Sign in to follow this
Speedman
Zvezda 1/100 KV-1 & KV-2 - Completed.
Build 1 & 2
Because the only difference in the kits are the turrets, I'm combining two builds into one thread. I know I've already built them in the photos, but don't worry, that's just to show that they're meant to be snap together kits. There's still a lot of work to do even if the part count is quite low =D
Price: £2.99 each from Antics.
Edited by Speedman
All the parts have been cleaned up and I've cut down the moulded in tow shackles so I can add my own made out of wire. Both turrets are now glued and filled with Mr. Surfacer.
Shackles added front and rear as well as the hull machine guns. I cut off the plastic rungs on the KV-2 turret and replaced them with copper wire.
Primed and ready for painting :) I've drilled out the KV-1's barrel and drilled view holes in the periscopes.
Edited by Speedman
I pre-shaded them today, followed by a few coats of a custom green. After post shading I gave them a few coats of Humbrol Clear. I should be able to get some washes done tomorrow.
I found some decals for the KV-2 and painted the slogan on the KV-1, after that I got the first couple of washes are done.
