Tamyia Avro Lanc Dambusters 1/48(picture heavy)
fallmonk
Well since everyone else was doing one i felt left out ;-) actually me and me and my best mate are building the same(ish) kit he bought a straight forward tamyia lanc i bought the Dambusters version.will post as i go.Also fitted a "edwardo" dash kit so far so good here's some pictures , Ohh and just to add a bit more interest i decided to wire up the props with micro motors AND am going to wire up the "UP KEEP" Bomb to make it spin , it will either work out good or i will destroy a £100 kit lol
Not sure if this will upset people but i decided to go with cockpit green even thou Tamyia say use "Panzer Grey" or Black
Drilled out upkeep for pully and dowel,
Now the more observant of you might have noticed i wired the batt and motors up BEFORE i hooked the wings and fuselage OOOOOOHPS have to cut n shut together null_zps2309f797.jpg
Edited by fallmonk
me too....why not add the altitude lights as well?
another thought...if you were to add the downward lamps why not mount the Lanc on an acrylic pole over a seascape ( lakescape didn't sound right ) ....would look brill with props & Upkeep turning & the lights reflecting off the water!
BTW build looking good!
I have a nice peice of clear Perspex I was going to mount it on , but your idea for the lamps sounds good . Will need to up the power and get a few led lights , also need to fabricate some tubes for lights so they act as spot lamps and not just light up area below !
:popcorn:
Ok wee trip to maplins after work this afternoon , bright white LEDs bought , power source bought, micro on/of switch bought , battery's and extra cable bought ! Now I just need to figure out where lamps should be in position , wire and fit it all in the lancs fuselage ,,,, easy :-( lol
It looks like you've attached the wireless operator's table and radios to the aperture where the front turret sits... you may want to change that!
Tom your 100% right, either I wasn't paying attention or sniffing to much glue lol,
Thankfully I had only placed it there in a dry fitting , didnt look right so sent picture to my mate and he corrected my error .
Dont you just love Maplins,
Aldis lamps drilled out ,
OK some bad news one of the LEDS died 2mins after this pict was taken , so i cant button it up the now , done a lot of soldering wires running the switches etc think i have it almost done just need to go to maplin AGAIN think i have shares in there , on first name terms with half the staff lol
Am not sure they had this amount of wire in the real Lancs
Cheers folks some slow progress mostly trips to maplins getting switchs, then more leds, then as recommended some resistors,
but think am finally near closing her ,
Also started the the water Dio , never null_zpsdc0b0e9b.jpgdone one of these so trial n error
Edited by fallmonk
Small update,still got loads to do , really strugling to keep the upkeep bomb pivot in place ,spins to fast and superglue not holding it !
will figure something out ,to be honest i done these shots more for my sanity as wiring really done my head in , just wanted to see some progress.
Had some problems with paint so lots of sanding and re masking, am hopeing its ok this time.
Its starting to be a long slog this one not happy with my sanding and filling but will keep trying
Small update , got painting i wanted done finished (so far) fitted tail and upkeep bomb ,fingers crossed it turns the dowel wasnt sitting 100% right so its a bit hit or miss if it works !
Another update , been very slow with this due to work and weather had a slight problem with rear turret(pict below) any ideas?
also as i thought the bomb aint spinning so far looks like more work required !
PS had a engine failure on the video that will need looked at ;-)
nearly there
