Miggers Posted February 8, 2014 Share Posted February 8, 2014 I'm sure you knew this, but anyway; there was quite a bit of coverage, and indeed footage, of Bill Humble's career as Hawker's test pilot in an episode of the genealogy show Who Do You Think You Are, dealing with his daughter, BBC wildlife presenter Kate Humble..... Stunning workmanship on that, btw........ Bill was actually Kate's grandfather....... Anyway,that F2/43 is the Mother and Father of all F2/43/Fury/Sea Fury models Pete,that's not art, it's not skill,it's model engineering and construction at it's most fabulous,she's a beauty. Link to comment Share on other sites More sharing options...
airscale Posted February 10, 2014 Author Share Posted February 10, 2014 thanks everyone .. I find your comments inspire me to do more, and better so thank you.. ..still edging towards the finish - sorted out a few more bits & bobs... ..I got a little more done on getting the cowl panels sorted out - the real aircraft has quite distinctive staining on the inside face of the panels where they closely cowl the cylinder heads - it's a sort of diamond shape.....I tried making a mask from tape and adding some strip spacers at the back, but this didn't really work, so I cut it from thin card... also added some stencilling......bad pic, but here is a shot of the home mix being sprayed on.....seemed to work out ok....then really abused them.....and dry fit to check how it looks... ..then masked up the walkways on the wings.... ..and weathered them by chipping the edges with a blade and then using wet micro mesh to just ease some of the rivet detail through the paint... ..also masked up the interior of the canopy and gave it a blast... ..still needs cleaning & detailing, but getting there... ..lastly masked out the part of the fuselage spine that is under the canopy, up to and including the canvas sealing strip... ..need to clean some of the dirt wash off, but again with some gentle 'stressing' it is starting to look used & dusty... ...and all of it together... ..still more to do, so she is not done yet TTFN Peter 8 Link to comment Share on other sites More sharing options...
Ex-FAAWAFU Posted February 10, 2014 Share Posted February 10, 2014 Oh my! That's just beautiful, subtle work. Link to comment Share on other sites More sharing options...
jimbojones Posted February 11, 2014 Share Posted February 11, 2014 Can I ask what tool are you using to make the rivits ? Link to comment Share on other sites More sharing options...
Troy Smith Posted February 11, 2014 Share Posted February 11, 2014 HI Peter great work, and very useful seeing all the detail. How long does this all take? What thicknesses of brass sheet are you using? If you want a next project there is the Sabre Fury that was this plane's sister, which I think had a blue stripe. A Beautiful Aircraft, Beautifully captured. So, Same again in 1/72nd? Why couldn't the kit be this good in the first place though? Pete Pete in Riyahd It exists, but is a Japanese resin kit, that was $85 when available http://modelingmadness.com/review/korean/cleaver/tmc72sf.htm this is the 1/72nd Aki kit cheers T Link to comment Share on other sites More sharing options...
airscale Posted February 11, 2014 Author Share Posted February 11, 2014 thanks for stopping by chaps Can I ask what tool are you using to make the rivits ? Hi Jim - it's Radu's Rivet R set from RB Productions - the method I use is to get a good mr surfacer primer layer to scribe & add rivet details to - it is far, far easier & cleaner than doing it to bare plastic How long does this all take? What thicknesses of brass sheet are you using? If you want a next project there is the Sabre Fury that was this plane's sister, which I think had a blue stripe. cheers T Hi Troy - this build started in July 2012 so it's got about 18 months into it (I am a cheapskate so one £29.99 kit will do me for years..), as for the brass, I did a tutorial on it here - it's between 0.01 & 0.05mm K&S shim As for the next project, I have started an HpH Hornet, though I love British aircraft so can see me coming back to big Hawkers sometime I saw an amazing Sea Fury on the contest tables at Telford, all opened up - I can't remember if it was 1/72 or 1/48 but may have been from that resin kit TTFN Peter 2 Link to comment Share on other sites More sharing options...
Devilfish Posted February 12, 2014 Share Posted February 12, 2014 I have just 3 words.....Mast a Piece!!! Link to comment Share on other sites More sharing options...
Nobby57 Posted February 12, 2014 Share Posted February 12, 2014 To quote my father after he had a, rather long, look at your work, "This laddie certainly knows what he's doing with a model aeroplane" Inspired him to tell a few stories from way back in the day and that's from a man who seldom talks about such things. Now that says something... I know what my father would have said...he was on HMS Glory for her entire Korean engagement. I think this is a two dimensional master-class and I can't think of any superlative...it's just so brilliant! 2 Link to comment Share on other sites More sharing options...
Tomjw Posted February 12, 2014 Share Posted February 12, 2014 This is a work of art. Absolutely stunning. Cheers, Tom. Link to comment Share on other sites More sharing options...
Troffa Posted February 12, 2014 Share Posted February 12, 2014 Ridiculously good skills, an inspirational build! Link to comment Share on other sites More sharing options...
jckspratt1 Posted February 12, 2014 Share Posted February 12, 2014 What everybody else said! Amazing work. Link to comment Share on other sites More sharing options...
Steviej Posted February 12, 2014 Share Posted February 12, 2014 wow she`s a beaut, love her Link to comment Share on other sites More sharing options...
Caution Wake Turbulence Posted February 12, 2014 Share Posted February 12, 2014 Every so often on Britmodeller, you click on a fairly innocuous looking thread, only to be confronted by the most amazing display of jaw-droppingly amazing craftsmanship. This is certainly one of those moments! Inspirational work, indeed. Andrew Link to comment Share on other sites More sharing options...
airscale Posted February 13, 2014 Author Share Posted February 13, 2014 thank you chaps well, today the undercarriage went on, so now it sits on it's gear and dares me to finish it... ..first I got the alignment right - they are canted outwards by 5 degrees and this was allowed for when I fitted the mounts a while back - I used a bit of tube to get things lined up.. ..I also fitted the small ancilliary door and made up the actuator arm... ..then used 15 min epoxy to get the wheels on, giving time for them to settle on their flat spots and get the vertical & forward alignment right... ..and she has legs... ..on the last lap now, the biggest job remaining is to make the u/c actuator arms and fit them to the legs & jacks - after that, it's just details hopefully.... TTFNPeter 7 Link to comment Share on other sites More sharing options...
Spikelhund Posted February 13, 2014 Share Posted February 13, 2014 Peter my chin hurts from smacking the floor every time I tune into one of your updates . Brilliant work, I'll almost be sorry when it's finished and all over. Cheers.... 1 Link to comment Share on other sites More sharing options...
PinkPanzer Posted February 14, 2014 Share Posted February 14, 2014 ...couldnt write earlier cause trying to pick my jaw from the floor.....Just awesome,my trully congrats mate! 1 Link to comment Share on other sites More sharing options...
PZRGREN Posted February 14, 2014 Share Posted February 14, 2014 Beautiful build and finish, a real work of art!! Roger. Link to comment Share on other sites More sharing options...
TheStig Posted February 14, 2014 Share Posted February 14, 2014 Unbelievable!! Awesome work! Link to comment Share on other sites More sharing options...
Sarcococca Posted February 15, 2014 Share Posted February 15, 2014 Wow!!! Can`t find the right words! That is high dexterity! So many amzing crisp details! I like a lot all the lil details and of course the finish. Great great job! Link to comment Share on other sites More sharing options...
airscale Posted March 15, 2014 Author Share Posted March 15, 2014 evening folks.. it's been a while so I thought I had better drop in with a little update.. ..this is more about what remains to be done, rather than what has been done, although small progress has been made. I have been distractingly busy in the real world lately - so trying to add the finishing touches and get G-AKRY into the RFI section ..got the U/C doors finished and have part built the jacks to mount them.. ..added some rather crass weathering (hey, I am still learning..) but then looking at the original the streaking is a bit dirty & random so I guess it passes.. ....also this is where the gear doors will mount.. ..added the oil streaks found on the gear doors - I really need to master the 'Haggo' way of doing things.. ..I need to add the rudder - it's finished but I keep knocking it off! so for now it is one of those final placement things.. ..have also worked out the cowl panel mounts - can't really see it here, but when fitted the hinge points and retaining cable all fit in this space.. ..I carelessly dipped the canopy in hot water to widen it for a better fit...... it turned white in my hands and a significant nervous breakdown was only avoided by re-dipping in future (miracle juice..) which thankfully restored clarity.... that said, there is a nasty kink in the lower frame now so I need to re-skin it.. ...so, after all that the old girl is not quite finished, but then there is not far to go now, and I know what I need to do... ..onwards & upwards.. ..I just need to avoid natural distractions like working on airscale's next little sojourn into 1/24 aftermarket modelling heaven... ..who would have thought we would have a Tiffie to play with TTFN Peter 6 Link to comment Share on other sites More sharing options...
Nobby57 Posted March 15, 2014 Share Posted March 15, 2014 Whoa...I feel for you Peter. It does look ugly, but just a minor, if nerve wrenching, setback. Look forward to her completion...won't be long now I'm sure. As to the Tiffy...hmmm, I know what you mean by distraction...I fear I'm going to blow a hole in my car savings; now that is a distraction! All the best, Nobby57 Link to comment Share on other sites More sharing options...
Alan Kelley Posted March 15, 2014 Share Posted March 15, 2014 Peter- this is a stunning build. Fantastic. Link to comment Share on other sites More sharing options...
blueliner Posted March 15, 2014 Share Posted March 15, 2014 Peter, There just aren't enough words... Stunning is inadequate to describe the level of detail. As my dad's friend used to say, "Great googley moogley!" Link to comment Share on other sites More sharing options...
Col. Posted March 15, 2014 Share Posted March 15, 2014 Have missed your updates Peter so glad to see you are still making progress with this one. Link to comment Share on other sites More sharing options...
Simon Cornes Posted March 15, 2014 Share Posted March 15, 2014 First time I've seen this thread. Wow!!...........I may as well give up, no way could I get anywhere near this standard, and I thought I was reasonable!! Thank God its not a 1/72nd model, I have to remind myself its 'only' 1.48th! You couldn't possibly do more in larger scales, it has got to be the ultimate in miniaturisation. In this world there must only be a handful of people who can produce such wonderful work. Thank you for sharing it with us, we are certainly not worthy!!! Simon Link to comment Share on other sites More sharing options...
