exdraken
Mi-24 /35 Hind E , Revell 1/48 - Czech Air Force: finished :)
on the fly again ;)
restarted (again) this fantastic and challenging model!
wings mounted, after cutting back my previous extension...
targeting device pods fit perfectly !
Werner, any reason you've gone for the short wings? I've got a CMK conversion for mine with those stub wings and I was going to extend them the same as you did to fit the 4P plans.
yes... I modified them to long version, fitted them, glued them and checked again with the 4+ plans ...
they were exactly my extension too long :( so I de-modified them again - superglue and a lot of it so hard razor saw work ;) sow they appear to fit the plans nicely.
I think that when I first modified them, perspective fooled me!
but that is quite some time ago... I am happy with the current look can't explain my former motivation now!
will try to make a photo showing the current fit to the 4+ plans
Edited by exdraken
Ignore this image then?
Hi, I know this photo,
if you look closely last time I mistook the outer missiles lauchers for the outer limit of the wing... that is wrong ~5mm on each side
here are some from this morning I took especially for you:
scaled up plans from +4
cheers! great you like it!
Good progress!
Where is PZU?
small update on the scratch building of the IR suppressor mount
some old landing gear bay cut up accordingly and filled with " perfect plastc putty"
sanding to shape is next ;)
Looks good!
Cut the pin which is located near IR jamming station "LIPA" It's incorrect....
Edited by IGKent
thanks!
incorrect in what respect? there is a pin , or more a wire antenna mount there... maybe it should be a bit further aft! what do you think?
Edited by exdraken
thanks!
I think I see now...
there are actually 2 of these antenna mounts, but not on the center, but to the left and right!
Edited by exdraken
some more work on the IR suppressor and some ECM equippemnt
(could really have bought the CMK set dedicated to the Revell kit...) ;)
lets go to the paintshop, no?!
some painting progress during the last month:
pre-shading
grey underside:
time/ labor intensive, hard edge 4 tone camouflage
green color, looks a bit grey here, but I hope with a clear cote it will look right!
Edited by exdraken
Good to see this one moving forward again :thumbsup:
yeah, finally some more work done!
the blue grey is a bit challenging....
too grey one time, too blue the other :(
had to paint it 3 times till ~ satisfied....
the engine exhaust soot is fought with a black area...
Czech Hind have green main rotor blades! you learn something new everyday!
here on Ruporator's resin blades:
masks off/
hope you like it as much as I do!
Never thought I'd use the word pleasant in relation to a 'Hind' but that's the only way I can describe that scheme. Nice work.
