Sebastien Posted February 2, 2014 Author Share Posted February 2, 2014 As cleaning isn't quite a favourite activity on mine, I've sculpted the back of the nacelle with Milliput: Note: when you mix Milliput, mix the right quantity. If you dont, it looks like this: Cheers, Sebastien 1 Link to comment Share on other sites More sharing options...
aidy Posted February 2, 2014 Share Posted February 2, 2014 That rework makes the Sanger nacelle look seriously under nourished. Are the nacelles identical for both sides? Link to comment Share on other sites More sharing options...
Sebastien Posted February 2, 2014 Author Share Posted February 2, 2014 That rework makes the Sanger nacelle look seriously under nourished. Are the nacelles identical for both sides? The engine part is identical on the four nacelles. I'd love the outer nacelles to be identical on both sides... Link to comment Share on other sites More sharing options...
Lars Befring Posted February 4, 2014 Share Posted February 4, 2014 Hi! I´ve been following your heroic battle with Sanger and you have inspired me to do this: http://www.ipmsstockholm.se/home/avro-shackleton-engine-in-3d-part-1-fact-finding/ The goal is to make a 3D model that is downloadable from our webpage and printer-ready. anything that can bring more Shackletons to the exibit tables! keep up the good work /L 1 Link to comment Share on other sites More sharing options...
HOUSTON Posted February 4, 2014 Share Posted February 4, 2014 Amazing work Sebastijan. Link to comment Share on other sites More sharing options...
Sebastien Posted February 7, 2014 Author Share Posted February 7, 2014 Thanks! I'm done with the shape. I think I'm not too far off the mark, and I'd like to have your opinion. I will separate the engine from the rear and scribe the details later on, before making a mold. Cheers, Sebastien 1 Link to comment Share on other sites More sharing options...
phildagreek Posted February 7, 2014 Share Posted February 7, 2014 If you put as much effort into the rest of the build as you have into this one component, it should be a pretty cool build! Link to comment Share on other sites More sharing options...
Sebastien Posted February 10, 2014 Author Share Posted February 10, 2014 Phil, I'll sure try! Slow weekend for both members of the Krazy Froggy Growler Group Build. We went both to modeling shows and didn't do much. My friend worked on the bomb bay. He wants to make a drop-in assembly he'll insert once the fuselage is closed. The doors so far: The bay itself: I worked on the inner engine nacelles. I separated them from the backing sheet (and as I worked sitting at a friend's stand in the model show, his clothes, a couple of models and various stuff are covered in white dust). The nacelles: Checking how things fit from above, and the first doubts are rising: From the side, the doubts vanished instantly, replaced by a certainty: So the nacelle does match the wing shape, but is 1 cm too short... More fun to come. Cheers, Sebastien Link to comment Share on other sites More sharing options...
tomprobert Posted February 10, 2014 Share Posted February 10, 2014 From the side, the doubts vanished instantly, replaced by a certainty: So the nacelle does match the wing shape, but is 1 cm too short... More fun to come. Cheers, Sebastien I remember that problem well - I built the rear of the nacelle up with plastic card and filler to raise the fairing to the correct height (ie level with the trailing edge of the wing.) I found that if you removed too much plastic from the rear part of the nacelle just in front of the rear fairing to correct the fit to the wing, the angle of the engine was far too far 'nose down' and the whole nacelle and engine had the wrong look. There should be a picture or two in my thread which you may find useful. The power-eggs look great by the way! Keep on slaving away, it'll be worth it in the end when you've got a kit in your collection that very few others have Tom Link to comment Share on other sites More sharing options...
Sebastien Posted February 10, 2014 Author Share Posted February 10, 2014 I remember that problem well - I built the rear of the nacelle up with plastic card and filler to raise the fairing to the correct height (ie level with the trailing edge of the wing.) [...] The power-eggs look great by the way! Thanks Tom. I intend to build up the rear with plastic card and filler. Great minds and all that stuff... And thanks again about the power egg. I'll work on it tonight, I hope I finish it then. Cheers, Sebastien Link to comment Share on other sites More sharing options...
Sebastien Posted February 12, 2014 Author Share Posted February 12, 2014 Hi, While I'm working on the inner engine nacelles, I'm wondering how the landing gear is made. I know it's much beefier than the gear on the Lancaster, but is it articulated in the same way? Can I use item 9 in the Tamiya Lanc instruction a a basis? Thanks for your advice, Regards, Sebastien Link to comment Share on other sites More sharing options...
tomprobert Posted February 12, 2014 Share Posted February 12, 2014 I used a set of Lancaster gear from an old kit I built years ago - I don't know if it's 'accurate' as such, but it looks good enough to me. I had to shorten it a little, but it goes in fine. The wheels are the main stumbling block - I'm sure you've realised that the kit items don't really resenble anything Shckleton-like. I used some Lancaster wheels which are fitted with different hubs - I'm always on the look out for some Paragon Lincoln hubs as they are the same as the Shackleton. Tom Link to comment Share on other sites More sharing options...
Mike Posted February 12, 2014 Share Posted February 12, 2014 An enjoyable thread made more so by your self-deprecating humour Sebastien Link to comment Share on other sites More sharing options...
Sebastien Posted February 12, 2014 Author Share Posted February 12, 2014 I used a set of Lancaster gear from an old kit I built years ago - I don't know if it's 'accurate' as such, but it looks good enough to me. I had to shorten it a little, but it goes in fine. The wheels are the main stumbling block - I'm sure you've realised that the kit items don't really resenble anything Shckleton-like. I used some Lancaster wheels which are fitted with different hubs - I'm always on the look out for some Paragon Lincoln hubs as they are the same as the Shackleton. Tom Hi Tom, I intend to use a Lancaster gear from SAC, and I have Paragon Lincoln wheels (the Sanger-provided wheels are... entertaining). Mike, I can't be that serious about modeling (and my modeling abilities). While I like working on vacs (even the tedious bits) and I work quite seriously on them, I have to find a way of entertaining the readers (and myself when I write stuff). And I love Terry Pratchett, Douglas Adams and Eddie Izzard, so... Regards, Sebastien Link to comment Share on other sites More sharing options...
perdu Posted February 12, 2014 Share Posted February 12, 2014 I remember this giving me some interesting moments thirty years ago I never used photography as a modelling tool back then but this is a crop and enlarge of the one I built then I recall using a product like Plastruct for the first time and built a beefier copy of the Lancaster type undercarriage based on the Lincoln in Cosford I think. If you have that lancaster one it would be easy to do using it as a template (I'll pull this if you like, just an idea of how it looks.) 1 Link to comment Share on other sites More sharing options...
Sebastien Posted February 12, 2014 Author Share Posted February 12, 2014 Thanks (and nice Shack, BTW). I think I'll use the beefy gear legs as provided by Sanger and adapt them to the triangles in the SAC set. Cheers, Sebastien 1 Link to comment Share on other sites More sharing options...
richw_82 Posted February 12, 2014 Share Posted February 12, 2014 Shackleton legs are shorter in length, and slightly more sturdy. The way the undercarriage is connected and mounted is identical to Lancaster. The Tamiya undercarriage bay would give you a very good start!Here's the Shackleton undercarriage from the manual: Regards,Rich Link to comment Share on other sites More sharing options...
Sebastien Posted February 12, 2014 Author Share Posted February 12, 2014 Thank you Rich! Sebastien Link to comment Share on other sites More sharing options...
Sebastien Posted February 12, 2014 Author Share Posted February 12, 2014 The first wheel well has been started. First step: where the heck will it be? Well, according to what I understood, it should be something like that: Let's remove what needs to be removed: I started with the outer wall: The outer wall in the wing: I intend to make a drop-in wheel well. I'll know soon enough if it is a bad idea. Cheers, Sebastien Link to comment Share on other sites More sharing options...
perdu Posted February 12, 2014 Share Posted February 12, 2014 Great beginnings, I think this is going to be fine. If mine has legs too long it's way too late to change it now, does it look reasonable Rich? Link to comment Share on other sites More sharing options...
richw_82 Posted February 12, 2014 Share Posted February 12, 2014 It looks fine Perdu! Its only really noticeable if you're a bit of a pedant. The easiest way of getting it right is looking at the angles of the 'K' bracing above the mainwheel.Here's the best shot I have of the full size example. Regards,Rich 2 Link to comment Share on other sites More sharing options...
Learstang Posted February 12, 2014 Share Posted February 12, 2014 Nice shot of the undercarriage, Rich! Our go-to guy when it comes to the MR.2. Nice to have that 1:1 model to work with. Regards, Jason Link to comment Share on other sites More sharing options...
perdu Posted February 12, 2014 Share Posted February 12, 2014 Ah that's a relief RichIt''s good news that you are here as well as Ph, I can stay current better that way I only have one more half decent pic of my made up u/c, where were you thirty years ago when I needed you? I cheated by painting the tread blocks and inventing a cockpit innards 1 Link to comment Share on other sites More sharing options...
Learstang Posted February 12, 2014 Share Posted February 12, 2014 I don't know, Bill; both the innards and the outtards look pretty good on that model! Regards, Jason 1 Link to comment Share on other sites More sharing options...
Troy Smith Posted February 13, 2014 Share Posted February 13, 2014 If I recall correctly the BoB flight Lancaster has, or did use the undercarriage for a Shackleton, presumably a lot easier to find airworthy parts, so there can't be that much difference if that's correct. And if it's cobblers my apologies. I used to have a good memory until I started dealing with children... Then I remembered the internet..... what did we do before wiki http://en.wikipedia.org/wiki/Avro_Lancaster_PA474 PA474 has the undercarriage of an Avro Lincoln and main tyres from an Avro Shackleton, both aircraft closely related to the Lancaster. However, original tail wheel tyres are no longer available and so a nose wheel tyre from an Airbus A340 has been substituted. Some marbles left at least. Oh...great work as well Sebastien.... you mention Paragon Lincoln wheels, does that mean you have a Paragon Lincoln conversion in the stash? cheers T Link to comment Share on other sites More sharing options...
