Procopius Posted August 1, 2013 Share Posted August 1, 2013 I purchased the Fujimi "Sharkmouth" Ju 87B kit (F-17), the kit decals for which I believe depict an aircraft as shown in a propaganda shoot for Signal magazine c.1939. Are there any decals out there for a Ju 87B in the Battle of Britain? I mean, I know there are, I'm not an idiot, but are there any for a plane that was shot down during the battle? That would be my preference. Link to comment Share on other sites More sharing options...
Steven Eisenman Posted August 1, 2013 Share Posted August 1, 2013 Before you begin your search, nearly all the Ju 87s in the BoB were the B-1, an entirely different animal from the B-2. I understand the Fujimi may come with straight stack exhausts, but that alone does not make a B-1. The B-1 had an entirely different radiator, narrower prop blades, a different shape under the nose just behind the prop, and a slightly different angle on the main gear. So, if accuracy is an issue, might want to consider an alternative. However, a few units were beginning to receive the B-2 as the BoB was drawing down in the fall of '40. Iterestingly, St.G. 2 had receive R-2s in late August, early September: Coded T6+AP (yellow A) for example. The shark mouth aircraft was a true B-1. Link to comment Share on other sites More sharing options...
Procopius Posted August 1, 2013 Author Share Posted August 1, 2013 Is the Fujimi kit not a B-1 out of the box, then? Link to comment Share on other sites More sharing options...
Chuck1945 Posted August 1, 2013 Share Posted August 1, 2013 The Fujimi kit is sold as a B-1/B-2 and includes the earlier exhausts B-1 type exhausts. No other alternative parts are provided. That said the narrower prop can be done by re-shaping the kit prop and the other changes Steven mentions are either minimal in 1/72 (the radiator housing is perhaps 0.5mm deeper for a B-2) or not borne out (or at least noticeable on the 1/72 plans in the recent Classic pubs book on the Stuka. 1 Link to comment Share on other sites More sharing options...
