feoffee2 Posted April 29, 2014 Share Posted April 29, 2014 Does anyone know anything about an eastern express md11 Thanks Link to comment Share on other sites More sharing options...
Jessica Posted April 30, 2014 Share Posted April 30, 2014 Only rumours and wishful thinking. Link to comment Share on other sites More sharing options...
Jennings Heilig Posted April 30, 2014 Share Posted April 30, 2014 Everybody hold hands and chant... Link to comment Share on other sites More sharing options...
PMG Offramp Posted April 30, 2014 Share Posted April 30, 2014 It's supposedly planned right after the Tristar, sadly very vague information on Russian websites, not sure if it's still on track. If these 2 are the same quality as their Il-18, they'll be beauties ! PAS Resin also had one planned, not sure if it's still the case. Link to comment Share on other sites More sharing options...
feoffee2 Posted April 30, 2014 Author Share Posted April 30, 2014 It's supposedly planned right after the Tristar, sadly very vague information on Russian websites, not sure if it's still on track. If these 2 are the same quality as their Il-18, they'll be beauties ! PAS Resin also had one planned, not sure if it's still the case. Only rumours and wishful thinking. Everybody hold hands and chant... Thanks hope someone makes one because I don't really want to spend £50 on the welsh one but if I have to then I will but will hang on and see if anything materialises Link to comment Share on other sites More sharing options...
Team Aer Lingus Posted April 30, 2014 Share Posted April 30, 2014 I doubt the EE kit would be much cheaper than the Welsh one judging by the price of their woeful B777 on some retail/auction sites Link to comment Share on other sites More sharing options...
Skodadriver Posted April 30, 2014 Share Posted April 30, 2014 I doubt the EE kit would be much cheaper than the Welsh one judging by the price of their woeful B777 on some retail/auction sites Don't forget there are two different Welsh kits - all vacform at £41 or vacform/resin at £61. I built the very first version of the Welsh MD11(which was totally vacformed apart from the engine fronts) many years ago. Although it was a lot of hard work it made up into a very nice model which really captured the character of the real aircraft and I simply can't imagine EE getting it so right. Sanding the wings for a big vacform is never fun and if I build it again, which is entirely possible, I think I'll probably save up for the one with the resin wings. Link to comment Share on other sites More sharing options...
feoffee2 Posted April 30, 2014 Author Share Posted April 30, 2014 Don't forget there are two different Welsh kits - all vacform at £41 or vacform/resin at £61. I built the very first version of the Welsh MD11(which was totally vacformed apart from the engine fronts) many years ago. Although it was a lot of hard work it made up into a very nice model which really captured the character of the real aircraft and I simply can't imagine EE getting it so right. Sanding the wings for a big vacform is never fun and if I build it again, which is entirely possible, I think I'll probably save up for the one with the resin wings. I doubt the EE kit would be much cheaper than the Welsh one judging by the price of their woeful B777 on some retail/auction sites Thanks might just get the welsh one Link to comment Share on other sites More sharing options...
Timo Posted May 1, 2014 Share Posted May 1, 2014 I don't normally do vacform kits, but the Welsh MD11 kit is good – see pic of my Lufthansa Cargo build as evidence. If you do decide to get a Welsh kit, I would recommend getting the version with resin wings and elevator. While its more expensive, it makes the build a lot simpler. Only tip is that fixing resin wings to the vacform fuselage needs some reinforcing to prevent flexing – I used brass tubing through the fuselage with the ends extending about 20mm into each wing. Its rock solid. Hope this helps Tim Link to comment Share on other sites More sharing options...
feoffee2 Posted May 1, 2014 Author Share Posted May 1, 2014 I don't normally do vacform kits, but the Welsh MD11 kit is good see pic of my Lufthansa Cargo build as evidence. If you do decide to get a Welsh kit, I would recommend getting the version with resin wings and elevator. While its more expensive, it makes the build a lot simpler. Only tip is that fixing resin wings to the vacform fuselage needs some reinforcing to prevent flexing I used brass tubing through the fuselage with the ends extending about 20mm into each wing. Its rock solid. Hope this helps Tim Thanks I think I would get the more expensive one Link to comment Share on other sites More sharing options...
Artmaul Posted February 1, 2017 Share Posted February 1, 2017 I just received my EE 1/144 MD-11 kit, it's much better than what I've expected! So no need for a vac kit anymore, yay! Link to comment Share on other sites More sharing options...
