RNoAF Aerobatic Team Posted April 16, 2014 Share Posted April 16, 2014 Keep up the good work! ! 1 Link to comment Share on other sites More sharing options...
Arniec Posted April 17, 2014 Author Share Posted April 17, 2014 Again some pictures of work done today. Here are two pictures of the exhaust area. the first picture is after the first sanding and the second one to riffil it again with mr surfacer, because it wasn't enough the first time. I have also been looking at the placement of the stabilisors. They were without modification hanging down and not at the right angel to the fuselage. 2 pictures of the insert I placed from some plastic rod. And here is a picture after the glue hase cured and I could drill it out a bit to get the stabilisor to fit. As you can see there is not much left of the rod, but that tinnie bit is enough. Here are two pictures of the stabilizor testfitted. And here is the fuselage with the stabilisors, wing and rudders fitted for a test fit. That is more the look of it. I have also done the first thing on the cockpit. But that is still to early to get some pictures. Cheers and a happy easter weekend to everybody, 2 Link to comment Share on other sites More sharing options...
Giorgio N Posted April 17, 2014 Share Posted April 17, 2014 Thanks for the Easter wishes, I guess that this long weekend will be used by many here to build kits for the various Britmodeller group builds... Starting to look like a Tomcat now, I like the many small and not so small improvements you're making on this model 1 Link to comment Share on other sites More sharing options...
Arniec Posted April 18, 2014 Author Share Posted April 18, 2014 Thanxs Giorgio for the nice comment. I have just done a little bit today. I have finaly finished the exhaust cans by again a sanding session. Now they are given a coat of paint to se if they are now correct. We will have a look tonight after I get home from work. No pictures of this, but you guys must be alread tierd of my pictures. Further nothing done, because I have got no time today. Hopefully I can do some work this weekend. Cheers, Link to comment Share on other sites More sharing options...
Andrew Posted April 18, 2014 Share Posted April 18, 2014 Great progress in recent times, Arnold. I like your improvement to the stabilator mounts and your work overall. It's looking very Tomcat-like and I'm sure you'll be keen to get painting underway; I'm certainly keen to see how it develops. Regards, Andrew. 1 Link to comment Share on other sites More sharing options...
Arniec Posted April 21, 2014 Author Share Posted April 21, 2014 The progress in the build hase slowed down a bit. I have been bussy today with the cockpit. Mostly to get it to fit inside the fuselage. I am getting there in the end. After that it will be to paint the cockpit. The most difficult part of this is that there are no instructions to say you what you need to remove from the fuselage. No foto's that are worth the build. Hopefully later on this week. Cheers, Link to comment Share on other sites More sharing options...
DaveJL Posted April 21, 2014 Share Posted April 21, 2014 The progress in the build hase slowed down a bit. I have been bussy today with the cockpit. Mostly to get it to fit inside the fuselage. I am getting there in the end. After that it will be to paint the cockpit. The most difficult part of this is that there are no instructions to say you what you need to remove from the fuselage. No foto's that are worth the build. Hopefully later on this week. Cheers, To get the aires pit to fit nicely, you need to remove the 'bumps' that protrude into the cockpit area from the boarding steps. Also shave back the sills at the sides of the cockpit, along with chopping down part of the cannon bay. You'll also need to trim back the small lip around the area where the pilots control panel coaming fits. Lastly, sand down the roof of the front landing gear bay as far as you dare! A good bit of work unfortunately! 1 Link to comment Share on other sites More sharing options...
Dermo245 Posted April 21, 2014 Share Posted April 21, 2014 Coming along nicely... Dermot 1 Link to comment Share on other sites More sharing options...
Arniec Posted April 21, 2014 Author Share Posted April 21, 2014 (edited) To get the aires pit to fit nicely, you need to remove the 'bumps' that protrude into the cockpit area from the boarding steps. Also shave back the sills at the sides of the cockpit, along with chopping down part of the cannon bay. You'll also need to trim back the small lip around the area where the pilots control panel coaming fits. Lastly, sand down the roof of the front landing gear bay as far as you dare! A good bit of work unfortunately!Luckely I have done already most of what you discribed. With a lot of dry fitting I am getting there. The right side is ok. I only need to do a few tweaks on the left and then she will be ready for some paint.Cheers, Edited April 21, 2014 by Arniec Link to comment Share on other sites More sharing options...
DaveJL Posted April 22, 2014 Share Posted April 22, 2014 Luckely I have done already most of what you discribed. With a lot of dry fitting I am getting there. The right side is ok. I only need to do a few tweaks on the left and then she will be ready for some paint. Cheers, It is an absolute pain to get to fit, a lot of work, but well worth it! 1 Link to comment Share on other sites More sharing options...
Arniec Posted April 26, 2014 Author Share Posted April 26, 2014 I will do some more work on it next week. I lost a little bit of my mojo with the cockpit. Link to comment Share on other sites More sharing options...
Arniec Posted May 10, 2014 Author Share Posted May 10, 2014 (edited) After a few weeks of doing nothing on this model, I have finally managed to do some more work on here. The cockpit fits now and I have made some changes to get a better fit later on in the build. Here are some pictures of what hase been done. the testfit of the cockpit inside the two fuselage halfs. There is still a gap in the front, but that is filled now with a piece of plastic. Here are the two front fuselages modified with removing of the plastic wall where it will fit to the back fuselage. To get a good fit in the end I also put some plastic tabs inside the back fuselage. Here are two pictures of the testfit of this and I am quite pleased with it. I will do some more work on it this week. It will be mostly to get the cockpit ready for some painting and after that I can give it a lick of paint. Cheers, Edited May 10, 2014 by Arniec 2 Link to comment Share on other sites More sharing options...
Arniec Posted May 14, 2014 Author Share Posted May 14, 2014 I have started to paint the cockpit yesterday with the interior colour. Today I have started to do some detail painting. I hope I can finish the painting this weekend. I have also given the exhausts their first coat of paint. I have no foto's jet. Cheers, Link to comment Share on other sites More sharing options...
Giorgio N Posted May 15, 2014 Share Posted May 15, 2014 Looking forward to seeing the painted cockpit ! Link to comment Share on other sites More sharing options...
Arniec Posted May 15, 2014 Author Share Posted May 15, 2014 Hi Guys and Giorgio , Here are some pictures of the cockpit sofar. I still need to do some more detailpainting and glue the etch parts on it. And also some painting was done on the Exhausts. I have painted them with a few different types of metal colour. That is it for today. Hope to do some more work tomorrow. Cheers, 1 Link to comment Share on other sites More sharing options...
RNoAF Aerobatic Team Posted May 15, 2014 Share Posted May 15, 2014 Looks brilliant! Working on 1/1 scale kitchen the next week or two or so.... 1 Link to comment Share on other sites More sharing options...
Jabba Posted May 15, 2014 Share Posted May 15, 2014 I have been a bit behind looking at this one. There has been a lot of work already gone into this especially the cockpit. Keep up the progress of this project. 1 Link to comment Share on other sites More sharing options...
Arniec Posted May 16, 2014 Author Share Posted May 16, 2014 Thanxs guys. I have finished the cockpit today. After some last detail painting and a little bit of oil wash. If you have watched more closely you will notice that the seats are missing. I will do these later on in the build. Here are some pictures of the cockpit. And here are two pictures with the 2 stations put on the tub. I hope to close the front fuselage this weekend and put it on the rest of the model. Cheers, Link to comment Share on other sites More sharing options...
Jabba Posted May 16, 2014 Share Posted May 16, 2014 Very nice. 1 Link to comment Share on other sites More sharing options...
DannyB Posted May 16, 2014 Share Posted May 16, 2014 Wow, awesome work on the cockpit! 1 Link to comment Share on other sites More sharing options...
Arniec Posted May 28, 2014 Author Share Posted May 28, 2014 Well it hase taken me some longer time to close the front and put it to the rear fuselage. But it is finaly done and the seam is not to bad in my opinion. Here are two pictures. the upside seam. I still need to do a little clean up here. And the underside. I used a small piece of scrap plastic as a tap to line the underplate better up with the rest of the fuselage. This now only needs a bit of Mr Surfacer 500 to blend it in. After this I will place the nose cone and then she is prepared for some paint. I still need to clean up the wings etc. so it will still take me some time before I can power up the compressor. Cheers, 1 Link to comment Share on other sites More sharing options...
Tom Cooper Posted June 6, 2014 Share Posted June 6, 2014 Perhaps I've missed the related post but, did you cut the bay for the IFR-probe open? No IIAF/IRIAF F-14 is authenic if that bay is 'closed', i.e. if the doors for it are in their place... Link to comment Share on other sites More sharing options...
Tom Cooper Posted June 6, 2014 Share Posted June 6, 2014 Before I forget... here something to consider: a new camo pattern applied on the only IRIAF F-14AM after her overhaul and upgrades: http://www.uskowioniran.com/2014/04/combat-aircraft-of-iran-military-day.html Link to comment Share on other sites More sharing options...
Arniec Posted June 9, 2014 Author Share Posted June 9, 2014 Thanxs Tom for the details. I already new it about the IFR probe. I am going to make a early version just after they were in Iran, so the IFR probe still hase his hatch. Here are also a few pictures of the progress. The nose is on and the exhausts are on. Cheers, Link to comment Share on other sites More sharing options...
Tom Cooper Posted June 9, 2014 Share Posted June 9, 2014 Sorry to bother: but there was no 'early version'. IFR-probe bay covers were removed already before delivery, i.e. in the USA. Reason: the 'Iron Maiden' IFR-baskets of USAF KC-135s (used to help deliver/transfer Iranian F-14s to Iran) tended to damage these doors: in some cases, the door would be ripped away and ingested into the engine, causing catastrophic damage. For the same reason, even the USN was removing these doors whenever cooperating with USAF tankers (USN tankers use 'soft' baskets). The photo here was taken in January 1976, and is showing the first two F-14As (serials 3-6001 and 3-6002) minutes after their landing at Khatami AB (TFB.8, meanwhile renamed to Baba'ie AB) after their delivery flight from the USA. As can be seen, covers were removed already before that flight. Surely, all the 80 doors were eventually delivered to Iran, but have been stored ever since: they were never put to use because Beech 1080 IFR-pods used by Boeing 747-131Fs and Boeing 707-3J9Cs of the Iranian air force had the same 'Iron Maiden' baskets like USAF examples. Link to comment Share on other sites More sharing options...
