HansReggelsen Posted September 4, 2014 Share Posted September 4, 2014 I've gotten hold of the 1/48 Hasegawa AH-64D Longbow. I bought it after studying the sprulayout and found it to be identical with Hasegawa's WAH-64D kit. I have the Aviation Worshop decals where there are decals for the british WAH-64D. What more do I need - surely it can't be this easy, can it? Cheers Hans J Link to comment Share on other sites More sharing options...
David Womby Posted September 4, 2014 Share Posted September 4, 2014 Not an expert but does the kit have the larger side sponsons that the UK Army machines have? David Link to comment Share on other sites More sharing options...
Stephen Posted September 4, 2014 Share Posted September 4, 2014 You need this to build a British Apache http://www.kitsforcash.com/apache-wah-64d-ah1-uk-spec-update-including-cvr-7-pods-130-p.asp HTH Stephen Link to comment Share on other sites More sharing options...
HansReggelsen Posted September 4, 2014 Author Share Posted September 4, 2014 Hi David - yes it does come with the larger sponsons - I checked it once, I checked it twice... Hi Stephen - thanks for the link! However I also found a set from Isracast which also have all the stenciling as well as the resin parts, so I think I'll go with that. Cheers Hans J Link to comment Share on other sites More sharing options...
daryl_five_zero Posted September 4, 2014 Share Posted September 4, 2014 The Heritage kit is all you need for the older fit Apache AH. Mk1, with the 4-point HIDAS fit. There are still a few cabs flying around with this fit, instead of the newer 5-Point fit. Just do a bit of research to get your tail codes right. As far as I am aware, all AH.1's have been upgraded with the M-TADS housing, so if you wanted to do up-to-date you'd either need the IsraCast set, or better still, the extra sprue from theJapaneseversion of the Hase AH-64D. Only problem with the IsraCast set is that it doesn't include the 3rd MPD to replace the ORT in the CPG's pit. Link to comment Share on other sites More sharing options...
Shaun Posted September 4, 2014 Share Posted September 4, 2014 I can help if you need the M-tads and 5 point fit? Shaun Link to comment Share on other sites More sharing options...
HansReggelsen Posted September 5, 2014 Author Share Posted September 5, 2014 Thanks to Daryl and Shaun. I plan on doing ZJ232 a WAH-64D Apache AH.1 of 664 Sqn from Afghanistan in 2007 as depicted in the Aviation Workshop/Model Alliance decalsset 'Airwars Afghanistan 2003-2007 - part 1'. Do you think that I'm clear to go? I must admit - and you've problaby allready guessed - that british Apache's are a pretty new subject to me! Cheers Hans J Link to comment Share on other sites More sharing options...
daryl_five_zero Posted September 5, 2014 Share Posted September 5, 2014 I imagine that'd be fine... IIRC it wasn't until around 2010 onwards they started fitting M-TADS to UK Apaches.Have a look at Gary Stedman's pictures on the walkaround section on here... you'll be hard pushed to find a more comprehensive set of pictures of the Apache AH.1! HTH Daryl Link to comment Share on other sites More sharing options...
HansReggelsen Posted September 5, 2014 Author Share Posted September 5, 2014 Thanks once again to all who answered - I can almost not wait to get started! Cheers Hans J Link to comment Share on other sites More sharing options...
