goon Posted August 31, 2014 Share Posted August 31, 2014 Hi gang, I need to make a tarmac road surface, so need to lay about 2mm of something with a realistic texture on to the hardboard back of a picture frame. I'm guessing it needs an amount of flexibility so as not to crack or peel away from the hardboard. Any suggestions of what to use please? Preferrably available from somewhere like B&Q so I can go out and get some this afternoon. Cheers, Gareth Link to comment Share on other sites More sharing options...
heloman1 Posted August 31, 2014 Share Posted August 31, 2014 Aerosols and paint it. I lay down two or three coast of grey primer over a couple of coats of sanding sealer applied by brush which gives abit of texture and gives a good ket to the hardboard and for the cellulose paint. I then mist alternate coats of cream dark grey and black. If it's too darl or light just and more grey or black as required. Four aerosols from Halfords plus a small tin of sanding sealer shouldn't cost too much and you'll have enough for lots of roadway bases. For a concrete base lay the cream down first. Colin Link to comment Share on other sites More sharing options...
Foghorn Leghorn Posted August 31, 2014 Share Posted August 31, 2014 Wet 'n Dry sandpaper, various grades to choose from and being dark grey it comes precoloured Link to comment Share on other sites More sharing options...
Andrew Jones Posted August 31, 2014 Share Posted August 31, 2014 Wet 'n Dry sandpaper, various grades to choose from and being dark grey it comes precoloured Yes , that would be my suggestion as well , precoloured and textured , just weather it a bit. Link to comment Share on other sites More sharing options...
goon Posted August 31, 2014 Author Share Posted August 31, 2014 Thanks for the ideas. I've got some things to embed in it so it really needs to be a pourable / spreadable substance. Cheers, Gareth Link to comment Share on other sites More sharing options...
Jabberwocky Posted September 1, 2014 Share Posted September 1, 2014 How about some silicon bathroom sealant, mixed with fine ground scatter for model railways of the right colour and texture? It should be paintable, spreadable, and flexible enough to cope with handling. Cheers, Paul Link to comment Share on other sites More sharing options...
FZ6 Posted September 1, 2014 Share Posted September 1, 2014 You can get some textured aerosol paint. I have got some which is an ideal colour and texture for tarmac. I picked mine up from B&Q Link to comment Share on other sites More sharing options...
goon Posted September 1, 2014 Author Share Posted September 1, 2014 Thanks for the further replies. I've mixed some flexible filler with the normal stuff and a lot of water. It was drying slowly last night, so we'll see what it's like when I get home. I suspect I might be having to have a second go though! Link to comment Share on other sites More sharing options...
