Will Vale Posted May 16, 2014 Share Posted May 16, 2014 Very cool, I keep looking at this kit on the shelf of my local shop. Also I love builds with little helpers, they add so much life. Will Link to comment Share on other sites More sharing options...
Pete in Lincs Posted May 16, 2014 Share Posted May 16, 2014 That door frame edging. it's probably meant to be a rubber seal. Make the opening slightly bigger than you need. Cut a thin strip of plastic card. Round off one side, Glue it into the opening, Rounded side out. For the tight corner curves, Lightly score across the strip and it will confrom to the frame. Once dry you can sand the inside edge level with the door frame. Link to comment Share on other sites More sharing options...
griffsrw Posted May 16, 2014 Share Posted May 16, 2014 great fun. they look a bit pale too me, do they work nights ? Link to comment Share on other sites More sharing options...
Gobs of Espresso Posted May 16, 2014 Author Share Posted May 16, 2014 That door frame edging. it's probably meant to be a rubber seal. Make the opening slightly bigger than you need. Cut a thin strip of plastic card. Round off one side, Glue it into the opening, Rounded side out. For the tight corner curves, Lightly score across the strip and it will confrom to the frame. Once dry you can sand the inside edge level with the door frame. That's perfect! Thanks! : ) Link to comment Share on other sites More sharing options...
Gobs of Espresso Posted May 16, 2014 Author Share Posted May 16, 2014 great fun. they look a bit pale too me, do they work nights ? Thanks! Yeah, they work only nights. part of me likes them as is but part of me knows I have to paint them at some point. Once they have faces, it will not be the same. now, things are pretty neutral that's because I am still chicken to paint. Link to comment Share on other sites More sharing options...
Gobs of Espresso Posted May 19, 2014 Author Share Posted May 19, 2014 a little more done..... purchased a knife pallet and some PE for the Airconditioning grill front and maybe back Masked and ready for putty Lastly.......a glimpse of the next project Thanks for viewing. Gobs Link to comment Share on other sites More sharing options...
Gobs of Espresso Posted May 19, 2014 Author Share Posted May 19, 2014 Very cool, I keep looking at this kit on the shelf of my local shop. Also I love builds with little helpers, they add so much life. Will Thanks Will! Link to comment Share on other sites More sharing options...
Gobs of Espresso Posted December 1, 2014 Author Share Posted December 1, 2014 (edited) First of all, I apologize to those who were following this Build. After having some warping issues and my asthma kicking in to high gear, I lost my mojo and decided to set aside all builds instead of starting a new one. Last post was in May and since then I found it easier to watch all your builds and discussions rather than rectify my kit. I promise to contribute my share even if I have to start a new kit when I am stuck or having a long wait for parts ordered. If my asthma kicks in again then I'll find a way around it. I have till Dec. 11 till i'm off for the holidays then I'm back Mid Jan. This is where I left off: A little warping left after much adjustments. I didn't know that the tamiya putty would shrink as much as it did and given the section it was applied to, it bent and bowed like the letter U. This after much on it. Setting the pieces befor the right door frame is glued And a little painting work done on the chasis... Thanks for viewing! Gobs Edited December 1, 2014 by Gobs of Espresso 2 Link to comment Share on other sites More sharing options...
Tom Hall Posted December 2, 2014 Share Posted December 2, 2014 The fellow sitting on the right looks shattered. (I do hope you are giving the help adequate breaks, pursuant to the labour laws....) Link to comment Share on other sites More sharing options...
shood23 Posted December 2, 2014 Share Posted December 2, 2014 Looking good i like the mods your making Shaun Link to comment Share on other sites More sharing options...
phildagreek Posted December 2, 2014 Share Posted December 2, 2014 Glad you're back. Link to comment Share on other sites More sharing options...
RMP2 Posted December 2, 2014 Share Posted December 2, 2014 Such good fun and an oddball vehicle too. Many, many years ago I used to leave my Lego men doing stuff to finish spaceships while I went to school. Lazy buggers them Lego men, good to see your guys are better motivated. Link to comment Share on other sites More sharing options...
Pete in Lincs Posted December 3, 2014 Share Posted December 3, 2014 Welcome back. Looking forward to more. Link to comment Share on other sites More sharing options...
Gobs of Espresso Posted December 5, 2014 Author Share Posted December 5, 2014 The fellow sitting on the right looks shattered. (I do hope you are giving the help adequate breaks, pursuant to the labour laws....) Sadly, they are running the show, not me. They work when they want to and boss me around. I am the victim here : ( Looking good i like the mods your making Shaun Thanks Shaun! Glad you're back. Thanks Phil! Such good fun and an oddball vehicle too. Many, many years ago I used to leave my Lego men doing stuff to finish spaceships while I went to school. Lazy buggers them Lego men, good to see your guys are better motivated. Thanks! They are quite lazy at times but not more than me. : ) Welcome back. Looking forward to more. Thanks Pete! I'm quite slow but I am enjoying this build and can't wait to finish it so I can put a stop to finding new ways to tweek it. Link to comment Share on other sites More sharing options...
Gobs of Espresso Posted December 5, 2014 Author Share Posted December 5, 2014 Since this will take time, I decided to post simutanious builds which I am trying now to keep me moving and motivated. It is unusual since I like starting and finishing something before moving on but this make take a while. More to come.... Link to comment Share on other sites More sharing options...
arni Posted December 7, 2014 Share Posted December 7, 2014 A tip for next time,try using car body filler as it does not shrink and sets within minutes. Link to comment Share on other sites More sharing options...
