longshanks Posted May 13, 2014 Posted May 13, 2014 Hi Folks, A request from the 'darkside' . . . . Maritime modelling I currently building the Airfix Vosper Type I @ 1/72. The detail plans I have call for 4 x Carbines (Assuming Lee Enfield ) to be mounted in racks on the open bridge. Question anyone know of a source for these ? Thanks for your time Cheers Kev
davidelvy Posted May 13, 2014 Posted May 13, 2014 Didn't know there was a Lee Enfield carbine. However, Wikipedia has informed me of the No5 MkI or "Jungle Carbine." No mention of maritime use, though.
Red Dragon Posted May 13, 2014 Posted May 13, 2014 Possibly Lanchester, Thompson or Sten sub machine guns, they were often called 'Machine carbines' in documents, the Lanchester was a Naval weapon. Phi Hi Folks, A request from the 'darkside' . . . . Maritime modelling I currently building the Airfix Vosper Type I @ 1/72. The detail plans I have call for 4 x Carbines (Assuming Lee Enfield ) to be mounted in racks on the open bridge. Question anyone know of a source for these ? Thanks for your time Cheers Kev
cossack52 Posted May 14, 2014 Posted May 14, 2014 i'd be tempted to go with the lanchester;this was a copy of the ww1 bergmann mp18;made for the navy in ww2.,and termed a machine carbine.don't think there was a lee enfield carbine,as the SMLE was made shorter than a standard rifle,longer than a cavalry carbine,to suit both roles
longshanks Posted May 15, 2014 Author Posted May 15, 2014 Thanks Guys for your input. I think you may well be right with the Lanchester machine carbine ! I don't think I going to be able to find models of these ;o) Cheers Kev
Giorgio N Posted May 15, 2014 Posted May 15, 2014 No Enfield rifle was ever designated as a carbine, but clearly the Rifle No.5 was a carbine... in any case this was a late war weapon designed for airborne troops I can't see how it would have been of use on an MTB. It was also mainly used postwar. As others have said, the Lanchester would be the most likely option as it was a weapon used mainly by the Royal Navy (but developed for the RAF). As it was just a copy of the German MP18/28, your best bet is to look for one of these. The MP18 in particular was used by German troops in late WW1 and there are set of figures that include this weapon, at least Hat has one in their WW1 heavy weapons set. I'm sure there should be others
Julien Posted May 18, 2014 Posted May 18, 2014 Yes doubt it was a MK5 . Certainly was lighter but having fired one it kicks like a mule, much more than a MK4 I would not want to fire many rounds from it. Great idea but some limitations. Julien
593jones Posted May 21, 2014 Posted May 21, 2014 No Enfield rifle was ever designated as a carbine, This is not strictly true, as, when the original Lee Enfield rifle was adopted, replacing the Lee Metford, there was a carbine version, issued to the cavalry. The shortcomings of this weapon were highlighted in the Boer War, when it was outclassedby the Mausers used by the Boers. As a result of this the Short Magazine Lee Enfield rifle was introduced in 1903. This was a shortened version of the Long Lee Enfield, intended for use by both infantry and cavalry. This, of course, proved to be probably the finest bolt action rifle adopted by any army. 1
Kingsman Posted May 22, 2014 Posted May 22, 2014 Lanchester would be my bet, used extensively if not exclusively by RN. A 9mm SMG is much more useful up close & personal with a Schnellboot than any rifle. Probably stowed without magazines fitted. 34rd mags are long so would need weapons to be spaced well apart, or would protrude too far into wheelhouse, if fitted. That means magazine rack or box (more likely) nearby. How to make one? in 1/72 scale differences will be minute. I have no idea what weapons are available in that scale. Use Lee-Enfield as a basis if you can get one, but any rifle will probably do. Cut down stock, add barrel shroud from rod. Or a piece of 0.30" Browning barrel. Cooling holes invisible in that scale. Small microstrip block for magazine housing. That housing was solid brass, not painted. Rest of metalwork blued or black painted. You could graft a MkIII Sten with a Lee-Enfield stock if you can get these. However, I imagine there would have been a canvas cover over the rack to keep the salt spray off the weapons or it may even have been a locker. So perhaps those are the easy options. 1
rickshaw Posted June 1, 2014 Posted June 1, 2014 No.5's were used by the RN and RAN in the Far East during the Malaysian Emergency.
