Nigel Heath Posted September 1, 2014 Author Share Posted September 1, 2014 My fuel tanker had a little mishap at the recent Dundee model show so I had some repair work to do. The most involved was to fabricate a new door mirror to replace the one that snapped off and was never seen again: Here it is all finished: I glued down the hose with some Gator glue and added the hose between the tanker and pump unit: With that I think I can call this whole project finished: I know some figures would set it off but I'm still thinking about those. Here is the RFI. Cheers, Nigel 2 Link to comment Share on other sites More sharing options...
Sgt.Squarehead Posted September 1, 2014 Share Posted September 1, 2014 Looks great Nige! As for the figures, I think you need to find something in hard plastic that you can really work with - Preiser would be ideal, but they are a swine to get hold of. Soft vinyl figures are a pain to work with and the results aren't always that great, I'm not saying it can't be done (see Mottlemaster's excellent C-47: http://www.britmodeller.com/forums/index.php?/topic/234962362-airfix-c-47-from-upottery-over-dropzone/ ), but your figures will be rather more open to scrutiny on the base. 1 Link to comment Share on other sites More sharing options...
Moggy Posted September 1, 2014 Share Posted September 1, 2014 Nigel - this model/vignette is yet more inspiration to emulate your project! I've learned some new techniques and a few new wrinkles on known ones. I'm making your WIP thread and this a PDF doc I can consult at home. Cheers, Moggy 1 Link to comment Share on other sites More sharing options...
Nigel Heath Posted September 1, 2014 Author Share Posted September 1, 2014 Aw, thanks Moggy that is very kind of you. Nigel 1 Link to comment Share on other sites More sharing options...
hendie Posted September 1, 2014 Share Posted September 1, 2014 lovely work there Nigel 1 Link to comment Share on other sites More sharing options...
georgeusa Posted September 1, 2014 Share Posted September 1, 2014 It looks great Nigel. I am not real sure it needs any figures at all. Will they really add to the story? 1 Link to comment Share on other sites More sharing options...
philp Posted September 2, 2014 Share Posted September 2, 2014 Looks great. 1 Link to comment Share on other sites More sharing options...
louiex2 Posted September 3, 2014 Share Posted September 3, 2014 Nigel- excellent work, but then I am never disappointed by your masterful work. As to figures, I don't know if you've checked out Preiser, but they do have several sets of ground crews in 1/72nd scale, USAF WW2 and Luftwaffe, both painted and unpainted. Since I'm across the pond, I'm not sure who th UK stocking are but model train shops can usually get them or you might try Hattons. Keep up the great work! 1 Link to comment Share on other sites More sharing options...
Nigel Heath Posted April 21, 2015 Author Share Posted April 21, 2015 I am going to enter my Flying Banana diorama into the Scottish National Model Show this weekend but the wet and dry sand paper squares used to represent the concrete slabs have started to curl and lift at the edges. Clearly 3M Photo Mount is not the best adhesive for this sort of job even though it was quick and convenient. For the repair I decided that contact adhesive was the best solution, fortunately I had some in my Modelling Materials Storage Facility. The worst offending square was removed completely and the adhesive applied to the surrounding, lifting edges as well as both surfaces of the removed square: Here is the finished result which has pretty much sorted out the issue: I even managed to not get any of the glue on the visible surfaces. Result! Bye, Nigel 2 Link to comment Share on other sites More sharing options...
