adilson Posted July 25, 2014 Author Share Posted July 25, 2014 Much work to be done in the next days about 1200 pieces were created in scrat Bye.... 1 Link to comment Share on other sites More sharing options...
xffw45343tg Posted July 25, 2014 Share Posted July 25, 2014 Wow! To take an engine out, the fuselage is first set horizontally for wing removal, then a further 1.5 degrees so the engine is level. The front nozzles usually remain attached to the airframe (there are short sleeves connecting them to the engine which are removed) whereas the rear nozzles must be removed, along with the water tank which is normally squeezed in between the bulkhead and the "elephant's bum" duct at the aft of the engine. The change unit would normally be supplied bare - i.e. without the Gts/apu and main generator which are taken from the outgoing unit. Ancillary drive pads, intake, exhausts etc come fitted with red covers. You have built a spare engine, right? Keep up the tremendous work, the end is in sight!! Kirk 1 Link to comment Share on other sites More sharing options...
Scooby Posted July 26, 2014 Share Posted July 26, 2014 Wow, just totally amazing! 1 Link to comment Share on other sites More sharing options...
snapper_city Posted July 26, 2014 Share Posted July 26, 2014 Oh my, What a build. 1 Link to comment Share on other sites More sharing options...
Guilherme Kosciuv Posted August 6, 2014 Share Posted August 6, 2014 (edited) We are waiting you at superkits to talk about this kit with Bonfim. Edited August 6, 2014 by Guilherme Kosciuv 1 Link to comment Share on other sites More sharing options...
Val Posted August 6, 2014 Share Posted August 6, 2014 WOW! Super build! Top work! 1 Link to comment Share on other sites More sharing options...
adilson Posted August 6, 2014 Author Share Posted August 6, 2014 We are waiting you at superkits to talk about this kit with Bonfim. Great....Please I need to talk to him. Saturday I went to the club but it was closed. Link to comment Share on other sites More sharing options...
xffw45343tg Posted December 14, 2014 Share Posted December 14, 2014 Are we nearly there yet? Link to comment Share on other sites More sharing options...
HOUSTON Posted December 16, 2014 Share Posted December 16, 2014 AMAZING work Link to comment Share on other sites More sharing options...
adilson Posted February 9, 2016 Author Share Posted February 9, 2016 Sorry to all the time away, I will update the fotos They are five years and is not yet ready, I will update all my topics. Hugs... 2 Link to comment Share on other sites More sharing options...
youngtiger1 Posted February 9, 2016 Share Posted February 9, 2016 Wow, that looks pretty cool. All you need know is some Marine ground crew around it and it'll be complete 1 Link to comment Share on other sites More sharing options...
adilson Posted February 9, 2016 Author Share Posted February 9, 2016 Wow, that looks pretty cool. All you need know is some Marine ground crew around it and it'll be complete They are being hired 1 Link to comment Share on other sites More sharing options...
youngtiger1 Posted February 9, 2016 Share Posted February 9, 2016 good one... 1 Link to comment Share on other sites More sharing options...
xffw45343tg Posted February 9, 2016 Share Posted February 9, 2016 Wow! What detail! Just for your interest rather than as a suggestion to change anything: The fuselage is jacket to horizontal prior to wing removal. The access panels forward of the wing are removed, including the longitudinal spine. There are 4 lifting points for the wing - the rears in the position you have shown them and the fronts are simlarly spaced. The lifting points correspond with the point of attachment of wing to fuselage. Once the wing is removed, the aft of the fuselage is jacked up again - iirc by 1.5 degrees to allow for the angle of the installed engine. The rear nozzles are removed but I believe the front ones are usually only disconnected from the flange on the engine plenum. The engine is attached via trunnions adjacent to the fire bulkhead and brackets aft of the rear nozzle flanges. Engine ancillaries are transferred over to the Engine Change Unit. Cheers! Kirk 1 Link to comment Share on other sites More sharing options...
adilson Posted February 9, 2016 Author Share Posted February 9, 2016 Wow! What detail! Just for your interest rather than as a suggestion to change anything: The fuselage is jacket to horizontal prior to wing removal. The access panels forward of the wing are removed, including the longitudinal spine. There are 4 lifting points for the wing - the rears in the position you have shown them and the fronts are simlarly spaced. The lifting points correspond with the point of attachment of wing to fuselage. Once the wing is removed, the aft of the fuselage is jacked up again - iirc by 1.5 degrees to allow for the angle of the installed engine. The rear nozzles are removed but I believe the front ones are usually only disconnected from the flange on the engine plenum. The engine is attached via trunnions adjacent to the fire bulkhead and brackets aft of the rear nozzle flanges. Engine ancillaries are transferred over to the Engine Change Unit. Cheers! Kirk thank´s my friend....Look how interesting this photo, Harrier wing removal, regarding the engine covers already adjusted the problem, thanks to divide the master knowledge. cheers... 1 Link to comment Share on other sites More sharing options...
Shaun Posted February 9, 2016 Share Posted February 9, 2016 What a cool idea, that model looks great in a dismantled state. Shaun. Link to comment Share on other sites More sharing options...
xffw45343tg Posted February 9, 2016 Share Posted February 9, 2016 Interesting pic. Never seen it done like that before. I'd imagine that this simplifies removal of the forward attachment bolts? With a bit of luck a proper expert will rock up and explain. Link to comment Share on other sites More sharing options...
MarcoUK78 Posted February 9, 2016 Share Posted February 9, 2016 Wow!!!! 1 Link to comment Share on other sites More sharing options...
