Misrule Posted February 19, 2014 Share Posted February 19, 2014 Seems most of the Gamilas ships don't have long gun barrels on their ships, just stubby turrets with only newer designs having proper full length cannons. Here's a vid of some random battle scenes, you can see the Dreadnought make its combat debut at 10:30 toward the end. Makes a good impression http://www.youtube.com/watch?v=rTJ-k2LRjM0 From the stats she mounts seven quad turrets, they look fairly small due to the bulk of the ship but work out as 490mm guns, plus a bunch of secondary weapons and missiles. Most of these alien ships tend to be pretty light on small calibre weapons, seems they favour missiles instead of flak guns. No word on if the flagship with the forked front will be out, but I think its likely. That ship does have a planet wrecking spinal cannon plus a few batteries of proper gun turrets. Really hoping it shows up Link to comment Share on other sites More sharing options...
Madhatter Posted February 23, 2014 Author Share Posted February 23, 2014 (edited) Hi allWell, I guess I wasn't as close to finishing as I thought. The base is turning into a model on it's own. Not opting for a simple stand and base, I have gone for something more interesting - well, hopefully.First up, I have found a good use for all those ship superstructure plates I have from all the ship models I have scavenged from. They make great buildings! A very rudimentary box to contain it all - with thanks to my son for the use of his puzzle box - that has no puzzle left:and a look at the very basic idea:Of course, the base needs defending, so I am attempting to scratch up some wicked looking guns. I'll add stuff to them to make them look bulkier and meaner.Everything is in its infant stage with so much more detail to add, but I thought I'd share what I have in mind.CheersMH Edited February 23, 2014 by Madhatter 1 Link to comment Share on other sites More sharing options...
Madhatter Posted February 25, 2014 Author Share Posted February 25, 2014 Greetings all I have started to detail the base now and it appears that what I have in my head will actually work. I have also slightly adjusted the base a little to include service tunnels - mostly to add more depth to the base. you can just see the added surface detail i have been adding to the channels. They'll be much more noticeable once they're painted and washed: and some plant machinery (well, the start anyway): This should make it so the buildings don't look so perpendicular to the edges of the base - well, at least distract the eye a little from the fact they are. I am also trialling something a little different for a light effect. If it works I'll post some pics Anyways, must be off, I still have plenty more to go. Thanks for looking Si 1 Link to comment Share on other sites More sharing options...
Madmonk Posted February 25, 2014 Share Posted February 25, 2014 Hi Si, That is great work on the base, looking at all those tiny pieces of plasticard in the trenches you must have fingers like needles not sausages like most of us!! Keep up the exceptional work. Cheers, Warren Link to comment Share on other sites More sharing options...
Madhatter Posted February 26, 2014 Author Share Posted February 26, 2014 Thanks mate Don't worry, I have fat fingers to, so I use a brand new blade to pick and place the pieces. Makes life so much easier Link to comment Share on other sites More sharing options...
Madhatter Posted March 3, 2014 Author Share Posted March 3, 2014 hi guysBeen slowly plodding away at this. I have scratched up my own guns to go on the base a defenses I have pretty much finished detailing the bit on the bottom of the base and have just started spraying the top plates of the base. Will try to finish detailing the buildings tonight and from there it's on the that last part of it all and that is putting it all togetherI've attached the carrier deck to the ship but I am still waiting to get the bridge section cast for me (I haven't seen the bloke who does it yet - been 2 months and a no show each time)I'll post some more pics of the base soonCheersMH Link to comment Share on other sites More sharing options...
Misrule Posted March 3, 2014 Share Posted March 3, 2014 Awesome looking sci-fi guns Link to comment Share on other sites More sharing options...
Will Vale Posted March 3, 2014 Share Posted March 3, 2014 The base is just great. Is the carrier going to be hovering above it, or sitting across the two pads, or something else? Link to comment Share on other sites More sharing options...
Madhatter Posted March 3, 2014 Author Share Posted March 3, 2014 thanks guys Yes, the carrier is going to be positioned up and over a huge mast like structure - almost like a refuelling mast (which hides the power cables). I've made it so I can just plug the carrier onto the mast and remove it when I transport it. I'm currently working on the mast itself, trying to detail it up some with pipes and such - anything to make it not look like a straight stick or pole I've also made a start on the painting of the base - so far so good. Once washed and weathered, I think it'll look alright. Fingers crossed Link to comment Share on other sites More sharing options...
Madhatter Posted March 10, 2014 Author Share Posted March 10, 2014 good evening allWell, it's update time, and here is where I am currently at.I have finished the first of the buildings and the guns are both painted. One of which is now attached to the first building. If these guns were real, man, they would be massive! But I think they look way cool none the less. I have also reduced the amount of fibers I had because it didn't look right and I thought it needed to be a bit more sparcely set out. Lighting pics later: I have started to do the second building now and so far so good. I changed the mast design I had originally to this much better looking one now. I found some 1/35 iron telegraph poles mae by Miniart and they were the perfect (well, almost - had to jig it a little) size to go over the inside pole which hides the power cables to the ship and holds the plug which it sits on. I think they look rather good, so I'm keeping it. I wanted an industrial look and I think I got it. I have also finished "the pit". I wanted it to look grimy and dirty - a start contrast to the plates on the top level that the buildings sit on. However, painting is not my strong suite, so I may not have done it too convincingly. Its the second time I have ever used MIG pigments (a good practice run for my upcoming BR52 build later on). Sorry for the slightly blurry picAnd Ii thought I would try something a little different here. I bent a 5mm Fiber Optic thread, painted the bottom silver, wrapped some very thin strips of masking tape around the thread, then over that sprayed black then Iron to try and achieve a sci-fi looking energy pipe. I hope you can see it. Once the final photos are taken it should. It's one of those things you may or may not see - depends if your looking for it I guess:And last but not least, the top plate. The blue service channels off set the metallic paint quite nicely I think: I will be adding more pipes and some other smaller structures to the plates as well - I just haven't got those parts yet. I have made my own pipes though that will feed from "the pit" to the mast. Don't ask me what function they would have 'coz I have no idea - Ii am just because I think it'll look coolWell, that's all for now. Need to finish off the second building. Once that's painted and dried, both buildings will be set onto the plates then onto the base. The ship itself is almost finished - just need to get that bloody bridge section cast and the guns painted then I can call it done!As always, if you have any feedback - good or bad - please feel free to postCheersMH 1 Link to comment Share on other sites More sharing options...
Pete in Lincs Posted March 10, 2014 Share Posted March 10, 2014 Epic! Link to comment Share on other sites More sharing options...
Madmonk Posted March 10, 2014 Share Posted March 10, 2014 +1 Link to comment Share on other sites More sharing options...
Misrule Posted March 15, 2014 Share Posted March 15, 2014 (edited) One of the Japanese hobby magazines showed up with some new background information on the ship, mostly what we already knew but still quite nice... The Chimera-type carrier (Gelvades class) Under the territorial expansion policy of Abelt Dessler’s regime, the active military branch of the Garmillas Empire not only increased the production of existing vessels, but also the competition between provincial planets to develop special prototype vessels. Among these, one of the newly-created vessels, called an Astro Battle Carrier, combines the characteristics of an aircraft carrier and a battleship, giving it the ability to conduct independent operations. Its main feature is to prepare for combat by inverting part of the flight deck. Although an open flight deck is established below the combat structure around the bridge, the front half serves as a gun deck that is exposed when the structure is flipped. Since the left/right turning range of the turrets is wider than the deck mechanism, they are kept in a stowed position when turning on the rotational axis. The openings in front of and behind the flight deck are closed by armored shutters when the guns are activated. The stern landing port is equipped with a bellows-type shutter like that seen on the rear hangar of the Meltoria-class astro battle cruiser. The ship has a complex structure with an angled deck on the starboard side and a main gun battery at the rear flight deck that must rotate in the 2 o’clock direction to clear the landing path. There are two layers of hangars inside the ship; aircraft are lifted to the flight deck by two large elevators located at both port and starboard. Various craft such as fighters, bombers, fast strike, and reconnaissance can be made available depending on strategy. Unlike the existing Gaiperon Class Astro Carrier, the Gelvades Class is suitable for long-term solo operations such as exploration of unknown territory, information gathering, or battle action like the breaking of enemy supply lines. However, its building costs are about double that of a conventional battleship, and the complexity of its construction process limits its production, so only a few have been deployed. And a bit on the multi deckers... The birth of the multi-deck astro carrier Among the combat vessels that make up the Garmillas Empire astro fleet, carriers are used for military operations that make use of aircraft. As the front continually grows under the expansion policies of Abelt Dessler, the specifications of carriers also repeatedly evolve at any given time. This resulted in a series of multi-deck carriers called the Guipellon class. These ships more than reflect demands from the front to allow deployment of several different models of aircraft equipped for a variety of strategies, and the distinctive feature of the Guipellon class is the division of four layers: top deck (first), upper deck (second), central deck (third), and lower deck (fourth). The first model to be built (Shuderg) had unidirectional decks, but the second (Lambea) was equipped with an angled deck. A later model (Balgray) had the forward edges of its deck reconfigured with mountain-shaped extensions for additional sensor equipment. At the time this model was designed, it seems to have been assumed that it would use the angled deck variation, so the radar tower on the central port side became retractable so as not to interfere with launching and landing aircraft. There is no hangar built into the structure of the ship, so aircraft are tethered to the decks for inertial control. Also, it is rare for all four decks to be fully employed, since the third deck is often used for storage of containers containing armaments for prolonged operations. The first, second, and third decks are used only for launching craft and the fourth is dedicated for landings. However, depending on the tactical situation, launch and landing from the angled deck is also possible. Each deck is equipped with two electromagnetic catapults to launch aircraft with the basic consideration that landings would be achieved by approaching the rear of the carrier. An arriving craft is decelerated by a tractor beam positioned at the rear, then guided to the entrance of the landing deck. In some cases, one type of aircraft is dedicated to each class of carrier, but different models can be taken on board depending on strategic demands. and a lovely picture There's more at this page including some images of the fleet in 1/1000 http://ourstarblazers.com/vault/DHApril14/ Edited March 15, 2014 by Misrule Link to comment Share on other sites More sharing options...
streetfighterjeff Posted March 15, 2014 Share Posted March 15, 2014 love this model and the ret of the pics of the others. what program is this from? going to have to look for it on the tinterweb and have a look for the kits, jeff Link to comment Share on other sites More sharing options...
Misrule Posted March 15, 2014 Share Posted March 15, 2014 Its from a Japanese anime by the grand name of 'Space Battleship Yamato 2199' which is a remake of one of the original anime's from the early 70s i think. It's old school space opera, lot of drama, lot of explosions, nice balance of character development and well fleshed out antagonists which is a nice change from a lot of fiction Also, awesome looking ships and fighters Here's a long trailer for the series to get an idea... https://www.youtube.com/watch?v=yue88a0Mx50 Short version- Earth in the year 2199 is dying, after a long war with a superior alien empire humanity has a year left to live. From nowhere Earth is contacted by a benevolent alien who claims she can give Earth the means to restore the planet to life. She provides plans for humanity to build an advanced ftl capable ship so they can go to her world and collect this device. Unfortunately the enemies of Earth aren't about to simply let this happen so the ship is armed with experimental weapons, a crew made up from grizzled veterans and promising newcomers, and given the task of breaking through the enemy lines to save Earth before all life is extinguished. Also in order to hide this construction from the enemy the ship is disguised as a wrecked WWII battleship, which is why it has that retro look Link to comment Share on other sites More sharing options...
streetfighterjeff Posted March 15, 2014 Share Posted March 15, 2014 cool.that is a must look. and also my next build is going to be a what if tiger tank but as a what if and hovering. jeff Link to comment Share on other sites More sharing options...
Madhatter Posted March 16, 2014 Author Share Posted March 16, 2014 Damn, I had no idea e deck was supposed to be gray. Too late for a repaint now. I prefer the gray though. Maybe on e next one ill do it that colour. I'm waiting on my dreadnaught to come in, which hopefully won't be too far away. Same goes with the twin fronted flagship. So can't wait I'll be updating this build again soon. Not too far from completion now Link to comment Share on other sites More sharing options...
Pete in Lincs Posted March 16, 2014 Share Posted March 16, 2014 Jeff, Hover tanks look cool (I built one too) But, They really do need recoiless weapons. (Sorry, Madhatter. Back to you) I always thought they'd dredged up the Yamato. You live & learn! Link to comment Share on other sites More sharing options...
Madhatter Posted March 16, 2014 Author Share Posted March 16, 2014 No worries Pete - I have no objections to tangents I am almost finished the base now – just a few things to tidy up, mostly just the edging and the addition of some more piping. I decided to plug everything in tonight to see how it looks, and I am pretty darn happy with myself. It’s come out really well – not too bright – just right. I am also glad I reduced the number of Fiber threads in the buildings – the effect is now just right. I had to spray the surface another colour because the Alclad scratched off a lot and it was looking pretty crap, so I have gone with a light gray and I am happy with the result. The ship is finished bar the bridge section which is being cast in clear – so I should get that back in a couple of weeks. I also plugged that into the base and it works a treat. Pics of that part soon. In the meantime, I took some pics of the base so you can see what you think: Thanks for stopping in guys See you soon MH Link to comment Share on other sites More sharing options...
streetfighterjeff Posted March 16, 2014 Share Posted March 16, 2014 looking better and better madhatter. cant wait to see it all together. Link to comment Share on other sites More sharing options...
Madmonk Posted March 16, 2014 Share Posted March 16, 2014 That's turned out quite nice Si. Having looked at some of these I quite fancy a go at building one of the Yamato 2199 kits. Did you use the flasher unit at all. Cheers, Warren Link to comment Share on other sites More sharing options...
Misrule Posted March 16, 2014 Share Posted March 16, 2014 (edited) Damn, I had no idea e deck was supposed to be gray. Too late for a repaint now. I prefer the gray though. Maybe on e next one ill do it that colour. I'm waiting on my dreadnaught to come in, which hopefully won't be too far away. Same goes with the twin fronted flagship. So can't wait I'll be updating this build again soon. Not too far from completion now Its cool, the deck is supposed to be red-brown in canon, I guess the guy who made that model wanted to be a bit unique himself with the grey Every ship on the show of that type though, definitely red based so your ship is accurate to the source. Dreadnought is scheduled for end of July, though there is a regular battleship due end of April also. That said I'm really keen for the red fighter plane that shows up a few times edit- Here's a pic of the rank and file battleship due April Edited March 16, 2014 by Misrule Link to comment Share on other sites More sharing options...
Madhatter Posted March 16, 2014 Author Share Posted March 16, 2014 Oooo, that battleship does look rather nice, might just have to pick that one up too. I am this close to buying the later triple deck carrier as well. Might do that in a few weeks time when the wife goes on holiday. Warren, no I haven't used the flasher unit on this as I am saving it for another project it'll get used though Thanks everyone for the kind posts Si Link to comment Share on other sites More sharing options...
Carts Posted March 16, 2014 Share Posted March 16, 2014 I have to admit to knowing next to nowt about this Battleship Yamoto stuff,but I know exceptional modelling when I see it. Link to comment Share on other sites More sharing options...
Madhatter Posted March 17, 2014 Author Share Posted March 17, 2014 Thanks Carts Don't worry, until I started this kit, I knew just as much as you about the series, but thanks to Misrule, I now have a relatively good grasp on it. Am hoping to finish the base tonight, so I'll post some pics of it if I do Link to comment Share on other sites More sharing options...
