Gday All Thought I better get started too. My build will be the venerable Hasegawa 1/48 kit done as a R.A.N aircraft, although at this stage not decided on final scheme
So first off, the required box shot
Now, unfortunately I did take shots of the cockpit, but when checking them to post they were unusably blurry so we now jump ahead to where I have glued the fuselage halves together
not sure if I just got a badcopy but the fit was nothing to right home about, requiring much filling with super glue and rescribing
To Be Continued!
Edited by pacificmustang
moving along, the stiffeners need to be removed from the intake sides for a RAN/Kiwi machine
so they were simply sanded off with progressively finer grades of sanding sticks and sponges
I must say, after a late start I am becoming a convert to using these sticks and sponges. I find the Flory skinny sticks and sponges invaluable, especially with armour builds
The intakes were not a bad fit at all, after a bit of fettling, and dont worry Calum and Silver Fox, I have a couple of Trumpeter 32 kits to be done as A-4K's
Bruce
Bruce
Phew, I was getting worried Bruce :D
I agree about the sticks and sponges I find them excellent for sanding
on to the slats, and an error in the kit. The slat wells have a pronounced step whereas the real a/c does not have this, the slat wells simply flowing into the wing upper surface with no step evident.
Other builders have used various means to remedy this, such as cutting the slat well out and reattaching it flush with the upper wing, or using filler to blend it in. I suppose I could have left it, but would not be able to put up with Calum's bleating :winkgrin: so thought I would skin the well with plastic card instead to bring the well up flush with the wing surface
not sure how happy I am with this, may try a different technique on the next one.
You may wonder why I have attached the slats this early in the piece. Well on every other A4 I have done I have knocked the slat actuators off, hopefully, attaching the slats now will lessen the odds of this happening
  • 4 weeks later...
and decaled
I had fun sitting the roundels over the vortex generators and the rudder checks over the ribs NOT!
Must have taken about ten coats of microsol and a bit of touch up in the end. OOPS, just spotted the wonky rescue arrow
whilst waiting for all the decal solutions to dry, thought I might crack on with a second kit, so heres the cockpit done with a bit of help from Mr Eduard
Most pics I have of skyhawks show them at rest with the tailplanes in the nose down position. Seeing as I had some steel beach stabiliser pivot plates in my possession I cut the kit ones off, which was probably a mistake as the resultant holes were far larger than the resin plates necessitating me filling them with bits of plastic card
I also wanted to show the access hatch between the flaps opened, so cut this out of the kit bottom wing. Some dodgy scratchbuilding later, and I had some bulkheads and stringers in place. A piece of plastic tube to represent the aft section of the engine, and it should be good enough for what you will be able to see through the hatch
This one will be done in the air superiority scheme
Thanks for watching
Bruce
Thats one think hing that Classic Airframes got right on the TA-4, no slat well just a smooth transition.
Lovely looking G.
oh.Buggar :banghead: I missed that walkaround on your site Calum. To be honest, the added detail is just to give the effect of internal structure rather than a superdetailed interior. I can live with my spurious detail, the wrong colour is a different matter though. I now have the fuselage together so repainting is going to be difficult. Will have to see how much I can hit if I point the airbrush up there. Might just have to live with a ZC interior, but I will do the inside of the door silver. Wish I had found your walkaround earlier
Well if I ever see that particular model of yours in real life I'll not shine a torch up there. :D
I'd like to open the aft hell door on my next build. We always left them open
Edited by Calum
getting there. I could even get this one finished :thumbsup:
meanwhile, on the other one DAMN YOU GIBSON!!!!!!!!
If you're not breaking slat rails you're not building A-4's :)
888 looks good. As an aside does anyone know why the second batch of G's got numbered 87X instead of the 89X that might have been expected?
The 87X batch of side numbers was still being used by the last surviving Sea Venom FAW-53's when the first batch of A-4's arrived. The 88X numbers
had been used previously by Gannets (Which were nearly all retired by 1967)
The second batch of (ex USN) A-4's arrived in 1971 by which time only a few target towing Venoms were still around and the 87X could be applied with little issue.
The last Sea Venom (WZ-943) carried out the last RAN flight in 1973.
The 89X numbers had been allocated to firstly the Westland Scouts then later on the Bell 206 Kiowa ( pocket rockets)
Edited by NAVY870
