Troy Smith Posted August 21, 2014 Share Posted August 21, 2014 Ok! Here is my stupid question, was the prop used on the mk1 the same as the prop used on the Spit Mk1a this has been discussed here before. HINT - use google, add 'Britmodeller' into your search term, it works better than the site search. Graham sums it up, this might make it clearer more pics and discussion here, despite the thread title, scroll down a bit. http://www.britmodeller.com/forums/index.php?/topic/234956047-romanian-hurricane-underside-colours/ what is available in what scale and what kits is also tricky, as Graham suggest, a more precise question will get better answers. eg "I'd like to build XXXX Hurricane from XXXX kit in XX scale, what spinner do I need". Will probably get you chapter and verse, even if links to previous threads. One caution, kits often gets the spinners wrong! Link to comment Share on other sites More sharing options...
beppe Posted August 21, 2014 Share Posted August 21, 2014 (edited) Hi folks, I read about De Havilland, Rotol propeller, which hurricane used what ? Anyone can help ? I have the hurricane mk1 used in Malta in mind Cheerio, beppe Edited August 21, 2014 by beppe Link to comment Share on other sites More sharing options...
Troy Smith Posted August 22, 2014 Share Posted August 22, 2014 Hi folks, I read about De Havilland, Rotol propeller, which hurricane used what ? Anyone can help ? I have the hurricane mk1 used in Malta in mind Cheerio, beppe Hi Beppe all the Mk I's I have seen on Malta had the De Havilland Hurricane propeller, like this below, [2nd spinner in drawing above] Hawker Hurricane MkI Trop RAF 261Sqn J Sgt F N Robertson P3731 Malta 1941-01 see http://www.britmodeller.com/forums/index.php?/topic/234957764-malta-hurricanes/ The DH prop was favoured in the Middle East for the Mk I ONLY The Mk II used the 'bullet' or Hurricane Rotol only [3rd spinner in drawing above] I don't recall ever seeing a Mk II or mk IV with any other spinner. The 'bullet' Rotol was also fitted to late MkI's, and could be retrofitted, which is why the RAF Museum Hurricane has a bullet Rotol, from it's days in training command. Just a word of caution that a bullet Rotol does not automatically mean it's a Mk II. Handy comparison photo N - Spitfire type Rotol U- Hurricane [bullet] Rotol R- Hurricane De Havilland Canadian planes are a different story... cheers T 1 Link to comment Share on other sites More sharing options...
modelfreak Posted August 24, 2014 Share Posted August 24, 2014 Ok here is my stupid question, In the cockpit tub were the walls paint in slate grey light grey or cockpit green? Link to comment Share on other sites More sharing options...
Troy Smith Posted August 24, 2014 Share Posted August 24, 2014 interior grey green, though this seems to have varied in colour a bit. See page 3. Link to comment Share on other sites More sharing options...
johnd Posted September 10, 2014 Share Posted September 10, 2014 If I was to build a Canadian spinner-less Mk XII, I understand that I'd need a Hamilton Standard propeller from a B-25. Would this be a straight fit or would it have to be modified (blades shortened, for instance)? Also, does anyone have any suggestions how to get hold of a part to represent the engine front in 1/72? I guess a Revell Lancaster engine could act as a donor but that seems a waste... Ta, John. Link to comment Share on other sites More sharing options...
Troy Smith Posted September 10, 2014 Share Posted September 10, 2014 Good question John don't really know about the prop. Somewhere I read they used cut down Battle props. The engine front can't be that hard to scratch, and the Revell Lanc engine would be spare if built closed. This is worth a read, has Canadian planes with Hamilton props with spinners! http://ascalecanadian.blogspot.co.uk/2007/10/rcaf-hawker-hurricanes-part-1.html Link to comment Share on other sites More sharing options...
johnd Posted September 10, 2014 Share Posted September 10, 2014 Thanks Troy. It looks like the Battle prop is the correct base for those fitted to the Mk X. I wonder if the front of the Merlin III looked the same as the Merlin XX? Link to comment Share on other sites More sharing options...
Black Knight Posted September 10, 2014 Share Posted September 10, 2014 I matched the Canadian prop with one from a B17. The B17 one was supposed to be 6 inches in diameter larger than the Hurri H/S, but my kit one was under sized and and worked out the perfect size. http://www.britmodeller.com/forums/index.php?/topic/234965903-hurricane-stgb/ Link to comment Share on other sites More sharing options...
Troy Smith Posted September 10, 2014 Share Posted September 10, 2014 Thanks Troy. It looks like the Battle prop is the correct base for those fitted to the Mk X. I wonder if the front of the Merlin III looked the same as the Merlin XX? The merlin XX comapared to the Merlin III had a section added to the rear, which is why's it's 4 inches longer, the front AFAIK is basically the same. Merlin III Merlin XX HTH T Link to comment Share on other sites More sharing options...
stevehnz Posted September 11, 2014 Share Posted September 11, 2014 This is basically what you are looking to replicate in 1/72 to model a spinnerless Canadian Hurricane nose. The two gizmos at an angle in the lower part of the front cowl opening are the vacuum pump & the constant speed unit ( not sure which is which) I've got a HS prop off an early Revell Martlet which will do me for my version of this come the time. the tricky part will be hollowing out the front of the cowl & conjuring up a smaller version of this two unit below the reduction gearbox housing. Don't expect the ring of bolts around the latter. The talk of Battle props has me puzzled, did the Canadian Battles have a HS prop, 'cause the RAF's Battle prop was nothing like the Hurricane unit? Steve. Link to comment Share on other sites More sharing options...
Graham Boak Posted September 11, 2014 Share Posted September 11, 2014 The vacuum pump is on the starboard side. Link to comment Share on other sites More sharing options...
occa Posted September 11, 2014 Share Posted September 11, 2014 This is basically what you are looking to replicate in 1/72 to model a spinnerless Canadian Hurricane nose. The two gizmos at an angle in the lower part of the front cowl opening are the vacuum pump & the constant speed unit ( not sure which is which) I've got a HS prop off an early Revell Martlet which will do me for my version of this come the time. the tricky part will be hollowing out the front of the cowl & conjuring up a smaller version of this two unit below the reduction gearbox housing. Don't expect the ring of bolts around the latter. The talk of Battle props has me puzzled, did the Canadian Battles have a HS prop, 'cause the RAF's Battle prop was nothing like the Hurricane unit? Steve. Wow I like that, do they have a 1/72 version? Edit: Obviously not. Hope QB or someone else takes up the idea Link to comment Share on other sites More sharing options...
Troy Smith Posted September 11, 2014 Share Posted September 11, 2014 This is basically what you are looking to replicate in 1/72 to model a spinnerless Canadian Hurricane nose. The two gizmos at an angle in the lower part of the front cowl opening are the vacuum pump & the constant speed unit ( not sure which is which) I've got a HS prop off an early Revell Martlet which will do me for my version of this come the time. the tricky part will be hollowing out the front of the cowl & conjuring up a smaller version of this two unit below the reduction gearbox housing. Don't expect the ring of bolts around the latter. The talk of Battle props has me puzzled, did the Canadian Battles have a HS prop, 'cause the RAF's Battle prop was nothing like the Hurricane unit? Steve. Steve the bit about Battle props is in the link I posted http://ascalecanadian.blogspot.co.uk/2007/10/rcaf-hawker-hurricanes-part-1.html The RCAF also received Sea Hurricanes. Yes, the RCAF got some Sea Hurricanes complete with hooks. They were built by CC&F for the FAA but were diverted to Canada. They were in the BW835 to BW884 serial range. The RCAF Sea Hurricanes were basically a Hurricane Mark I with a hook, a DH spinner with a cut down Battle prop, and an eight gun wing. Early in service they carried the Fleet Air Arm scheme of Extra Dark Sea Grey/Dark Slate Grey over Sky. (A common misconception here is that they didn't have hooks. I can't confirm if they all had hooks or some did and some didn't but this one sure did.) This one is BW850 BV-T of 126 (F) Squ. RCAF. I don't know a great deal about Canadian built planes, the above link seems too. The Battle did use the Merlin, so it would be possible to fit the prop to a Hurricane. I have to say, it is amazing the amount of fine detail on Hurricanes that has come up since I joined here and took an active interest. the other great find on the linked blog spot is this one [as often folks don't read links it seems ] Another fun misconception is that RCAF Hurricanes didn't carry spinners. So here are a few that do: Serial unknown, but a XII with rockets...how cool is that! also, this has an interesting feature This one is BW850 BV-T of 126 (F) Squ. RCAF Apart from being a Sea Hurricane over Canada, note the lack of the 3rd access panel which would normally be under the 'T' I had noticed this on this Sea Hurricane shot I have used before, and wondered if it was an old airframe, though now possibly this is a Canadian plane. Does anyone know the serial of this? 1 Link to comment Share on other sites More sharing options...
Kallisti Posted September 11, 2014 Share Posted September 11, 2014 sigh how have I missed this thread for so long, especially when SEAC Hurricanes were being discussed Link to comment Share on other sites More sharing options...
johnd Posted September 11, 2014 Share Posted September 11, 2014 I'm glad I asked that question, there is some good stuff coming out. After a bit more digging, I found a Google book, 'Canadian Warplane', by Harold A. Skaarup. This has some useful info in it about the Canadian Hurricanes and says that the Hamilton Standard was 'as used on the Dakota and Liberator'. Link to comment Share on other sites More sharing options...
stevehnz Posted September 12, 2014 Share Posted September 12, 2014 Steve the bit about Battle props is in the link I posted http://ascalecanadian.blogspot.co.uk/2007/10/rcaf-hawker-hurricanes-part-1.html I don't know a great deal about Canadian built planes, the above link seems too. The Battle did use the Merlin, so it would be possible to fit the prop to a Hurricane. Thanks for clarifying that Troy, when I first read it I confused myself into thinking it was the unspinnered props being refered to, hence my association of Battles with HS props, I think I've got it straight now. Steve. Link to comment Share on other sites More sharing options...
ClaudioN Posted September 13, 2014 Share Posted September 13, 2014 (edited) Please, see the post below where the quote is correctly included. Claudio Edited September 13, 2014 by ClaudioN Link to comment Share on other sites More sharing options...
ClaudioN Posted September 13, 2014 Share Posted September 13, 2014 I had noticed this on this Sea Hurricane shot I have used before, and wondered if it was an old airframe, though now possibly this is a Canadian plane. Does anyone know the serial of this? AE962:D (a Canadian-built Hurricane X converted into a Sea Hurricane Ib, I believe) serial 4'' stencil, red individual letter 'D' behind the roundel. 801 Sqn. ? However, the deck might be Victorious' Claudio 1 Link to comment Share on other sites More sharing options...
stevej60 Posted September 20, 2014 Share Posted September 20, 2014 Hi folks,just building the "warts and all" Airfix 1/48 hurricane and due to the poor recent boxings decals ordered some after market ones.On the sheet there are two Russian aircraft depicted for MK IIb aircraft.What were the main differences between the MKI and IIb? I know the "C" was cannon armed. As a non rivet counter can I model a representation of a IIb from the Airfix kit? Link to comment Share on other sites More sharing options...
Work In Progress Posted September 20, 2014 Share Posted September 20, 2014 (edited) As a non rivet counter you probably shouldn't have asked, because then you would have been happy. The answer is no. The II has a longer nose than the I, and most examples of the IIb have 12 guns rather than 8. The II also has a different tailwheel from that of the I. Edited September 20, 2014 by Work In Progress 1 Link to comment Share on other sites More sharing options...
Troy Smith Posted September 20, 2014 Share Posted September 20, 2014 Hi folks,just building the "warts and all" Airfix 1/48 hurricane and due to the poor recent boxings decals ordered some after market ones.On the sheet there are two Russian aircraft depicted for MK IIb aircraft.What were the main differences between the MKI and IIb? I know the "C" was cannon armed. As a non rivet counter can I model a representation of a IIb from the Airfix kit? As a non rivet counter you probably shouldn't have asked, because then you would have been happy. The answer is no. The II has a longer nose than the I, and most examples of the IIb have 12 guns rather than 8. The II also has a different tailwheel from that of the I. WIP has given a basic answer. Early Mk II's had the same tailwheel and exhausts as MkI though [examples of Mk I's had the later jointed tailwheel fitted, the MkI at Hendon still does] The nose is 4 real inches longer, which is 1/12th inch in 1/48th [about 2mm ] The carb intake is also moved, and the radiator bath is deeper. the MkII nearly always has the longer 'bullet' rotol as well. see here for more detail http://www.britmodeller.com/forums/index.php?/topic/64364-hurricane-noses-and-the-hasegawa-172-kits/page-2 The added wing guns are easy enough to add, just scribe in some new panel, a couple of shell ejector slots and the gun barrels, which protruded from the wing. Here's a restored IIB, http://www.primeportal.net/hangar/mark_hayward/hurricane_iia/ it's NOT a IIA, though the markings are an interesting choice, showing a very early IIA from the BoB. see http://www.britmodeller.com/forums/index.php?/topic/234966142-hawker-hurricane-iia-in-battle-of-britain-photographs-date-of-introduction/ This shows the added gun panels Note also the position of the upperwing roundel, I keep seeing model with it too far outboard... What sheet has 2 VVS IIB's? Is that the Sky Decals sheet? Treat it with caution, lots of it is wrong.... Soviet Hurricanes are a fascinating subject, they got about 3000 of them, nearly a 1/5th of the Hurricanes built! there are a few threads on them here http://sovietwarplanes.com/board/index.php?board=50.0 Note the threads on regunned planes. Link to comment Share on other sites More sharing options...
stevej60 Posted September 20, 2014 Share Posted September 20, 2014 Thanks guys,knew I,d get the answer,just a thought as not many Russian Hurricanes get posted but there are some nice RAF options on the sheet. And yes Troy it is the SKY sheet anything to watch out for regards the MKI options? I have used the decals for JX-B which was the reason for getting the sheet got another two building on will be a Rumanian machine from the Airfix boxing and one from the decal sheet which I will have to choose. Link to comment Share on other sites More sharing options...
Troy Smith Posted September 20, 2014 Share Posted September 20, 2014 I'd have to have a dig in the decal box. PM me or post up here for specifics. Romanian planes, these may help http://www.britmodeller.com/forums/index.php?/topic/234956047-romanian-hurricane-underside-colours/ http://www.britmodeller.com/forums/index.php?/topic/234954616-hurricanes-in-foreign-service/ Link to comment Share on other sites More sharing options...
Sean_M Posted September 21, 2014 Author Share Posted September 21, 2014 what colour is correct for the engine frame on the mk i Sliver or interior green. by frame I mean the wishbone structure on the outside of the merlin that the cover panels are screwed on Link to comment Share on other sites More sharing options...
