Killingholme Posted October 31, 2013 Posted October 31, 2013 (edited) Hi all, Just finished building the Dragon Sherman III 'Early production', which is a pain of a kit in all the ways that a Dragon armour kit is renowned for. Anyway, I'll still use the kit decals for 'Brabham Moor' a Royal Scots Greys tank. Here she is. http://www.iwm.org.uk/collections/item/object/205204405 Could people take a look and help me identify the stowage on here. The ammo boxes appear to have been spot-welded to the tank (I'm reading those dark stains at their bases as rust streaking), but I'm not 100% sure I've correctly identified what type of box they are... What is the contraption with the white frame or straps hanging off the back? That's got me stumped! cheers for any help you can offer, Will Edited October 31, 2013 by Killingholme
Sgt.Squarehead Posted November 1, 2013 Posted November 1, 2013 (edited) I think The boxes may be .30cal for the co-ax MG? I don't think that they would be welded to the hull and to my eye it looks like they are in a rack. The top edge of the lower front frame of the rack is faintly visible as a horizontal line across the 'face' of the ammo boxes. The track adjusting wrench appears to be stowed underneath the rack and I believe the large box to the left of the ammo boxes is strapped to the left outside end of the rack . As for the contraption hanging off the back.....Not a Scooby! Edited November 1, 2013 by Sgt.Squarehead
ozz Posted November 1, 2013 Posted November 1, 2013 (edited) it does look like a chair, but i think it resembles the cages used on the side of the 3.7cm german AA guns. that is used to catch the shell cases. Edited November 1, 2013 by ozz
Shermaniac Posted November 1, 2013 Posted November 1, 2013 The boxes on the rear deck look to be a 5 gal flimsie (probably Water)- not fixed and a 25pdr or 75mm Ammo Box welded/mounted and providing a housing for the track spanner seen beneath it The framework looks to be the breech guard (upside down) to the tank 75mm gun (removed) with other accompanyments. This could be a command tank? so would not need this item as the gun was not really there???
Sgt.Squarehead Posted November 1, 2013 Posted November 1, 2013 (edited) But surely a command tank would never have had a gun fitted in the first place? I still think at least some of the 'boxes' are belted ammo, While the first three on the left may well be flimsies the proportions of the two 'boxes' on the right don't seem correct and there is clearly some stencilled writing on the last one, which strongly resembles this (to my eye): Here's a 4-Gallon Flimsy for comparison: Edited November 1, 2013 by Sgt.Squarehead
Sgt.Squarehead Posted November 1, 2013 Posted November 1, 2013 To save flicking between windows, here's what we are talking about: THE BRITISH ARMY IN ITALY 1943. © IWM (NA 8276)IWM Non Commercial Licence
ozz Posted November 1, 2013 Posted November 1, 2013 (edited) some command tanks had dummy barrels made of wood. and i agree about the breech guard. well spotted. Edited November 1, 2013 by ozz
pigsty Posted November 1, 2013 Posted November 1, 2013 I don't think the staining under the long ammunition box by the serial number is rust. It's more likely to be spilled fuel. The filler cap is just inboard of the tow cable / spanner.
Niall Posted November 1, 2013 Posted November 1, 2013 I think the squarish box is for a primus stove.
Sgt.Squarehead Posted November 1, 2013 Posted November 1, 2013 some command tanks had dummy barrels made of wood. and i agree about the breech guard. well spotted. Sure.....Which means they wouldn't ever have needed a breach.
Killingholme Posted November 2, 2013 Author Posted November 2, 2013 (edited) Thanks guys this is really appreciated. I am convinced the frame is the breech guard. Seems an'odd thing to either remove or to keep as a spare! Wonder why they did that. Unless it just broke that day and someone's going to have to repair it. Surely if the gun had been removed the breech guard would havebeen bolted back'm on and the whole addembly kept together. Other than findingaveteran tanker to ask, who knows. but the important thing is that it is there and I'll have to make it! Thanks for the advice 're boxes and attachments. Forgot about the position of the fuel fillers- seems more likely than ruststreaks-I was thinking about the way you saw the sand guards spot welded to the hind quarters of Shermans in Italy and maybe got carried away... If the 25per box is in a rack,I don't suppose anyone knows of a photo of said type of rack empty? I assume something'like the crate fitted to the front fender on british Shermans? Thanks once again guys Will Edited November 2, 2013 by Killingholme 1
hwallen1410 Posted November 2, 2013 Posted November 2, 2013 I think the large box is a 6pdr ammo box (the strange wavy line gives it away) Not the clearest picture: Not sure if it is in a rack, though I have seen racks on British Shermans in that position, will see if I can dig out a picture. No idea why the Breech Guard has been removed. As far as I am aware command tanks were still armed, you might be confusing them with the RHA forward observer tanks. Hope this helps.
JackG Posted November 2, 2013 Posted November 2, 2013 (edited) Can't add much more to what others have spotted, but This Bronco set might help your accessorize your build: As for the breech, not sure the reasoning, but have seen some British shermans utilize the rear section of a mud guard as a bin, by flipping it upside down. regards, Jack Edited November 2, 2013 by JackG
JackG Posted November 2, 2013 Posted November 2, 2013 Was able to find film footage of the tank in question, at about the 3.27 min mark: http://www.britishpathe.com/search/query/183816/playlist/1 From the same page you can also access viewing of individual stills. regards, Jack
Killingholme Posted November 2, 2013 Author Posted November 2, 2013 Jack, you champion! I'd never have found that! Gives me a hint at what the stowage was on the front too. Glad I don't have the skills to do dioramas, or that 10 seconds of footage might have cost me a load of money in figures and scenery! cheers, Will
Killingholme Posted November 5, 2013 Author Posted November 5, 2013 Hi all, Another quick question= what type of track do you think this Sherman is wearing? I haven't found a single photo of a British Sherman in italy wearing the kit-supplied plain rubber block tracks, and the one's in the pictues look like they have some kind of relief in them. Can of worms duly re-opened... Will
Andrew Jones Posted November 5, 2013 Posted November 5, 2013 Some tank crews removed the breech guard to make it easier to bale out in an emergency. Andrew
Sgt.Squarehead Posted November 5, 2013 Posted November 5, 2013 (edited) Looks like WE210 to me: Might just possibly be T49: But I don't think so. Some tank crews removed the breech guard to make it easier to bale out in an emergency. Andrew Now that would make sense. Edited November 5, 2013 by Sgt.Squarehead
Killingholme Posted November 6, 2013 Author Posted November 6, 2013 Cheers Andrew and Squarehead. I really did think the track looked like the rubber block WE210 too!- the 'block' relief seems very pronounced in the photos-more so than on the typical steel chevron type of track. Damn Dragon- it looks like I'll have to buy tedious, fiddly, expensive, aftermarket working tracks. I REALLY didn't want to have to do that... Will
Killingholme Posted November 6, 2013 Author Posted November 6, 2013 Oh god, it's even worse than I thought... Bronco's replacement WE210 tracks "consists of 960 parts in light beige plastic... " I swear it's the last time I buy a Dragon armour kit! I end up throwing half of the kit into the spares bin.
keefr22 Posted November 6, 2013 Posted November 6, 2013 Why don't you build it in a dio a couple of seconds after the picture was taken - the tracks would be invisible then....!! It's OK, I've got me
Sgt.Squarehead Posted November 9, 2013 Posted November 9, 2013 I swear it's the last time I buy a Dragon armour kit! I've said that a few times too.....But for almost the opposite reason!
