nimrod54 Posted November 26, 2014 Author Share Posted November 26, 2014 Matt, I'll go and put some Tamiya tape over it now and leave it for 24hrs, I'll get back to you tomorrow with the answer. Link to comment Share on other sites More sharing options...
Procopius Posted November 26, 2014 Share Posted November 26, 2014 Gah, wish I'd seen this a little sooner! Matt, when I gave it a look, it seemed to me that the nose ring was fine as it was, and that the QB item maybe threw things off a little. However, I currently have a fever, to celebrate American Thanksgiving, and am marooned up in the snow-covered wastes of MI, 380 miles from my stash, so you may freely disregard my words as being disconnected from reality. Thanks for your comments and it is good to hear that you are enjoying all the builds here as well as your own F3. I think that these Sword kits are really nice and whilst they do take a bit more work to put together they do produce a good result with care, although Procopius may not agree with that comment after all the trials and tribulations he has just gone through. In the end though he has produced a splendid looking model and has now bought another Sword kit for a future build, so he is either determined to slay the beast or just a glutton for punishment. My wife does, from time to time lovingly (I hope!) tell me I'm an idiot. I hesitate to admit this, but she may be on to something... 3 Link to comment Share on other sites More sharing options...
Mattlow Posted November 26, 2014 Share Posted November 26, 2014 PC - I followed your build (is that a word that could possibly describe what unfolded over those pages?) and it was this in part that has kept me on the straight and narrow with my build - i.e. checking and testing fit etc all the time... I have also been spared the attentions of the gremlins that appeared to have held a convention in your basement, seeking to block your route to completion. So while you feel it's a bit of a 'whatever' build, I tend to see it as great inspiration to keep at it when the road gets rough. I've got one of each of Sword's Lightnings, so I need to 'tame them'. John... I look forward to hearing what the Tamiya tape does to the paint... Matt 2 Link to comment Share on other sites More sharing options...
Procopius Posted November 26, 2014 Share Posted November 26, 2014 In truth, I think I would have ended up feeling pretty good about the kit if I'd just rubbed it down with a towel soaked in IPA before applying the primer and Alclad. But counterfactuals are the easiest thing in the world. I hope you'll share your F.3 when it's done! 1 Link to comment Share on other sites More sharing options...
nimrod54 Posted November 27, 2014 Author Share Posted November 27, 2014 My wife does, from time to time lovingly (I hope!) tell me I'm an idiot. I hesitate to admit this, but she may be on to something... Mine says pretty much the same thing, particularly when I am adding bits to a 1/144th cockpit that nobody will ever see. I just say Ah, but I know it is there. 1 Link to comment Share on other sites More sharing options...
Duncan B Posted November 27, 2014 Share Posted November 27, 2014 Thanks for the extra information on fitting the Quickboost nosing to the T Birds, that'll come in handy when I finally get round to mine. With regards to the Mr Color Metallics, I would suggest (that from my experiments) they tend to be very fragile and will lift and rub off quite easily. Masking tape will definitely lift some of the paint and adding a clear coat over the top of it seems to dull the finish. Best to apply this stuff last rather than try to apply anything over the top of it in my experience of the stuff. Duncan B 1 Link to comment Share on other sites More sharing options...
Cookenbacher Posted November 27, 2014 Share Posted November 27, 2014 That's interesting Duncan. I didn't have any trouble with masking the MM metalizers, but I did end up varnishing them because I was tired of getting metalizer residue all over my hands. It did dull the finish somewhat, but the model still ended up shinier than the those in reference pics. Which does bring up a bit of a modeller's conundrum, a very shiny finish is desirable because it is difficult to achieve and looks good, but it rarely looks scale. Link to comment Share on other sites More sharing options...
nimrod54 Posted November 27, 2014 Author Share Posted November 27, 2014 John... I look forward to hearing what the Tamiya tape does to the paint... Matt Hi Matt Here are the results of the tape test. I applied two strips across the polished side last night and removed it about 45 mins ago, as you can see it has removed very little if anything. The residue that is on the tape has come off the primed side where it was wrapped around. However, I think that Duncans point about using this method is a valid one, in that it is probably best left as the last paint job. It would mean more masking because you would have to mask for any other colurs first, thus protecting the plastic for adding the metaliser and then mask off the coloured areas before applying this. Another suggestion I would make is that you wear gloves at the polishing stage because it is quite a messy process and will leave you with silver hands very quickly. If you check back to Post #63 of this build you will find a link to the original forum post were the method of brush painted NMF's was discussed. Within that topic there is another link, re-discovered by Cookenbacher, to a P-47 build where this method was used and this will give you some further pointers should you wish to go down this route, I must say that I am quite impressed with the results of this method though. It has the same patina and look of the aluminium sheets that I saw on the aircraft sub-assemblies during my time as an apprentice and employee at the Chadderton site of what was then Hawker Siddeley (ex AVRO) back in the 70's. I want to investigate this technique further in the future, probably on a smaller project first. The taped up area. Un-taped, as you can see there is very little residue if any from this side. What is on the tape has been removed from the primed and painted side. I hope that this has proved useful to you, it has been a worthwhile task for me. 4 Link to comment Share on other sites More sharing options...
Mattlow Posted November 28, 2014 Share Posted November 28, 2014 Thanks John Very useful.... Matt 1 Link to comment Share on other sites More sharing options...
Planebuilder62 Posted November 28, 2014 Share Posted November 28, 2014 I found a way of masking over shiny Alclad Airframe aluminium some time back that did'nt take the paint off with the tape. What i did was to soak a 'post it' in water until it became sft and pliable, but not dripping, and laid that over the shiny alclad. The surace tension holds the paper in place while you paint and the paper comes off straight away when the painting is done. Regards Toby 3 Link to comment Share on other sites More sharing options...
Mattlow Posted November 28, 2014 Share Posted November 28, 2014 Good idea, I've seen people do car paint touch ups with damp newspaper as the masking medium... Matt Link to comment Share on other sites More sharing options...
Procopius Posted November 28, 2014 Share Posted November 28, 2014 I wouldn't recommend newspaper for models, as the ink will run when it's damp, however. 1 Link to comment Share on other sites More sharing options...
Tim Moff Posted November 29, 2014 Share Posted November 29, 2014 people.......like.......the .........Sword kits.......I must be the mad one or somewhat lacking in skills/patience......!! Great build Nimrod, I will aspire to this when I next build a Sword Lighting...in 2114.....!!! 2 Link to comment Share on other sites More sharing options...
nimrod54 Posted December 9, 2014 Author Share Posted December 9, 2014 Made some steady progress on this since the last update the decals are now on and stencil data has been completed on one side. I need to crack on with getting the smaller bits and pieces completed now and then I can wrap this up. 9 Link to comment Share on other sites More sharing options...
Col. Posted December 9, 2014 Share Posted December 9, 2014 Looking good John Link to comment Share on other sites More sharing options...
Tim Moff Posted December 10, 2014 Share Posted December 10, 2014 cool bananas! 1 Link to comment Share on other sites More sharing options...
woody37 Posted December 10, 2014 Share Posted December 10, 2014 Looking great, such a classic Lightning scheme too John, great inspiration to keep on with mine 1 Link to comment Share on other sites More sharing options...
Cookenbacher Posted December 10, 2014 Share Posted December 10, 2014 You do always seem to find the best schemes John - that looks fantastic. 1 Link to comment Share on other sites More sharing options...
Jabba Posted December 10, 2014 Share Posted December 10, 2014 Sorry too bright, I think that you are going to have to tone it down a bit. Seriously a really nice scheme and well applied. 1 Link to comment Share on other sites More sharing options...
Hockeyboy76 Posted December 10, 2014 Share Posted December 10, 2014 That's a lovely looking firebird. 1 Link to comment Share on other sites More sharing options...
nimrod54 Posted December 11, 2014 Author Share Posted December 11, 2014 Cheers guys and thanks for your comments. I'm hoping to get the stencilling finished off today then tomorrow I can clean off any residue before giving it another clear coat. Link to comment Share on other sites More sharing options...
Mattlow Posted December 12, 2014 Share Posted December 12, 2014 Lovely looking Lightning. How do their decals perform...? Did you use any extra 'potions' or just the decals themselves (well with water obviously ) Matt Link to comment Share on other sites More sharing options...
nimrod54 Posted December 13, 2014 Author Share Posted December 13, 2014 Lovely looking Lightning. How do their decals perform...? Did you use any extra 'potions' or just the decals themselves (well with water obviously ) Matt Thanks Matt. As for the decals, I can't say how well they perform because, with the exception of the little red markings on the wings, I have used a set from Model Alliance. The main reason being that the kit decals for this scheme seem to be missing the blue border from around the red and white checkerboard and for the stencils I have used a set from Xtradecal. I did use Micro Sol and Micro Set to get these to settle down though. 1 Link to comment Share on other sites More sharing options...
nimrod54 Posted December 23, 2014 Author Share Posted December 23, 2014 This is gradually crawling along to a conclusion. I have fitted the tailplanes, not wanting to trust a butt join I decided to use some pieces of micro tubing to get a positive fit. The undecarriage legs and doors have been fitted. Today I have added a couple of struts from the nose leg to the nose undercarriage door and aerials to the nose, canopy and aft of the cockpit. The carpet monster has also had another meal having devoured the little box shape that appears to be on one side of the forward canopy, I managed to lose this while bending it to shape. Tailplanes fitted using micro-tubing for a positive location. Aerials fitted. Next up is to paint the aerials, fit the canopy and try and do something to tidy up the anti-glare panel. 3 Link to comment Share on other sites More sharing options...
Tim Moff Posted December 23, 2014 Share Posted December 23, 2014 great job - what did you use for the 2 Antenna behind the cockpit? What colour you painting them? My originals lost against the carpet monster! 1 Link to comment Share on other sites More sharing options...
