exdraken Posted November 10, 2015 Author Share Posted November 10, 2015 Never thought I'd use the word pleasant in relation to a 'Hind' but that's the only way I can describe that scheme. Nice work. pleasant good description! thanks for the kind words, Col! 1 Link to comment Share on other sites More sharing options...
igormk Posted November 11, 2015 Share Posted November 11, 2015 Great project exdraken! I am expecially fascinated by your courage to band the rear fuselage according to helicopter's original offset. Regarding the main rotor blades color, all Mi-24 have green rotor blades on the upper side. But have in mind that the bottom side of the blades is black and not green. Regards, Igor 1 Link to comment Share on other sites More sharing options...
exdraken Posted November 11, 2015 Author Share Posted November 11, 2015 Regarding the main rotor blades color, all Mi-24 have green rotor blades on the upper side. But have in mind that the bottom side of the blades is black and not green. Regards, Igor thanks.. hard to find decent photos of the underside of the rotorblade... mine are green for now another discovery when looking at the nice 1/72 Zwezda AT-6 / 9k114 Schturm anti tank missiles in another thread I noted that Revell's missiles are bare any detail and about 5mm too short... would live missiles have a breakable cover or would the launching tubes be open? most photos on the net show static show loads.... Link to comment Share on other sites More sharing options...
igormk Posted November 21, 2015 Share Posted November 21, 2015 (edited) Hi exdraken, I was quite busy last days, but finally I managed to dig some photos where you can see rotor blades from the underside. I hope it is not too late to make the correction of the color. Regarding the AT-6 missiles, yes their tubes have breakable covers, so the pictures you see on the net are the actual ones. On the static displays often you might find only the tubes without the missiles so those would be without covers. Here is one picture from 4+ publication for the reference. You can also find a lot of videos of Russian Hinds in Syria like this one HERE . These are definitely not on static display… If you are willing to invest more in this model (time and money) you can consider buying Cobra Company weapon set for Mi-24 (LINK). I think it is the best you can find on the market in 1/48. Or do some scratchbuilding . Regards, Igor Edited November 21, 2015 by igormk 2 Link to comment Share on other sites More sharing options...
exdraken Posted November 21, 2015 Author Share Posted November 21, 2015 (edited) Hi Igor, you are of course not too late, as I already took the advice with the black undersides very seriously and re-painted them thanks a lot for the photos, I could not find any that showed the black that clear! detail painting still required... some earlier pics with better lightning: I did also work on the external stores cmk tanks seem a bit skinny..wheels are nice, rocket pods needed some drilling work, additionally the tubes looked a bit strange (kind of bend out) rotor head links also needed some shortening of the blade mounts AT-6s/ 9k114 Schturm: thanks for the video, these are definitely live ones I was not sure with the 4+ pic... and my takeon the AT-6s (the longer ones on the photo, the shorter, open ones are kit parts) sprues filed to correct diameter (slightly more than the kit) and hollowed out/ contoured front with a dremel and a knife... Cobra Company parts are really hard to get in Europe... so unfortunately not really an option cheers! Edited November 21, 2015 by exdraken 2 Link to comment Share on other sites More sharing options...
exdraken Posted December 1, 2015 Author Share Posted December 1, 2015 green topside, black underside I think I have to adjust the main landing gear a bit... the HInd sits a bit too high and straight! cheers, Werner 9 Link to comment Share on other sites More sharing options...
igormk Posted December 5, 2015 Share Posted December 5, 2015 Great job! Now the rotor blades look like they should. Main landing gear on Revell Monogram kit definitely need some rework. If you leave it like this it looks like the helicopter is about to lift off any moment. You can find many references of how close to the ground the fuselage is IRL. According to the manual, clearance of the helicopter (the lowest point) is 0,32m on the optical sighting mechanism for ATGMs (nose section, right side). If you need precise data, I can make measurements on the real helicopter between the fuselage and the ground on 5-6 points, so you can make the correction. Cheers! 1 Link to comment Share on other sites More sharing options...
IGKent Posted December 5, 2015 Share Posted December 5, 2015 Good result exdraken!On this chopper should be installed five formation lights. Two on the wings and three on the tail boom. Link to comment Share on other sites More sharing options...
IGKent Posted December 5, 2015 Share Posted December 5, 2015 So it looks.... http://data4.primeportal.net/hangar/david_lueck/mi-24e/images/mi-24e_015_of_121.jpg 2 Link to comment Share on other sites More sharing options...
IGKent Posted December 7, 2015 Share Posted December 7, 2015 This is rocket pod B8V20-A...... http://i.flamber.ru/files/st1/1211922554/1252005181_o.jpg Link to comment Share on other sites More sharing options...
exdraken Posted December 15, 2015 Author Share Posted December 15, 2015 thanks Igor! very welcome!, decals are on: I shortened the main landing gear legs by about 2mm at their mounting base, and took ~ 1mm out of the front landing gear piston tail rotor still needs some paint, main rotor-head same cables 9 Link to comment Share on other sites More sharing options...
dieselweasel Posted December 15, 2015 Share Posted December 15, 2015 I haven't attempted a helicopter yet, your build may just tempt to have a go at one, was it the Hind that was painted to look like an eagle or some such bird of prey, now that is one i Would build Really great build exdraken, whats next on the list. Regards Jim 1 Link to comment Share on other sites More sharing options...
exdraken Posted December 17, 2015 Author Share Posted December 17, 2015 (edited) I haven't attempted a helicopter yet, your build may just tempt to have a go at one, was it the Hind that was painted to look like an eagle or some such bird of prey, now that is one i Would build Really great build exdraken, whats next on the list. thanks Jim, seeing a Hind live (at an airshow I mean!) is a sight not be me missed.... worked on the tail rotor yesterday: the trailing edge of the tips needed to be sanded to shape, detail provided by the kit is quite good imho: Edited December 17, 2015 by exdraken 5 Link to comment Share on other sites More sharing options...
Wee Beastie Posted January 4, 2016 Share Posted January 4, 2016 Yours looks great, and the build thread has proved very informative Just started my own Hind build (Polish markings). 1 Link to comment Share on other sites More sharing options...
exdraken Posted February 14, 2016 Author Share Posted February 14, 2016 unfortunately, when removing the masks of the canopy (after more than a year...), some residue remained... BUT, the I remembered a tip by member Anil /azureglo in the today ending fantastic F-5 GB :) about using WD40 to remove residue without damaging the paintwork! thanks a alot! I just remembered today and applied the WD40 tip with a Q-tip on my Mi-24 cockpit glazing ! as it really needed it, and it worked like a dream! GBs are a dream! hope to show the finished Hind soon! 2 Link to comment Share on other sites More sharing options...
exdraken Posted February 15, 2016 Author Share Posted February 15, 2016 put some work in her yesterday and today... so close to being finshed! mainly antennae, stores, canopy work: some impressions: 9 Link to comment Share on other sites More sharing options...
exdraken Posted February 21, 2016 Author Share Posted February 21, 2016 just noticed that I did not yet mount the windscreen wipers....! but a fearsome looking 12mm 4 barrel gun.... and I was working a bit on the anti tank missiles : then: now: aftermarket guys, take note! I'spend money to get good ones! 4 Link to comment Share on other sites More sharing options...
exdraken Posted February 23, 2016 Author Share Posted February 23, 2016 woking on the characteristic, side mounted flare dispensers now: CMK resin ones modified to use them without the shroud ASO-2V: 1 Link to comment Share on other sites More sharing options...
exdraken Posted February 24, 2016 Author Share Posted February 24, 2016 and already mounted: 2 Link to comment Share on other sites More sharing options...
exdraken Posted March 28, 2016 Author Share Posted March 28, 2016 (edited) I guess it is finished... or will it ever be? for the time being at least it is angled/offset cockpit section/ rear fuselage: cheers, Werner Edited March 28, 2016 by exdraken 15 Link to comment Share on other sites More sharing options...
Parabat Posted May 2, 2016 Share Posted May 2, 2016 Awesome work, it looks amazing. Link to comment Share on other sites More sharing options...
exdraken Posted May 10, 2016 Author Share Posted May 10, 2016 Awesome work, it looks amazing. thanks! Link to comment Share on other sites More sharing options...
Air Hockey Propellers Posted August 27, 2016 Share Posted August 27, 2016 The Hind 24 is now in my list! Great job there! 1 Link to comment Share on other sites More sharing options...
71chally Posted August 27, 2016 Share Posted August 27, 2016 Superb build and excellent execution of the Hinds' fuselage 'lean' - this thread should serve as the definitive way to model the Monogram (and other kits) Hind. 1 Link to comment Share on other sites More sharing options...
Marlin Posted August 27, 2016 Share Posted August 27, 2016 Very beautiful Hind Werner /Bosse 1 Link to comment Share on other sites More sharing options...
