More updates!
Fuselage and wings where put together and primed with AK Interactive's gray primer.
Some clumsy pre-shading followed... I need to improve my airbrush control. Still, getting better at it...
Also did the prop...
Now for the fun part....
The fuselage-wings assembly and the separate control surfaces were painted with a mix close to what Tamiya was suggesting. The base colour was lightened with a bit of white, in two or three steps, and each time some spot-painting was done, to add some variety. The bottom is a gray-ish white with lots of gray and white spots and streaks.
I was lucky enough that my airbrush handling betrayed me only on parts that are hidden by decals etc.
And some different lighting...
Now the next bit required a bit of thought, trials on an old model and lots of courage, as it felt like a risky task. I wanted to do some heaving paint chipping on the wing roots. However, I wanted to show the bare metal and the zinc `primer'.
My original plan was to do some paint chipping with Vallejo's medium - however I felt I could not control the pre-shadingn that way. Instead... I chose to use some sponge to do the zinc spots and brush-paint some Humbrol 11 on top of that. Good thinning of the paint is essential. I think I will need to do some sanding in some points as the paint was a bit thick.
The primer...
And the bare metal
I am reasonably happy with the outcome. Some more chipping here and there to follow, before I apply some gloss coats, decals and some oils.
Thank you for watching!
Aloha,
A few more updates...
While I was waiting for the fuselage to dry up properly I finished the prop (needs a mat varnish in the pic below)
Chipping was done with a little sponge and a silver pencil for some finer streaks:
I have then started working on the walkways. I could not determine why Tamiya has not included those or they are not referenced. Maybe some planes did not have them? I decided to do them anyway, as it is another excuse for some weathering.
The outer markers where masked and painted black:
The outcome, including some added weathering on the upper surfaces:
Next is the main walkways... more in a few days.
Next step was to spray a couple of layers of clear (Pledge) and apply the decals. The model's panel lines where highlighted with oils - a combination of Black and Industrial Earth from the 502 Abteilung oils which are excellent.
The control surfaces where highlighted with oils (Light Mud).
More weathering to follow...
Edited by Crowbar
Indeed, its been too long... Since I started this I became a dad and now I am about to switch jobs and move near Chester. So I expect more delays :P
But... for the time being I am having fun!
I wanted to soften the colours on the underside, so I used oils to add some streaks etc. Will add more, once I get around ordering some colours I am missing.
More updates, before another break for moving houses....
I decided to experiment with oils, to enhance the look of different surfaces and plates. Using a couple of colours I added streaks and faded paint spots, toned-down decals etc. Pastels where used for the smoke stains.
Edited by Crowbar
I don't know how I missed this build 'til now, perhaps because it was started so long ago. You have turned one of Tamiya's best 1/48 kits into a masterpiece. I especially like what you did with the cockpit, and the weathering, with some fuel staines on the upper cowling it will be perfect.
John
Thank you for the kind words. Indeed, it was started long ago. But I have to admit, it has been lots of fun.
There will be a little pause, again, as I am moving in a few days. Will pick it up in a couple of weeks!
I am trying to figure a nice way to do the spider-like spill in-front of the cockpit.
Panos
  • 4 weeks later...
Hello all,
I am back at this, after some time for moving to a new house. Seems that in the move I managed to loose one of the most important pieces of the kit. The canopy...
I do have the second piece (without the bulge) and I am trying to see which is the correct option for Dangerous Dan.
The only image I have/know of the airplane is:
I can not really make it out, however I figured more knowledgeable modelers may be able to understand from the mirror configuration.
Any ideas?
Btw, Supercale and Tamiya indicate a flat-top canopy - not that their illustrations are necessarily accurate...
Edited by Crowbar
Shameless bump - any ideas? I can not get any convincing reference for the time and I am tempted to continue with the build and leave the canopy business last - and possibly use flat-top just to complete the project.
  • 4 weeks later...
