jimmysze
Tamiya 1/12 Ducati 1199 Panigale S - Senna Version
Just received the Blue Stuff Senna decals from Hiroboy last week as well as the Tamiya detail-up parts from the LHS.
ill be using some Hobby Design rivets for detailing the engine block and fairings and Hobby Design air valves.
This is going to be a fairly slow build as I only spend a few hours on the weekend. Any ways here are the pics.
Some Hobby Design stuff
Blue Stuff Decal sheet. Lots of optional decals for the licence plate and exhaust.
Just got the block and valve covers painted and assembled. Also drilled some holes here and there for added bolt details using references online. Still need to add some detail painting for the bolts on the oil pan and cover.
Snipped the molded valve stems and drilled the appropriate size holes for the Hobby Design valve stems.
Then went ahead and primed with Tamiya pink primer.
Painted the wheels in Tamiya TS49. Will clear them next week end when the paint is fully cured.
So far its been a great kit to build. The parts have really nice assembly seams and joints which require minimal work. The past 3 kits I built were all reissue items using old tooling and had to spend quite a bit of time cleaning up the parts and assembly.
Ill have more updates over the weekend. Thanks
Edited by jimmysze
Nice so far I have this kit and the Senna decals, and should be starting it shortly, so will be following with interest. I also have the Grigio Scuro paint from Hiroboy, looking at the pics of the real thing it seems as though the finish is satin as opposed to the red version, what do you think.
Dave
Dave
Hey Dave. I'll be looking forward to your build as well if you decide to share it on the forums.
I think the Senna Version is also high gloss clear finish. It's probably the metallic finish that gives it the satin illusion.
The below reference shows some very bright and sharp highlights that almost seem white, which you would not get on a satin finish.
i thought about picking up the zero paints too.... but I settled with Tamiya TS38 Gunmetal
EBB6144386D157662435DA66FDB67_h498_w598_
Thanks Jimmy it certainly does look like gloss, as soon as i start the build i will post up some pics.
Dave
A little update so far.
I got the engine mostly painted and assembled to the main chassis.
Then i finished up the radiator and fan assembly
Hammered the wheels with clear. Next I'll have to mask and paint the rear axle nut then fit the valve stems on
I just snipped these off the sprue and glued the exhaust together after fitting. Next step is to clean up the part lines and lay some paint.
Thats it for now. I should have the exhaust system painted by tomorrow
Lookimg good Jimmy. I've got one in the stash but not sure I'm going to be starting it soon. I think I migh wait for the race version 2015...
Colin
I picked one of these up a while back - got it before I even read the preview article in TMMI! I'll be doing mine OOB, possibly with the Tamiya upgrade set if I can get hold of one for a reasonable price. Looks a great build so far!
Colin
I wanted to wait for the race version too but i just couldn't resist. Maybe I'll build another one later on as this kit is pretty awesome so far.
Same here! I saw it at the LBS and just had to pick it up just from the box art haha
So i worked on the exhaust today. used red gold, titanium silver and light gunmetal paints at different viscosity for the burnt exhaust look. I steered away from the clear blues and oranges as i felt it might end up looking too fake. I'll be shooting the slip joints with a textured matte clear and leaving the runners as is.
I was only able to lay the black coat over the mufflers today. the metallics should pop more this way.
Edited by jimmysze
Looking good Jimmy, funnily enough I was looking a one of those earlier on, I'm undecided on what to build at the moment
So it's Saturday which means a little progress and update. So i finally got the mufflers finished which took lots of masking.
Fitted the exhaust on and followed that up with installing the rad and rad hoses.
This is truly a wonderful kit to build... the fit is hassle free.
...also picked up this new release from the LHS... will do a review soon
starting to look a little more like a motorcycle
drilled out the holes for the rear brake rotor as tamiya only molds the imprint of where the holes would be.
rear swingarm pretty much complete
still deciding if i want to paint the rear fender (mounted on swing arm) in carbon fibre effect or the factory charcoal color
Edited by jimmysze
Looking really good Jimmy, can you tell me what color you used for the gold colored engine parts, as in having trouble finding a suitable colour.
Dave
Looking really good Jimmy, can you tell me what colour you used for the gold colored engine parts, as in having trouble finding a suitable colour.
Dave
Thanks Dave! I used IPP titanium silver mixed with very very very little IPP red gold to saturate it a little bit. Then I used a matte clear over the parts.
Carbon...definitely!
You know you want too......
ATB
I ended up painting it charcoal to keep true to the senna version :P
But ill definitey do the front fender in carbon! Now time to search for the perfect pantyhose
Super small update... sprayed the rear swingarm parts and glued them in place... then screwed the rear swingarm to the main chassis.
just threw the unfinished rear wheel on there to keep the motivation going.
[url=[/url" rel="nofollow" style="color: rgb(59, 89, 152); cursor: pointer; text-decoration: none; font-family: Helvetica, Arial, 'lucida grande', tahoma, verdana, arial, sans-serif; font-size: 13px; line-height: 17.9400005340576px; white-space: pre-wrap;" target="_blank">http://s1383.photobucket.com/user/Jimmy_Sze/media/06EEFC33-56B8-4A16-A24F-9612D1EC372C_zpshdfsfpve.jpg.html]06EEFC33-56B8-4A16-A24F-9612D1EC372C_zps[/url]
Hi Jimmy,
I do love the IPP colours you are using! Not seen them before & had a look....what a range of paints.
Senna looks stunning......more, more??
ATB
got the side braces finished up and assembled and installed the rear shock. the piggy back reservoir is a detail-up part from the tamiya front fork set with the ohlins decal applied by the builder.
finished the wheels. painted the hobby design valve stems (blk caps) and glued those in place.
masked the rear wheel lock and sprayed it titanium silver.
the front rotors also have detail up parts from tamiya to replace the molded rivets holding the 2 piece rotors together. this requires you to drill holes for installing the rivet details. also drilled out the holes on the rotors which took a long time...
Lookin' good Jimmy. I've hidden my kit in the stash, in the hope that out of sight is out of mind... We shall see! Hopefully in the New Year we wil see the race version?
Colin
If i didnt have such a backlog, including some tamiya bikes, i would buy one tomorrow based on your build, it looks lovely indeed.
Nice work, I must get mine started soon. I've got two hobby design detail kits but I've decided I'm only going to build one Panigale now.
So i ran into a little hiccup while painting the rear brake reservoir and bracket.
did a poor masking job and the black ran into the white. I'll try and repaint it tomorrow
Put the motorcycle stand together and painted it IPP super red (about the same as tamiya italian red)
still have to paint the hub mount black, paint the rollers and apply a decal and clear.
So i'm on holiday break and have some free time to work on the kit. Tackled the front fork today.
Started off painting the top crown along with the brake reservoir then gluing on the detail up parts ontop. its the silver ring, the anodized blue lock nut and the black 90 degree piece. (black ring is for the rubber seal/gasket at the stanchions)
These are the rest of the parts that come with the detail up kit ready for assembly.
painted the fork legs in titanium silver and cleared with matt clear
...and here is the fork assembled and installed. Front fender is only dry fitted cause it still needs the carbon fibre treatment
hey man nice clean build you have going on here, I'm also working on the same model so perhaps I'll put up my build soon.
I have enjoyed watching your WIP keep it up fella!
