sean Posted September 9, 2014 Posted September 9, 2014 (edited) I would like to join in with the Academy Sabre kit, using the Colombian markings options on the Microscale sheet for Canadair Mk6 Sabres. And the sprues: Regards, Sean Edited September 20, 2014 by sean 1
Mozzy19 Posted September 10, 2014 Posted September 10, 2014 I don't think I've seen a Columbian Sabre built before. I'm looking forward to seeing it progress. Sean 1
sean Posted September 20, 2014 Author Posted September 20, 2014 Cheers Mozzy. Started: The cockpit was put together fairly quickly and the fuselage joined together. And I've also started the Airfix Sabre, as the colours are the same, plus I bought a Modeldecal sheet for a Magister build, and it also has options on it to fit an R.A.F Sabre: One thing I noticed was the difference in size between the two kits. The Academy Sabre is a slightly bigger, especially in the depth of the fuselage. So, someone has got it wrong?? Regards, Sean 1
sean Posted September 29, 2014 Author Posted September 29, 2014 And a little bit more, not much, but a little bit: Regards Sean
TEMPESTMK5 Posted October 8, 2014 Posted October 8, 2014 Good morning Sean Yes they are both looking good 1
sean Posted October 29, 2014 Author Posted October 29, 2014 (edited) An update: I've recently had a slight case of mojolostitis, and couldn't really get enthused at all about doing any modelling. But these things pass, and I started a different build to these last week and that sort of kickstarted things back up,(although my Magister still languishes to the side on the modelling table). I basically just done an hour here and there and this is where I'm at:: The Airfix RAF Sabre, pretty much all the paint done, just another coat on the undersides, The Academy Colombian Sabre, halfway through paint, with the underside not touched at all. Regards Sean Edited October 29, 2014 by sean 1
