georgeusa Posted October 2, 2014 Share Posted October 2, 2014 I always like your metal work and am always impressed. Looks great. 2 Link to comment Share on other sites More sharing options...
Stew Dapple Posted October 2, 2014 Share Posted October 2, 2014 That tow bar is a little work of art all in itself Cheers, Stew 1 Link to comment Share on other sites More sharing options...
Bengalensis Posted October 2, 2014 Share Posted October 2, 2014 Lovely metal work as always. A delight to watch. I assume you are going to open the slots in the tractor's front shield? 1 Link to comment Share on other sites More sharing options...
Nigel Heath Posted October 2, 2014 Author Share Posted October 2, 2014 Thanks Chaps. I have thought about opening up the slots but the ribs on the back make this a little tricky: My thinking was that a black wash would suffice to give the illusion of depth but I have not ruled it out. Tonight I started to fabricate a tubular frame for the seat using 0.6mm brass rod: I soldered that up including some stylish and safety enhancing armrests: I will clean it up further but this is what it looks like in place: Most of the inspiration for its design came from the one we saw in Texas: There is more metal work to do including a new steering column assembly and hooks. No rest for the wicked. 3 Link to comment Share on other sites More sharing options...
Nigel Heath Posted October 2, 2014 Author Share Posted October 2, 2014 Using the thickest piece of PE I could find and some 1mm rod for the hook this is how I mounted it up for soldering: I also thought it would be a good idea to add a mounting pin on the back so I used some 0.8mm rod for that. Here it is just after soldering: After trimming and fettling I got this: Here is where it will go: I also cleaned up some filler I had used to blend in the tow hitch: Time for bed now, Bye, Nigel 8 Link to comment Share on other sites More sharing options...
louiex2 Posted October 2, 2014 Share Posted October 2, 2014 The Post-Doctorate course in model building continues. Simply amazing work! 2 Link to comment Share on other sites More sharing options...
Vanja #66 Posted October 3, 2014 Share Posted October 3, 2014 Great to see you haven't mistakenly made yourself a new loofah, Nigel... Metalwork is exceptional, as always... 1 Link to comment Share on other sites More sharing options...
infofrog Posted October 3, 2014 Share Posted October 3, 2014 I soldered that up including some stylish and safety enhancing armrests: I will clean it up further but this is what it looks like in place: Nigel How did you get those very nice bends ? Did you use a bender ? Rick 1 Link to comment Share on other sites More sharing options...
georgeusa Posted October 3, 2014 Share Posted October 3, 2014 Okay, now you are just showing off! Seriously, you use of metal and how well you fabricate it is a thing of beauty and awe. Very nice. 2 Link to comment Share on other sites More sharing options...
Nigel Heath Posted October 3, 2014 Author Share Posted October 3, 2014 I have a bender for PE but not for rod. What I tend to use are these pliers: I use the flat jawed ones for sharp(ish) bends - hold in the pliers and bend by hand and the round jawed ones for softer radii: I made the seat frame and hook just using these. I also used the round pilers to make the hitch ring. I hope that helps. 3 Link to comment Share on other sites More sharing options...
Bordfunker Posted October 3, 2014 Share Posted October 3, 2014 Nice work on the tractor Nigel. The tow hook is a mini masterpiece. Karl 1 Link to comment Share on other sites More sharing options...
Nigel Heath Posted October 4, 2014 Author Share Posted October 4, 2014 Tonight I went out for a curry with my new office chums but when I got back I decided to have a go at the steering wheel. First I made a 7mm diameter ring out of some 0.6mm rod, then I slipped a short length of 1mm tube onto a piece of 0.8mm rod that would eventually form the steering column. I also found a little circular instrument bezel that was a nice fit over the tube: Here is that bezel mounted at the top of the column, I also punched a cunning 1mm hole in some card: The column would stand on its own in the punched hole: Things were a little more stable with some additional jigging though and I was able to add three strips of scrap PE to form the wheel spokes: This is what they looked like after they had been soldered up: Each spoke could then be soldered onto the rim in turn with damp tissue stopping the centre from melting: That's that done: After some cleaning up this is what it looks like in position: There is still a support brace to add and a corrugated rubber boot at the base but I think that looks quite nice. (Way better than the kit dustbin lid anyway). Bye for now, Nigel 9 Link to comment Share on other sites More sharing options...
infofrog Posted October 4, 2014 Share Posted October 4, 2014 Your sheet metal work is awesome .. . Rick 1 Link to comment Share on other sites More sharing options...
keefr22 Posted October 4, 2014 Share Posted October 4, 2014 That steering wheel is just brilliant Nigel ! What power soldering iron & what size tip do you use? I could do with being able to solder the electrical dropper wires on my model railway track that neatly....!! keith 1 Link to comment Share on other sites More sharing options...
Nigel Heath Posted October 4, 2014 Author Share Posted October 4, 2014 Thanks guys. For this job I used my 25W Antex iron with a 2mm tip. It was probably bigger than ideal but it worked OK. I have a 15W and smaller tips as well but this bigger one was all set up so I used that. Now I going to try to get some white primer on things. Link to comment Share on other sites More sharing options...
Bordfunker Posted October 4, 2014 Share Posted October 4, 2014 That's a lovely bit of soldering Nigel. Karl 1 Link to comment Share on other sites More sharing options...
Nomore Shelfspace Posted October 4, 2014 Share Posted October 4, 2014 I've been following this one with my mouth open (no flies about fortunately). I built the same kit about 14 years ago and never liked it, mainly because of the weird scale, but this is taking this X-3 shaped piece of plastic to a new level. Hope whatever contest it goes in it wins. 1 Link to comment Share on other sites More sharing options...
Nigel Heath Posted October 4, 2014 Author Share Posted October 4, 2014 I got on the first of what I anticipate to be two coats of Alclad white primer: Things went reasonably well and the underlying naughty primer seemed to behave: I also sprayed the undercarriage doors and got some white followed by yellow on the tractor engine grilles so that they could be masked up to prevent overspray going inside: While that was hardening up I made a second hook for the front of the tractor: I did make an earlier one but that got eaten by the carpet monster. 4 Link to comment Share on other sites More sharing options...
Sgt.Squarehead Posted October 4, 2014 Share Posted October 4, 2014 Your metalwork never fails to amaze me. 1 Link to comment Share on other sites More sharing options...
Winenut Posted October 4, 2014 Share Posted October 4, 2014 Damn that carpet monster 1 Link to comment Share on other sites More sharing options...
Nigel Heath Posted October 4, 2014 Author Share Posted October 4, 2014 As per usual, the first coat of primer revealed seams and sink marks that I thought had been dealt with: I dealt with those using Squadron white filler: As well as other filled areas, I rescribed all the panel lines again as some were getting filled in. Just prior to applying the second coat I reattached the nose: This is the second coat before any sanding: I think it is now looking quite reasonable: I will let it harden up while I make dinner and then get it ready for a top coat of Tamiya gloss white in the morning: I am sure there are also plenty of jobs still to do on the tractor. Onwards and upwards. Nigel 5 Link to comment Share on other sites More sharing options...
Sgt.Squarehead Posted October 4, 2014 Share Posted October 4, 2014 It's certainly a lot less textured than the last time! 1 Link to comment Share on other sites More sharing options...
jgrease Posted October 4, 2014 Share Posted October 4, 2014 One of my favorite kits from childhood. Great work! 1 Link to comment Share on other sites More sharing options...
Nigel Heath Posted October 5, 2014 Author Share Posted October 5, 2014 After a thorough sanding I think this is now ready for the top coat: I discovered that my Tamiya white was almost all gone so I think I will be using Vallejo white for the final finish. I decided to add this piece of Flying Banana surplus PE for no better reason than I thought it looked nice, was a perfect fit and added some interest value: I could not see any reason for not now gluing on the underside: I then cut off the unrealistic hooks: Next I mixed up some Milliput and filled the various gaps and notches: I then got to work on the tractor instrument panel, I had this fret of multiple instruments which looked like it would offer an ideal candidate: This is the sort of effect I was trying to reproduce: I think this will do: Next I made up a brace for the steering column using some 1mm tube and 0.6mm rod: This is how that looks in position: The great thing is I can still turn the steering wheel - result! Bye for now, Nigel 7 Link to comment Share on other sites More sharing options...
hendie Posted October 5, 2014 Share Posted October 5, 2014 looking good Nigel. I spotted a couple of those x3's on ebay - it seems some are motorized and make jet noises! 1 Link to comment Share on other sites More sharing options...
