plasmahal Posted August 28, 2014 Share Posted August 28, 2014 (edited) Hi,[/size]So I have started applying decals for my second d-day build.I'm using the kit decals from Academy and micro set and sol.The outside of the decal goes down nicely but the more central areas and majority of decal do not go down to give that painted on look.I hope you can see from this photo:The edges, including some of the blue have gone down well but the rest is not really sucking down.Is this due to thickness of decal?Why has edge gone down OK?Is there anything I can do?ThanksToby. Edited August 28, 2014 by plasmahal Link to comment Share on other sites More sharing options...
robvulcan Posted August 28, 2014 Share Posted August 28, 2014 Weird !, I would remove the decal and get some of the excellent Fantasyprintshop decals. I often replace kit roundels with theirs http://www.fantasyprintshop.co.uk/USA-Stars-and-Bars_B223LJW.aspx Link to comment Share on other sites More sharing options...
georgeusa Posted August 28, 2014 Share Posted August 28, 2014 You might try perusing this thread. http://www.britmodeller.com/forums/index.php?/topic/234964617-decal-solution-stronger-than-microsol/ He was having similar problems and various solutions to his problems were suggested. Link to comment Share on other sites More sharing options...
charley420 Posted August 28, 2014 Share Posted August 28, 2014 Could ther be air trapped under the center? Try pricking it then apply more so until it wrinkles then use a hairdryer on low heat to evaporate the liquid out from underneath. Link to comment Share on other sites More sharing options...
plasmahal Posted August 28, 2014 Author Share Posted August 28, 2014 It does not seem to be trapped air or any silvering issue. Looking at some of the other decals on the sheet, they have 3 distinct thicknesses.So it seems that its a very thick decal, so i need to look at dealing with that as there are no silvering issues. Link to comment Share on other sites More sharing options...
