd hardly ever heard of it years ago 1 Link to comment Share on other sites More sharing options...
F4u Posted February 3, 2016 Share Posted February 3, 2016 Just like the real thing Peter stunning ! Guy 1 Link to comment Share on other sites More sharing options...
airscale Posted February 6, 2016 Author Share Posted February 6, 2016 evening folks.. so, plodding along and today was about getting one of the cockpit sidewalls into some sort of shape.. ..this is actually N7654C in Pensacola and what I am shooting for.. ..first thing was to just get the sidewall liner to fit properly and snugly and offer up the side console to make sure it fits and doesn't foul the seat. One thing became obvious, I painted the sidewall as per Grumman factory instruction of green below the instrument panel, but looking at the real thing it has been oversprayed black and I need to make the same change.. ..this is the one that needs attention, so I did the chromate primer & hairspray thing again.. ..and after some weathering to try and match the original.. ....when the parts were a good dry fit I cemented the switch console to the sidewall in situ so there were no alignment problems, and added the canopy winding handle.. ..also added some of the wiring bundles - need to finish it off and blend it in though.. and test fitting it in the cockpit - the two sides go in, then the seat - well thats the plan anyway... ..got the weekend to fiddle about a bit more.. TTFN Peter 14 Link to comment Share on other sites More sharing options...
Radleigh Posted February 6, 2016 Share Posted February 6, 2016 I think this could win the title 'best in show' at this years SMW. Without a doubt.... It's such a master piece in so many ways. 3 Link to comment Share on other sites More sharing options...
Pastor Rich Posted February 6, 2016 Share Posted February 6, 2016 Peter, Question: Are you going to build it such that the canopy slides? (Or is at least in the open position) I would hate to see it buttoned-up that you cannot see inside that awesome pit! Brilliant!!! PR 1 Link to comment Share on other sites More sharing options...
TGA Posted February 6, 2016 Share Posted February 6, 2016 Peter, what did you use to make the small toggle switches on the sidewall panel? 1 Link to comment Share on other sites More sharing options...
airscale Posted February 6, 2016 Author Share Posted February 6, 2016 Peter, what did you use to make the small toggle switches on the sidewall panel? i just used stretched sprue - the panel face was a PE part I made I am always worried I will snap one off... Peter 11 Link to comment Share on other sites More sharing options...
Col. Posted February 6, 2016 Share Posted February 6, 2016 Stunning. Utterly stunning. 2 Link to comment Share on other sites More sharing options...
TGA Posted February 6, 2016 Share Posted February 6, 2016 Your parts are so exquisite Peter. Can you take a few close-ups of the panels for me? I'd love to make toggles like that in my P-61 cockpit in 1/32nd but I need some ideas as to how...... 1 Link to comment Share on other sites More sharing options...
keefr22 Posted February 6, 2016 Share Posted February 6, 2016 Wow.... 1 Link to comment Share on other sites More sharing options...
perdu Posted February 6, 2016 Share Posted February 6, 2016 I'm getting a tad worried that the Pensacola place will get upset at you keep taking bits off their airframe to make it look like you modelled it... Not!!! BLOOMING LOVELY What was good is now next to impossibly good I'll just sit back now and be quietly jealous very 1 Link to comment Share on other sites More sharing options...
F4u Posted February 6, 2016 Share Posted February 6, 2016 Gets better every time you add something , hoping the canopy will slide or be open to see all that detail. Well done Peter. Guy 1 Link to comment Share on other sites More sharing options...
airscale Posted February 6, 2016 Author Share Posted February 6, 2016 thanks guys ..bit more done on the other side... ..don't know what this bracket is, but it is typical of a model within a model.. I am sure to most people it is a square empty space, but to oddballs like me it is still an interesting challenge.. note how it is folded and the corners are missing and radiused, there is a folded flange lower left, there are a number of holes and different tones where something was mounted there (like taking a painting off the wall..) ..told you I was odd... first step was to make a paper template... ..it needs to allow for the folded parts too, and what better material to use than a bit of litho sheet,,, ..marked it out and scored the outer cuts to bend & break off the waste.. ..used a dremel and cutting wheel to grind the radiused corners... ..and after cleaning up.. ..and then folding in a folding tool.. ..I sprayed it black, masked the patch and sprayed a bit lighter - added some weathering and mounted it... ..I repainted the whole cockpit liner the same as the other one to move the black line down and get some hairspray chipping... ..and hopefully tomorrow I find out if the seat fits between them... ..thats it for now.. TTFNPeter 16 Link to comment Share on other sites More sharing options...
perdu Posted February 6, 2016 Share Posted February 6, 2016 See if the seat fits... It will natcherlly lovely work Peter 3 Link to comment Share on other sites More sharing options...
Spookytooth Posted February 6, 2016 Share Posted February 6, 2016 As simple as that, a panel cut and shaped. It would take us mere mortals ages. Lovely work Peter. Simon. 1 Link to comment Share on other sites More sharing options...
basket Posted February 6, 2016 Share Posted February 6, 2016 truly .... well I can't find my words !!! 1 Link to comment Share on other sites More sharing options...
woody37 Posted February 6, 2016 Share Posted February 6, 2016 Me neither. I'm sure this is a real aircraft that Peter is messing around with on his living room floor! 1 Link to comment Share on other sites More sharing options...
Thom216 Posted February 6, 2016 Share Posted February 6, 2016 Love those little details. You are a gem! 1 Link to comment Share on other sites More sharing options...
Nigel Heath Posted February 6, 2016 Share Posted February 6, 2016 As Keith said, utterly stunning, such lovely work. 1 Link to comment Share on other sites More sharing options...
brianthemodeller Posted February 7, 2016 Share Posted February 7, 2016 Just had a pleasant hour or so catching up. To say may flaber has never been so gasted would be an understatement..! 2 Link to comment Share on other sites More sharing options...
Pastor Rich Posted February 8, 2016 Share Posted February 8, 2016 I for one am waiting with baited breath waiting to see the fit of the seat in the pit! Cheers, PR 1 Link to comment Share on other sites More sharing options...
Max Headroom Posted February 9, 2016 Share Posted February 9, 2016 I for one am waiting with baited breath waiting to see the fit of the seat in the pit! PR You and me both. I'm getting light headed and will need unbait my breath in a minute! 11/10 (I've run out of words......) Trevor 1 Link to comment Share on other sites More sharing options...
John_W Posted February 9, 2016 Share Posted February 9, 2016 I am suprised he didn't make a pair of scale boots to authenticaly scuff the floor. 1 Link to comment Share on other sites More sharing options...
F4u Posted February 9, 2016 Share Posted February 9, 2016 Look forward to the seat going in hope it's adjustable !!! Guy 1 Link to comment Share on other sites More sharing options...
