nickymaude 3 Posted February 13, 2014 Share Posted February 13, 2014 i thought its about time i tackled my amt enterprise d, which has been sat on my shelf for about 2 years, im going to be doing it lit, now i have a small minicraft drill for the windows, i just wanted to ask whats the right sized drill bit to use? Thanks. Link to post Share on other sites
Caerbannog 2,594 Posted February 13, 2014 Share Posted February 13, 2014 OMG - the windows for the D are not round but oblong - so you will have to drill 4-5 holes per window and cut them straight at the long sides with a scalpel. It makes sense to thin the plastic from the backside with a Dremel as well. This procedure grants for hours and hours of modelling fun. Frankly I would approach this completely different: Sell your AMT Enterprise D and get the Round2 version which is basically the same as the AMT kit but is using clear styrene... So just paint your Enterprise (fist white, then black to reflect/shield off the light and then the ship colours) and srape away the paint from the windows you want to have lit (or use maskol or the like). Rene Link to post Share on other sites
bigh827 20 Posted February 14, 2014 Share Posted February 14, 2014 He has a point, the new moldings are clear so that you can light the windows with out all that work. It's the same kit you have only molded in clear. You have had yours for 2 years, I bought mine in 1998 after coming back from German, US ARMY, and have yet to start it. Link to post Share on other sites
chadders 73 Posted February 15, 2014 Share Posted February 15, 2014 I was going to drill the windows in mine, then I noticed they were oblong. I took the easy route and just bought window decals, sod lighting them!! Link to post Share on other sites
celticwardog 69 Posted February 5, 2015 Share Posted February 5, 2015 Yes drilling out windows what fun. But I must add....given how rare and expensive the clear one is, and actually how long it would take to mask them anyway....is it really less work?! Link to post Share on other sites
Stu_davros 398 Posted February 5, 2015 Share Posted February 5, 2015 I drilled the windows on the first D I built about twenty years ago, I drilled 4 or 5 holes and then dragged the drill through the remaining plastic to connect them. I don't recall the drill size I used, but I remember breaking several bits in the process. Cheers, Stuart Link to post Share on other sites
celticwardog 69 Posted February 5, 2015 Share Posted February 5, 2015 Yes I remember doing the same thing, only issue is to watch for heat build up so it doesn't melt them too big. Daft this is the fibre optic version never looked right, a tiny spot of light in the a long window?! I'm doing a Voyager now, same thing but less windows and they are quite a lot bigger. Wondering if I can find a suitable micro file to keep them square (they are on that one) Link to post Share on other sites
