If Spitfires are not your thing then it may be worth looking away now as I'm going to try to make two 1/48 versions simultaneously!
A fair while back, when I decided I'd one day like to make the Eduard Mk.IX Spitfire, I didn't know at the time what I was starting. You can check out my finished version of the Mk.IX here. When I thought about such a lovely, quite expensive kit, I decided I ought to practice the skills I'd need to do it justice beforehand. So I practiced by making three 1/72 Spitfires and then moved onto a 1/48 Mk.XVI. Even before I'd started the Mk.IX I realised I was addicted to making Spitfires.
A few months ago I'd already picked up the 1/48 Tamiya Mk.Vb and then when the Airfix version appeared (and was quite cheap on pre-order on the big A) I decided to get one of those too. I had originally planned to make the Tamiya kit before the Eduard one but I ended up making the latter for the D-Day Group Build first.
So now it's time to expand my Spitfire collection by two.
I'm quite excited by this project and thought it would be interesting to see what the comparisons are between the two kits - I have little pre-knowledge about them other than reading bits and pieces about them on the web. Some people seem to be positive about both and others the opposite. Versions of these that I have seen built look pretty good to me but I'm not an expert on the real thing or the kits. In my head I have this idea that I might be able to use each kit to be make the other a better version but this may not work out in practice. I don't intend to do any major surgery on either, but rather just enjoy the type of thing I feel comfortable with.
Edit 21/08/15 - if anyone is interested there is a follow up thread to this one where I am currently making the Tamiya and Airfix (new tool) 1/48 Mk.I kits. I'm using a lot of the lessons I learned from this thread. If you are interested it can be found in the Battle of Britain Group Build section here.
So box and sprue photos first - I like the artwork on both:
In comparison the Airfix box seems a lot fuller of parts but I already know some of them won't get used:
Tamiya box:
As there did seem to be fewer parts with the Tamiya kit I decided to bolster it a bit with Eduard Zoom set:
Tamiya sprues:
Some cockpit details - I really like making up the cockpits and both kits seem to have nice details - Tamiya:
Tamiya instructions:
Versions included in the kit:
Airfix sprues:
Airfix cockpit detail:
Airfix - new style instructions - not sure about these yet:
Possible versions in the box:
I have also got these bits left over from the cockpit of the Eduard Mk.IX and I might think about if they're better to use somewhere:
I'm hoping to get some work started on these this weekend - all I've done so far is get all the parts washed in warm soapy water.
Kind regards,
Stix
Edited by PlaStix
  • Like 10
Hi Stix,
I think you're going to have some fun with these. The Tamiya kit does have some shape issues, one not-so-easy one to fix and a couple of ones that are easy to fix. I have done those fixes a couple of times and if you are interested I can point you to the needed information here on BM. In the meantime I look forward to seeing your progress.
Cheers, Jim
This should be good Stix,they both look brilliant blank canvasses to do your magic on! The Tamiya version I built many moons ago and is a vice free
no hassle build,the airfix kit looks an equal to any far eastern product I,m just starting to cut plastic on the Revelgawa MKIX so I,ll be "nicking" a few
ideas if you don,t mind,best of luck.
I'll certainly be watching this. I'm a Spitfire nut, having built 56 of them since 2007. :)
My all time favorite kit is the Tamiya 1/48 Mk. Vb, but by all accounts, the Airfix kit may soon be kicking that kit out of the top slot on my hill. I have two of the Airfix kits, but as I'm drowning in a commission build (seven identical P-47s due to be finished before Christmas), I can't start on them. So I'll be excited to see your progress.
My good friend Steve Budd wrote an article for AMW about the kit, and mentioned that part D33 did not fit well, so that may be something to keep in mind. But apart from that, he was quite happy with it.
Looking forward to seeing your work!
What a marvellous idea, should be an interesting comparison.
I've made several of the Tamiya Mk1 Spitfires, which are a lovely kit to build and I'm sure the MkVb will be very similar. Go the new Airfix kit under my bench at the moment, looks to be more of a demanding build than the Tamiya kit, as in more parts to make the kit up.
Hi Stix,I think you're going to have some fun with these. The Tamiya kit does have some shape issues, one not-so-easy one to fix and a couple of ones that are easy to fix. I have done those fixes a couple of times and if you are interested I can point you to the needed information here on BM. In the meantime I look forward to seeing your progress.Cheers, Jim
Hi Jim, thank you for your interest. Yes I would definitely be interested in seeing possible fixes. I'm relatively new at this, having been pretty much an OOB builder until fairly recently, but I'm interested in seeing what could be done even if I can't do it!
Hi Steve. Thank you for dropping by. I hope you'll be doing a WIP for your Mk.IX - I think you'll find I'm going to be borrowing ideas from you! Hopefully Wolwe will be starting his 1/48 Mk.IX too soon - it'll be almost like mini Spitfire GB.
you'll enjoy building both of them. I know I did.
Thank you SIlver Fox - I was very impressed with yours - I have it bookmarked for future reference!
And who says men can't multi-task!
Absolutely, although I'm not sure I can! We will see......... Thank you for dropping in.
Hi Jon. Wow I've still got a few to go then!! These two will be six and seven in my collection! Still that means I've got a lot more to look forward to! And thank you for the information- I will look out for that.
Kind regards,
Stix
Edited by PlaStix
Count me in stix...now wheres the popcorn?!:-D
Hi crustydude - I will, thank you - I don't know but leave some for me!
Hi Doug, I'm hoping it will be interesting. I'm aiming to have a go at the Mk.I Tamiya at some point. You could always get the new Airfix version on the go early and we could compare notes.
Kind regards,
Stix
I have got the Hasegawa MkVb too, which would widen the scope of the exercise. :hmmm:
Mind you still need to finish my MkXII off before starting another, hoping to get that done Monday or Tuesday.
Hi Doug. It's up to you but I'd say the more the merrier! As I mentioned; I'm hoping to start this Saturday but if you've seen any of my previous builds I'm one of the slowest kit builders around! And I'm looking forward to seeing your finished Mk.XII.
Kind regards,
Stix
Still love the Tamiya Spitfire, a classic kit and so easy to build. Good luck with your project :)
Thank you for your interest Marty. The Tamiya one does look very nice and I'm looking forward to building it. I'm pleased that I hadn't heard a new version from Airfix was due so soon when I bought the Tamiya one, because I may have got it just yet.
Kind regards,
Stix
Sounds even better - more variety! I look forward to seeing it in progress (hopefully in the near future.)
Great more spit builds for me to watch.
My daughters bought me the airfix 1/24 zumbach kit. There are numerous 'elements' that better men than i can address. OOB will do for a first model in 30 years..
I can feel myself improving though with every part i address or tecnique i try.
Without this site it would be a mess. Please keep it up.
Hi 40something. Welcome to BM. Sounds like you've got a good project to get yourself back into modelling with! Hope to see some of your progress here on BM.
Kind regards,
Stix
I quite like the OOB markings on the new Airfix spit, do like the more unusual schemes. Can't wait to see your progress, we know they will be good :)
Hi Woody. Thank you for stopping by.
I didn't get as much time on this as I'd hoped this morning - only about an hour and a half which gave me just about enough time to get some holes drilled. Like with the Eduard cockpit, some of the holes in the frames are there but not drilled all the way through and similarly some of them are missing:
Top left is the spare frame from the Eduard kit - (I'm using this as a comparison piece as the Eduard kit is considered by many to be the best detailed 1/48 Spitfire kit out there - I drilled it as a practice piece before doing the one I was using for the Mk.IX), bottom left are from the Tamiya kit and centre and right are the Airfix frames:
So I got out the micro-drills and pin vice:
Using a selection of drills I drilled out all the partial holes seen and added some new ones.
Airfix:
Seat support holes added:
Tamiya:
Airfix cockpit sides drilled out more deeply to give better definition:
Tamiya cockpit sides drilled - these were trickier because the frame they're in is thinner and I couln't go too deep as these are actually in the sides of the fuselage and I didn't want to risk going all the way through:
The three frames together after drilling: Left to right - Eduard, Airfix and Tamiya.
The Eduard piece obviously has some more detail but I think the Tamiya and Airfix also look okay and, let's face it, they're going to be mostly hidden, although I am going to do both cockpits open.
More work in the cockpits tomorrow.
Kind regards,
Stix
We're a strange breed us modellers. Great work on that drilling, but I fear most of it won't be seen without an Optivisor!!!!!
Doesn't stop us enjoying your craftsmanship though :)
Yes but YOU know it's there. The Airfix Spitfire cockpits seem to get better with each issue, my resolve not to buy any more 1/48 Spits is weakening by the day.
Looks great. I am going to keep my eye out and grab one of the new Airfix Vb's as soon as I see one.
Hi Woody, Biggles and Simon.
With regards modelling details that end up hardly, or never, being seen; I just enjoy working on things like the cockpits and as you say I'll know it's been done. I couldn't not do them - and I'll have the photos I've taken as well.
Simon - so far it does seem very impressive.
Once again I didn't get a lot of time on this but I have got it a bit further.
As I wanted to get some painting done of the cockpit parts I began by cleaning up some of the mould lines and other bits of flash. There isn't much on either kit but there seems to be slightly more on the Airfix version. Also I noticed the Airfix plastic is slightly softer - not a problem just a comment.
Then, because I want both the cockpits open, I cut out the doors.
Tamiya before:
I used a craft knife from the outside - carefully scoring along the door panel lines. Out of the two the Tamiya one was slightly easier as the kit designers have made the plastic thinner for this cutting process, although there's one less line to cut on the Airfix version because of the way the front cover for the cockpit is designed as a separate part.
Tamiya with the door cut away:
Airfix before:
Airfix with door cut away:
While I had the craft knife out I decided to cut and score along the lines of the elevators on the Tamiya version so I can have them dropped when on display. I didn't have to do this with the Airfix version as it has separate parts for this.
Following this I did some filing and sanding of a variety of cockpit parts, on both kits, before I started painting with Humbrol 78, matt Cockpit Green. As ever I thinned it with water and applied it with a small flat ended brush. Unfortunately I didn't get time to take any photos.
I might not get any more time on this until next week.
Kind regards,
Stix
Edited by PlaStix
Hey Stix, I've got the very same Tamiya's kit in my stash! :speak_cool:
Well, I'll take a seat and watch :popcorn:
Ciao
