Kilo Tango Posted March 10, 2014 Share Posted March 10, 2014 Good evening all, I been following the forums for a while now and I gathered was about time to join. This started to bug me as a project since I got hold of the Olympic airways decals in 1/72. I have not found a decent Comet kit in 1/72 and the available vacform I would not even consider after I had a close look at one second hand. So I started with the next nearest thing the Nimrod. After I managed to put my hands on one eventually, I started the chopping and filling. Progress is slow since I have only time to work a few hours on it at weekend, this is two weekends worth of chopping, filling, sanding, chopping, filling, sanding................. So from this... I will arrive at this...... Hopefully. Thanks for looking, Kostas 12 Link to comment Share on other sites More sharing options...
Mozzy19 Posted March 10, 2014 Share Posted March 10, 2014 Good lord! That's quite an ambitious project. But looking good so far. Sean Link to comment Share on other sites More sharing options...
Dave Fleming Posted March 10, 2014 Share Posted March 10, 2014 Ambitious, but I've seen it done. Don't forget the 4B had a longer forward fuselage than the 4 or Nimrod Link to comment Share on other sites More sharing options...
robvulcan Posted March 10, 2014 Share Posted March 10, 2014 WOW your brave. I have often wondered if this could be achieved. Good luck and I am watching . Link to comment Share on other sites More sharing options...
Norman Posted March 10, 2014 Share Posted March 10, 2014 Perhaps a silly question ''Why has no aftermarket company ever issued a conversion to do this ?'' And another if i may ''Why have we no decent injection moulded kits in 1/72 of the Comet family ?'' Cheers all Link to comment Share on other sites More sharing options...
stringbag Posted March 10, 2014 Share Posted March 10, 2014 This should be very interesting. Good luck with it Kostas Link to comment Share on other sites More sharing options...
DanSAR95 Posted March 10, 2014 Share Posted March 10, 2014 Good luck, an enormous amount of work needed here. Now you've got to hurry and get it done as we're all eager to see it. Once again, good luck. Link to comment Share on other sites More sharing options...
bigbadbadge Posted March 10, 2014 Share Posted March 10, 2014 Wow good luck on your quest, can't wait to see the finished article. All the bestChris Link to comment Share on other sites More sharing options...
canberra kid Posted March 10, 2014 Share Posted March 10, 2014 Fantastic, I'll be watching closely,I'd love to do the same. John Link to comment Share on other sites More sharing options...
woody37 Posted March 10, 2014 Share Posted March 10, 2014 Welcome to Britmodeller That's quite a task you're undertaking, it's fair to say you have our attention!!!!!!! I'd love a decent 1/72 comet kit as I'm not as mad, nor skillful as you! Link to comment Share on other sites More sharing options...
Kilo Tango Posted March 10, 2014 Author Share Posted March 10, 2014 Ambitious, but I've seen it done. Don't forget the 4B had a longer forward fuselage than the 4 or Nimrod Thank you very much for the comments, I will work on it next weekend again, work commitments. Dave I downloaded 3d views of both and uploaded them in Autocad, any idea of the lengths involved? Can't make heads or tails, in 1/72 the comet4b scales at 0.499mm the Nimrod at 0.536mm if you discard the bulges and mad antenna length is missing maybe 20mm? or thereabouts? Link to comment Share on other sites More sharing options...
bzn20 Posted March 10, 2014 Share Posted March 10, 2014 (edited) The Nimrod was built from the 4c, 4b longer fuse and the 4's bigger wing . Not sure if that helps or not given the difference between the 4c's donor fuse and the added MAD and nose extension 34 Vs the Nim's 38.65 M I nearly forgot....That's some conversion there, looking forward to the rest! Edited March 10, 2014 by bzn20 Link to comment Share on other sites More sharing options...
dambuster Posted March 10, 2014 Share Posted March 10, 2014 Had the same idea once but I couldnt find a good enough scale plan of a Comet to get the nose contours right. However, I've now dug out some references but also splashed out on the vacform you mention, and at some stage will probably look at doing a hybrid from the two kits. Peter 4 Link to comment Share on other sites More sharing options...
bzn20 Posted March 10, 2014 Share Posted March 10, 2014 Looking at your stalled kit. It reminded me of the AEW Nimrod at laying forlorn on the airfield at RAF Abingdon 1991/92. Now there is a thought! Link to comment Share on other sites More sharing options...
Dave Fleming Posted March 10, 2014 Share Posted March 10, 2014 They shortened the Nimrod fuselage by 6 feet from the 4C. The 4 was 111 feet and the 4B and 4C were 118 feet long. 1 Link to comment Share on other sites More sharing options...
Kilo Tango Posted March 11, 2014 Author Share Posted March 11, 2014 Peter, the vacform needs scraping, my honest opinion about it, a lot of hit and miss with it, the diameter of the fuselage does not match, is wider than the Nimrod kit. The wings are half an inch thick at the engine part. The lenght of the two fuselage halfs is not the same...... But your work looks good to me, keep with it David is then 22mm, thanks for the conformation, small ring section to be added in the long list lol Link to comment Share on other sites More sharing options...
perdu Posted March 11, 2014 Share Posted March 11, 2014 I love this kind of modelling and you have made a magnificent beginning with it I'm along for the ride Kostas Link to comment Share on other sites More sharing options...
TempestV Posted March 11, 2014 Share Posted March 11, 2014 I will enjoy watching this!!! Link to comment Share on other sites More sharing options...
Max Headroom Posted March 11, 2014 Share Posted March 11, 2014 Kostas That's one heck of an intro! Good luck and keep taking the headache pills....... Trevor the impressed Link to comment Share on other sites More sharing options...
John_W Posted March 11, 2014 Share Posted March 11, 2014 Nice work. Interesting to se the conversion going backwards. I remember seeing a conversion the other way - Airfix 1/144 Comet to Nimrod with a lot of balsa and filler. 1 Link to comment Share on other sites More sharing options...
garryrussell Posted March 16, 2014 Share Posted March 16, 2014 :hmmm:What is the AIM series like?? They seem to cover all the marks. Lengthwise the nimrod was shortened back to 4 length which was 111 feet six inches. Of course the Nimrod would be longer due to the nose, but the Comet section should be the same as the 4. It's the engine nacelles that seem daunting to me...similar or the same on top but very different underneath. Link to comment Share on other sites More sharing options...
Kilo Tango Posted March 16, 2014 Author Share Posted March 16, 2014 (edited) Evening all, thanks for the comments and support , finished the work on the right wing http://s27.postimg.cc/40dl7fhxf/IMG_3155.jpghttp://s27.postimg.cc/lp5bz1toj/IMG_3156.jpg Plug 25mm in length inserted and made a pigs ear of it,rather than mark and cut, yep I just cut, needless to say that the cut was not straight and nearly cut myself a few times http://s11.postimg.cc/x94qro63n/IMG_3157.jpg Then started on the underside eventually, took about 4 attempts The front end it was a bit easier than the chaos I started with in the rear Next weekend to be continued, be well!!! Edited March 16, 2014 by Kilo Tango 3 Link to comment Share on other sites More sharing options...
Max Headroom Posted March 16, 2014 Share Posted March 16, 2014 You deserve a prize for this! Trevor 1 Link to comment Share on other sites More sharing options...
BritJet Posted March 16, 2014 Share Posted March 16, 2014 Peter, the vacform needs scraping, my honest opinion about it, a lot of hit and miss with it, the diameter of the fuselage does not match, is wider than the Nimrod kit. The wings are half an inch thick at the engine part. The lenght of the two fuselage halfs is not the same...... But your work looks good to me, keep with it David is then 22mm, thanks for the conformation, small ring section to be added in the long list lol AIM did the Comet 4B a very long time ago and everything you say about it is correct! That kit was withdrawn many years ago due to the errors and the kits now available are completely unrelated to the old kit. If the kit you have includes BEA 'Red Square' decals, then that is the old kit. Steve 1 Link to comment Share on other sites More sharing options...
robvulcan Posted March 19, 2014 Share Posted March 19, 2014 This really is coming along very nicely. Your making it look easy. Then I guess were most of us would look at it and think. HMM its possible but a lot of work and then shy away. You have just gone for it and got stuck in with desire to get the job done. Its brilliant. Nothing better than seeing it truly being butchered into submission and Its really looking more comet than nimrod now. Great stuff keep up the good work Link to comment Share on other sites More sharing options...
