HOUSTON Posted September 13, 2014 Share Posted September 13, 2014 Impressive work. Link to comment Share on other sites More sharing options...
andy wood Posted September 19, 2014 Share Posted September 19, 2014 liking this Link to comment Share on other sites More sharing options...
Brandy Posted October 17, 2014 Share Posted October 17, 2014 Coming on nicely - looks like another little gem from the OM factory coming into being... Ian Link to comment Share on other sites More sharing options...
Learstang Posted October 17, 2014 Share Posted October 17, 2014 Excellent work, OM! I don't know how I missed this one. You make scratch-building almost look easy. Almost. It makes me want to get back to my long-stalled scratch-built Dayton-Wright RB racer. Almost. Regards, Jason Link to comment Share on other sites More sharing options...
Old Man Posted October 19, 2014 Author Share Posted October 19, 2014 Thank you very much, Gentlemen. It has been a while since I could post an up-date, but there has been considerable progress, and most of it I did manage to get pictures taken of, if not processed through until recently. So this is likely to be a fairly long post.... The first item was getting the cowling completed. This involved cutting in some surface detail down low on the forward fuselage sides, and piecing together the lower portions of the cowling after the motor had been affixed. It was necessary to replace the front strip; it took several attempts before I managed one with satisfactory perforations. The underpart of the cowling is built up from a total of seven small pieces (five 'parts'; and two 'patches' where angles were sanded through). This took quite a while, though a lot of the time was spent figuring out how to do it and how to make it work. If I were to do it again, it would be a fairly direct process and not take more than an hour or two. I am not sure what is going on on the lower fuselage sides, but I suspect there is a fuel and oil tank directly behind the engine. The deliberately thick sides and bottom gave ample play for the cutting. Next step was finishing the horizontal tail-plane and attaching this and the lower wings to the fuselage. This went fairly smoothly, and I feel good about the prospect of locator holes lining up, and that sort of thing. There has been some more refining of the sculpting on the nose. After putting in cabane locator hole in the fuselage, painting has commenced.... The linen color is PollyScale 'Old Concrete' cut with some 'IJA Grey'. I do not intend to weather this machine as heavily as I did the Short 827. The only major piece left to make is the vertical tail surface (this has to fit over the tailplane, and goes up to the end of the triangular decking). Wheels and propeller wil come from the spares box; I am very glad to note in the in-service up the Tigris picture, wheel covers are in place. Cabane struts will be put on first, and upper wing then attached, after which interplanes will be put in. This is because there are fish-plates for the cabane attachments to the fuselage, which I do not think could be gotten at readily if the uper wing was already on. It will be a close-run thing, a sit usually is with me and dead-lines, but I expect I will have this in hand by the closing bell.... 2 Link to comment Share on other sites More sharing options...
stevehed Posted October 20, 2014 Share Posted October 20, 2014 Good going, Old Man. Cowling looking good. I think getting the contours right here are the make or break parts for this build. Regards, Steve Link to comment Share on other sites More sharing options...
CliffB Posted October 20, 2014 Share Posted October 20, 2014 I'm full of admiration. Looking really good. Cliff Link to comment Share on other sites More sharing options...
rbeach84 Posted October 20, 2014 Share Posted October 20, 2014 Aye, that is looking spiffy! Look forward to the final results. Love a good scratch job... hey! R/ Robert Link to comment Share on other sites More sharing options...
dazdot Posted October 20, 2014 Share Posted October 20, 2014 nice work, keep it up Link to comment Share on other sites More sharing options...
Old Man Posted October 27, 2014 Author Share Posted October 27, 2014 Thank you very much, my friends. Bit more done on this over the weekend, Gentlemen. Definitely on the down-slope now.... Undercarriage and cabanes are on, as are the various 'fish-plates' at critical joints, and a coaming for the cockpit, and the vertical tail surface has been made. The fish-plates are a bit over-scale in thickness, but such is life in 1/72. Finish over-all has been tightened up a bit. One nice thing about the design is that there is no splay to the undercarriage or the cabanes, which makes them easier to set up. I will rig the cabanes before attaching the upper wing. Last picture shows the upper wing resting on the cabanes in a test-fit. This picture shows the miniature Union Jacks wife set up for me; two will go on the rudder, one each side (also some U.S.A.A.C. markings, shield for the Technical School, for another build I am working on). 1 Link to comment Share on other sites More sharing options...
dazdot Posted October 27, 2014 Share Posted October 27, 2014 Words fail me now I think that is truly awesome I just wouldn't know where to begin Link to comment Share on other sites More sharing options...
Old Man Posted November 3, 2014 Author Share Posted November 3, 2014 Rounding the turn into the home stretch here, friends; upper wing attached and structural rigging put in.... Interplane struts were made individually once upper wing was on the cabanes. Tricky business, but no serious difficulties. Next session ought to see it complete.... 2 Link to comment Share on other sites More sharing options...
Ray S Posted November 3, 2014 Share Posted November 3, 2014 Fabulous work Old Man! I have learnt so much reading through this, inspirational! All the best, Ray Link to comment Share on other sites More sharing options...
Sgt.Squarehead Posted November 4, 2014 Share Posted November 4, 2014 Astounding modelling and what a bizarre looking subject.....Smashing stuff! Link to comment Share on other sites More sharing options...
Old Man Posted November 4, 2014 Author Share Posted November 4, 2014 Fabulous work Old Man! I have learnt so much reading through this, inspirational! All the best, Ray Thank you, Sir. A taste for the obscure will drive a man to scratch-build.... Astounding modelling and what a bizarre looking subject.....Smashing stuff! Thank you, Sergeant. But still.... Call that bizarre? THIS is bizarre.... 1 Link to comment Share on other sites More sharing options...
Learstang Posted November 5, 2014 Share Posted November 5, 2014 Great work on the S.1, OM, but what on Earth is that Bristol(?) thingy? It looks like something made up for "Those Magnificent Men in Their Flying Machines"! Regards, Jason Link to comment Share on other sites More sharing options...
Old Man Posted November 5, 2014 Author Share Posted November 5, 2014 Great work on the S.1, OM, but what on Earth is that Bristol(?) thingy? It looks like something made up for "Those Magnificent Men in Their Flying Machines"! Regards, Jason That, Sir, is a Breguet U1 'affine', a 1914 design, the last of the 'single spar' Breguet tractors. It is needless to say a scratch-build.... Link to comment Share on other sites More sharing options...
Sgt.Squarehead Posted November 5, 2014 Share Posted November 5, 2014 A very impressive one at that! Link to comment Share on other sites More sharing options...
dazdot Posted November 5, 2014 Share Posted November 5, 2014 Very very impressive on both counts Link to comment Share on other sites More sharing options...
Old Man Posted November 9, 2014 Author Share Posted November 9, 2014 This is done, though not yet properly photographed. I am putting up some flash shots taken Saturday, as the chances of getting better ones taken before Tuesday are nought to nil. So here it is.... 6 Link to comment Share on other sites More sharing options...
JOCKNEY Posted November 9, 2014 Share Posted November 9, 2014 Congratulations Old Man Wonderful job of bringing a bit of forgotten history back to life. Cheers Pat Link to comment Share on other sites More sharing options...
dazdot Posted November 10, 2014 Share Posted November 10, 2014 Very nice well done that man Link to comment Share on other sites More sharing options...
Learstang Posted November 10, 2014 Share Posted November 10, 2014 Brilliant job, OM! Regards, Jason Link to comment Share on other sites More sharing options...
stevehed Posted November 10, 2014 Share Posted November 10, 2014 Tremendous build, OM. Regards, Steve Link to comment Share on other sites More sharing options...
Sgt.Squarehead Posted November 10, 2014 Share Posted November 10, 2014 Superb! Link to comment Share on other sites More sharing options...
