SaintsPhil 666 Posted February 3, 2014 Share Posted February 3, 2014 Good Morning BMers, I don't normally build models with spiny bits on the front, but I've been asked to build a Hurricane and I'm after some decent (accurate) scale plans, I really need the shell ejection ports under the wings. Anyone suggest a good source for these? Many thanks Phil Link to post Share on other sites
Giorgio N 9,084 Posted February 3, 2014 Share Posted February 3, 2014 (edited) From what I've heard here, Arthur Bentley's plans are the best around for the type. Edited February 3, 2014 by Giorgio N 1 Link to post Share on other sites
SaintsPhil 666 Posted February 3, 2014 Author Share Posted February 3, 2014 From what I've heard here, Arthur Bentley's plans are the best around for the type. Thanks Giorgio, I did see those, the price put me off though. I'm sure they're worth it but I'd never use them again! I wondered if there was a book with some accurate ones in that I could get second hand at a sensible price.... Link to post Share on other sites
Giorgio N 9,084 Posted February 3, 2014 Share Posted February 3, 2014 (edited) 1/48 plans from the same author were included in the November 2005 issue of Model Aircraft Monthly, you might be able to find this from the publisher or on E-bay Edited: IIRC the plans were for the Hurricane I Edited February 3, 2014 by Giorgio N Link to post Share on other sites
SaintsPhil 666 Posted February 3, 2014 Author Share Posted February 3, 2014 1/48 plans from the same author were included in the November 2005 issue of Model Aircraft Monthly, you might be able to find this from the publisher or on E-bay Edited: IIRC the plans were for the Hurricane I That might be a good source! Thanks Link to post Share on other sites
MDriskill 576 Posted February 3, 2014 Share Posted February 3, 2014 If it makes a difference to your project, Mr. Bentley's plans (which are indeed utterly amazing IMHO), if I'm not mistaken, cover only the Mk I Hurricane. IIRC there is a scrap view of a Sea Hurricane Mk IC wing, however, showing the access panel and ejection port arrangement of the 4-cannon wing as later fitted to the Mk II. Link to post Share on other sites
Sean_M 256 Posted February 3, 2014 Share Posted February 3, 2014 I know Arthur personally. I got all his Hurricane planes. They are worth it Phil I am a sort of in a stalled process of writing a book on building the Hurricane in 1/48 amd 1/32 scale. Maybe its just an excuse to have over 15 Hurricane kits. I helped Arthur update his site and I now believe that you can order and pay on line. http://www.albentley-drawings.com/drawings/hawker-hurricane-mk-i/hawker-hurricane-mk-ii/ What Kit are you using? PM if you need any more help Link to post Share on other sites
chuckb1 197 Posted February 3, 2014 Share Posted February 3, 2014 My treasured plans from the 80's Bentley all the way for me. Link to post Share on other sites
viscount806x 474 Posted February 3, 2014 Share Posted February 3, 2014 1/48 plans from the same author were included in the November 2005 issue of Model Aircraft Monthly, you might be able to find this from the publisher or on E-bay Edited: IIRC the plans were for the Hurricane I Didn't they appear in an old Scale Models mag from the early 1980's also? Link to post Share on other sites
chuckb1 197 Posted February 3, 2014 Share Posted February 3, 2014 Yes also there was a re print of the series in 1990 I have both plus the Wing Span commemorative big three BoB sett. Link to post Share on other sites
SaintsPhil 666 Posted February 4, 2014 Author Share Posted February 4, 2014 Thanks everyone, think I've tracked some down now! Link to post Share on other sites
MDriskill 576 Posted February 5, 2014 Share Posted February 5, 2014 (edited) Didn't they appear in an old Scale Models mag from the early 1980's also?Yes, they were first published in Scale Models in 1/72 scale in the August, September, and October 1980 issues. There was an excellent accompanying article by Mr. Bentley describing how the drawings were done and some interesting quirks of the aircraft's shape. I believe the set was also available through the MAP Plans Service back in the day. As noted above, the 1/48 version is in the November 2005 Model Aircraft Monthly. The only ancient dog-eared magazines I guard more zealously are Mr. Bentley's Fw 190A/F/G drawings (Scale Models; May, June, July, and August 1978), LOL...! Edited February 5, 2014 by MDriskill Link to post Share on other sites
Troy Smith 8,781 Posted February 5, 2014 Share Posted February 5, 2014 Yes, they were first published in Scale Models in 1/72 scale in the August, September, and October 1980 issues. There was an excellent accompanying article by Mr. Bentley describing how the drawings were done and some interesting quirks of the aircraft's shape. I believe the set was also available through the MAP Plans Service back in the day. As noted above, the 1/48 version is in the November 2005 Model Aircraft Monthly. The only ancient dog-eared magazines I guard more zealously are Mr. Bentley's Fw 190A/F/G drawings (Scale Models; May, June, July, and August 1978), LOL...! here's a scan of the article, I posted this here before, but I find threads [and therefore info] can easily get 'lost' here ....easy enough to find if you know it's there, not so easy if you don't.... Anyway, here's the background to the Bentley plans, and why they are considered the best. Link to post Share on other sites
Edgar 915 Posted February 5, 2014 Share Posted February 5, 2014 Don't use the 1980s Bentley drawings, since he's amended them, as a result of Peter Cooke's researches; those published in Scale Aviation Modeller, in 2005, are (or should be) the corrected set. 1 Link to post Share on other sites
Sean_M 256 Posted May 14, 2014 Share Posted May 14, 2014 Order direct from Arthur Link to post Share on other sites
