Tbolt Posted September 17, 2023 Posted September 17, 2023 13 hours ago, elger said: so I'm curious about how much retooling has been done - the Eduard fuselages have always been a tad taller than the competition. Is there anyone with both Eduard kits (the older G series and the "retooled" K) who could compare fuselages and see if they're still as tall (especially behind the cockpit) or if the height has been reduced? The exhaust cutout looks quite large still, which makes me think the nose is still too tall, but I haven't checked it yet. I'll have a look when I get home later. 1
Tbolt Posted September 17, 2023 Posted September 17, 2023 21 hours ago, elger said: so I'm curious about how much retooling has been done - the Eduard fuselages have always been a tad taller than the competition. Is there anyone with both Eduard kits (the older G series and the "retooled" K) who could compare fuselages and see if they're still as tall (especially behind the cockpit) or if the height has been reduced? So checking the G-6 fuselage against the K-4, they are exactly the same in height. the exhaust slots on the K-4 are actually a little narrower, by approximately 0.4mm and the exhaust themselves narrower by approximately 0.6mm. 1
elger Posted September 17, 2023 Posted September 17, 2023 32 minutes ago, Tbolt said: So checking the G-6 fuselage against the K-4, they are exactly the same in height. the exhaust slots on the K-4 are actually a little narrower, by approximately 0.4mm and the exhaust themselves narrower by approximately 0.6mm. thank you! 1
Tomas Enerdal Posted September 18, 2023 Posted September 18, 2023 If anyone is interested, The look of the exhausts and their openings can be improved, a lot if you ask me. Take a look at the Hombee's post above, from Aug 18, with the pics of the built up kit. For some reason Eduard mould the narrow exhaust shields, above and below the exhaust stubs into the sides of the fuselage. Yet the opening looks too wide. They should be there for the upper side above the thin shields as an integrated part ow the cowl, but not below. If you choose to add Eduard's own aftermarket exhaust you add another set of lower shield to that, why? There should only be only one lower shield each side, and very thin at that. To improve the looks, remove the lower shield from the fuselage, just below the exhaust opening. Work carefully, sand the last remnants away with fine wet'n-dry, so as to save the surface details below the opening. If needed, the opening can be narrowed down further with a shim of thin plasticard. Again, carefully sand away any plasticard that stands proud of the surface. Now add thin exhaust shields below the exhaust stubs, either your own or the brass ones that are enclosed with the aftermarket exhausts. (so far, the best ones that I know of, are the Eduard Brassin aftermarket exhausts for Tamiya's G-6, ED648402. but I have yet to see their latest for this kit) 1
Homebee Posted October 19, 2023 Author Posted October 19, 2023 (edited) Fresh news - Project postponed Source: https://info.eduard.com/cz/10-2023-special V.P. Edited October 19, 2023 by Homebee 1 1
Bozothenutter Posted October 19, 2023 Posted October 19, 2023 Bozothenutter is a sad nutter..... Was looking forward to an israeli mezek...
dragonlanceHR Posted October 19, 2023 Posted October 19, 2023 45 minutes ago, Bozothenutter said: Bozothenutter is a sad nutter..... Was looking forward to an israeli mezek... I will make an offering to the styrene gods and apply the AML resin upgrade to my HC Avia sitting on the Shelf of Doom. 1
RHWinter Posted November 25, 2023 Posted November 25, 2023 On 10/17/2022 at 5:43 PM, Homebee said: Programme 2023 Source: https://www.eduard.com/out/media/InfoEduard/archive/2022/info-eduard-2022-10-special.pdf V.P. Now as we were informed by Mr. Šulz that Eduard will hold back their 1/48 Avia S-199 and CS-199 due to economical reasons: Will Eduard also cancel/hold back their announced Me 109 G-12? This would make sense, 'cause as far as I know, virtually NO german top-fighter-As was ever photographed in a G-12 or reported to have scored kills flying a G-12 - which means that this would be a low selling kit. Any rumors?
Piotr Mikolajski Posted February 8, 2024 Posted February 8, 2024 On 11/25/2023 at 5:50 PM, RHWinter said: Will Eduard also cancel/hold back their announced Me 109 G-12? Someone asked about this long awaited version and here is the answer from Mr Sulc: CZ: Tak ta bude dlouho očekávaná ještě nějakou dobu EN: Well, it will be long awaited for some time Source: https://www.modelforum.cz/viewtopic.php?p=2628491#p2628491 The conclusion is that the G-12 has not dropped out of the programme, but will not be released this year. 3 1
Homebee Posted August 9, 2024 Author Posted August 9, 2024 Platz boxing - ref. AE-33 - Messerschmitt Bf.109G-6 Gustav - JG-52 Source: https://www.1999.co.jp/eng/11082258 V.P. 1
Homebee Posted October 9, 2024 Author Posted October 9, 2024 Hope for those who like Awfulschmitt V.P. 4 2
RHWinter Posted October 10, 2024 Posted October 10, 2024 10 hours ago, Homebee said: Hope for those who like Awfulschmitt V.P. „Awfulschmitt“! I did not know that the Avia S-199 is being called like this. I always thought the reason why this version of the Me 109 was a rare bird model-wise was that there were not so many victories achieved with. You know: Boys like heroes. But now I understand there‘s a new (to me) perspective: uglyness! So Eduard hesitate to bring up the S-199 because they will probably only sell the kit to czech and israeli modelers - and me. Oh, BOYS!! 1
Graham Boak Posted October 10, 2024 Posted October 10, 2024 It wasn't. It was called the Mule, because of its poor handling and performance. At least in Czechoslovakia. But there has been a lot of decades for people to invent all sorts of aviation histories.
Patrik Posted October 10, 2024 Posted October 10, 2024 In Czech, Mule is Mezek. So the name is a pun. Partly a kind of funny abbreviation for Messerschmitt, and partly an indication of its headstrong handling characteristics, especially while starting or landing. 6 1
Milos Gazdic Posted October 14, 2024 Posted October 14, 2024 is S-199 finally coming in 1/48? did i miss something?
RHWinter Posted October 14, 2024 Posted October 14, 2024 12 hours ago, Milos Gazdic said: is S-199 finally coming in 1/48? did i miss something? No, you did not miss something, Milos - unfortunately not…
Milos Gazdic Posted October 15, 2024 Posted October 15, 2024 Sadly BUt just saw that they announced it for 2026... Which doesn't sound too promising.
RHWinter Posted October 15, 2024 Posted October 15, 2024 1 hour ago, Milos Gazdic said: Sadly BUt just saw that they announced it for 2026... Which doesn't sound too promising. No, not „to“ promising, indeed… First contact I had with Eduard about S-199 and CS-199 in 1:48th must have been around 2016 and they told me these kits MIGHT come out in 2019… But Eduard do a great job and when the market is ready for those two types of planes, Eduard will give us great models of them. But until then it will be more Me 109's, Spitfires, Mustangs and the like. It‘s simply the economy. 1
Piotr Mikolajski Posted October 15, 2024 Posted October 15, 2024 On 10/14/2024 at 8:08 AM, Milos Gazdic said: Is S-199 finally coming in 1/48? Yes and no. Eduard is working on it, they don't want to put it off any longer. However, it will not be released in 2025.
Homebee Posted November 20, 2024 Author Posted November 20, 2024 (edited) Released - ref. 82166 - Messerschmitt Bf.109K-4 Kurfürst - ProfiPack Source: https://www.eduard.com/eduard/bf-109k-4-1-48-1-2.html V.P. Edited December 22, 2024 by Homebee 2 1
Homebee Posted December 22, 2024 Author Posted December 22, 2024 Released - ref. 84203 - Messerschmitt Bf.109G-4 Gustav - weekend edition Source: https://www.eduard.com/eduard/plastic-kits/weekend-edition/aircraft/1-48/bf-109g-4-1-48-1.html V.P.
Homebee Posted December 22, 2024 Author Posted December 22, 2024 Released - ref. 84201 - Messerschmitt Bf.109G-6 Erla Gustav - weekend edition Source: https://www.eduard.com/eduard/plastic-kits/weekend-edition/aircraft/1-48/bf-109g-6-erla-1-48-1.html V.P. 2
Homebee Posted September 3 Author Posted September 3 (edited) First boxing S.199 box art - kit should be available at the Eday 2025 - ref. 94801 ? - Avia S-199 Erla Canopy V.P. Edited September 5 by Homebee 8
Piotr Mikolajski Posted September 3 Posted September 3 3 hours ago, Homebee said: First boxing S.199 box art - kit should be available at the Eday 2025 The premiere is set for November, so the kit will definitely be shown at Eday, but there can be no delays if it is to go on sale. 1
