A significant anniversary build of Senna's mp4/4
A tribute to one of the best drivers
to have been in F1
This i a tribute build to commemorate the day that possibly the best driver on the planet died doing what he loved, and in my opinion it was the best way (in a weird way) for him to go and it is ofcourse Ayrton Senna.
It was 20 years ago on May 1st 2014 that the three time world champion lost his life doing probably one of the things he truely loved, racing the fastest cars against the fastest drivers in the world, but on that faitful day in northern italy on the 7th lap of the San Marino GP Senna lost control of his williams fw16 and collided with the barriers at tamburello, this was by no means the first time he had crashed in his career but for some reason on that day a suspension part had broke off and hit him giving him injuries that he would not recover from.
Now beings that i was only 4 when all this happened i was unaware of most of it untill i got older and looked it up for myself and looked into the man that he was and from then i have been hooked on everything Senna so with all the tricks and tips i have picked up along the way from fellow Bmers i am this year going to try and modify the tamiya mclaren mp4-4 into the Japanese GP verion that Senna won his first title in here is where i started and just a quick sorry for first the long intro and also the amount of photos.
I am planning to finish?unveil this build on the 1/5/14
The box:
And now the peices that will be involved in making this a (hopefully) great replica:
Now the Senna figure i made a while ago:
And now where i am up to with the build:
these parts here C4 will be used to modify the turbo intake to the Japan spec
like so
Along with that the intake holes on the body need to be filled
And the radiator outlets changed
A peice of plasticard was used to make up the gap from where the outlet should be to where it is now
This is where i am up to as of last night on the body but i have been cracking on with the floor pan and monocoque
Thank you very much for looking and i hope that i can get it done on time
Cheers shaun
Edited by ferrari_boy12
The second instalment:
Things have progressed a little quicker than anticipated but im calling that being overly organised so here goes
So the first thing is the steering wheel
And the dash.
The engine as of this morning.
This is a mock up of the engine and floor pan from last night.
Basic mock up of all major bits under the body.
This pic really shows the effect of the carbon decals (which were a pain in the a**e to work with).
One of the radiators,
And another one.
One of the wheel.
This is of the little opening on the top surface of the body thats been filled by putting a thin bit of plasticard underneath the cutting some more to glue into the gap and filling the rest.
And the new side outlets with a shorter section at the front of it.
Then a real quick mock up of how thefigure will sit in just to make sure i have the heights right.
Oh and just one final pic to highlight the difference between the painted and the carboned on the rear uprights.
And just to mention again that these carbon decals are great but they are a real pain to get to conform properly, at the moment my method is dip it in warm to hot water then micro sol and leave until its soft then add heat and try to get it down with a damp cue tip, it works fine but it took me over an hour to figure it out on the floor which is flat.
Any way thanks for looking and all comments welcome.
Cheers Shaun
Just a quick update
I got the cowl peices that go within the rear suspension sprayed and then figured out where a couple of (what i thought were) spare decals go so they have been done once they were dry
All the uprights have now been decaled and clear coated and are ready to go on the car soon
The rear wing endplates have been sprayed and clear coated, i just need to do the decals on the inner surface and polish them up abit
The monocoque has been worked on slightly
Also in this next pic the main body cowl has been primed and had its coat of white done and just dry fitted most parts to see how it looks
And last of the build so far is the brakes, i did think of getting the brake set for this but sence came over me and said they will never get seen so i chose not to but they will have a few mods to them, mainly on the rears but nothing major
Just a quick thing to add all the marlboro orange/red parts have all been sprayed white first so that they will all match what is on the main body of he car and last nite i found that the orange/red is extremly delicate and think that it must have a rather long curing time as it has been for or 5 days and they still can have finger prints kind of melted into them, which isnt that big a deal as they polish out quite quick but its a pain in the butt
Anyway thanks for looking
Just a quick uupdate for now
The monocoque is now glued to the floor and there is there also
now for the same again with a few more bits done
and again as of today
now the main body has been painted and is due for a light polish tonight then the orange/red will go on tommorrow
and the endplates for the front wing have been done they just need the carbon decal on them then there ready
and the rear endplates are almost finished
and last is the roll over hoop
thanks for looking and comment are welcome
cheers Shaun
A little update from today
thanks Simon I thought as it is a milestone year since he past then I should do something nice
right on with the show
I Manage to get the body polished before i mask it for the red
And i got the carbon decals on the front enplates (The top has micro sol on, bottom Is done)
and the one on the under side of the main plane of the rear wing
And the big parts have been fiddled with a bit
And last is the little radiator Bits at the top have had a bit of purple put on
Thanks for looking
Shaun
thank you and to be honest about this car there are a few bits that make you tear your hair out but overall it's a really nice and easy kit with lots you can do to make it your own with loads of extras out there to get depending on how you want it, as I have said previously that I have tried to modify it to my best ability to look like the end of season car but truth be told it would look just as good straight out of the box
cheers shaun
A little update but its for a big step in the build
the body has been masked and had its first couple of red coats on
and this is how it turned out
Im really happy with how its come out and now its just a wait of probably a week or so until a clear coat and a polish
cheers for looking and any and all comments are welcome
shaun
A little bit more from today, I got really anal and did a little bit of wiring mainly just the bits that will get seen a lot
it is a little hard to see as the colours but in real life they are quite noticeable
and mrvr6 i know what you mean it seems mad to say that the last year senna won the title it was the same year i was born
cheers shaun
Thanks guys for the comments and mark that's good to hear I was watching your build of the 99t and then it just stopped, not happy lol
any way i found this today and thought it would belong even though its not a model
i dont know the artists name but it was all drawn by hand but I think with the significance of this build it earns a place on here
cheers shaun
A small update today
the wheels and tyres are done
and the brake lines that go over the calipers ( the small metal hoop) was made from bending soilder wire over the fat end of my pin vice
the little fia cap, i honestly dont know what it does but im guessing it was policing something important
and all the little gubins on top of the gearbox are on now
and last is the little gold cap on the (again not sure what it is) air distributer
and just as things were going well i messed up the white parts of the rear wing i over sprayed the clear and its eaten a decal slightly
any way cheers for looking and hopefully tomorrow goes better
shaun
Turbocharger blow-off valve, limited manifold boost pressure. This was supplied by the FIA to all teams to ensure they were all operating at the same max boost.
Thanks that would make sense dave, I thought it may have something to do with the turbo boost as they were limited to 2.5 bar but I didn't want to say it was just incase I was wrong as I thought with the turbos being quite low in the car that all those mandatory bits would be down there with them either way I've learnt something new today
cheers shaun
nice job on the cf decals. i hate them with a vengeance, but they make such a difference. i tried the spraying through a piece of netting trick and it was passable on small parts but looked pants on bigger ones. keep it going , im loving this.
I know what you mean with the carbons they took so much work just to get to conform to most parts and then on one of the parts they micro blistered
heres a small update from today
the rear wing endplate is done
and a quick mock up of the rear wing (not glued)
and the front endplates just need a quick gloss and polish
and a real quick one of the wheels which have been sanded to simulate a worn look and the bottom tyre has been flat gloss coated over the decal on the sidewall
and these are my modified turbo inlets
and from the top, the off side one hasn't been fitted yet
Now for the dash which still needs a little doing but as you can see the steering wheel is missing as i cut it off and drilled into the back off it to make it removable
Last just a really quick dry fit of the body and car just to make sure that i havent messed up anywhere
and this is what my new radiator outlets look like
thank you for looking
cheers shaun
A small but major update
I had to alter/redo the offside turbo inlet
and the big bit i started the decaling of the main body
and i finished it too
and this is the new side outlets the are quite close to the original
not a great comparison as to the different angles but you get the idea
cheers shaun
