Bristol Bombay / Bristol Superfreighter wings question
phat trev
I understand the Bristol Bombay and Bristol Freighter shared the same wing? Would the same wing be used on the Superfreighter?
Wondering if I could use the wings from the airfix Bristol Superfreighter on a vac form bombay (with a bit of altering as needed?)
The Bristol 170 Freighter and 130 Bombay display only similar layout of fixed-gear twin-engined high-wing monoplane.
Just have a look at bare figures: wing span 96 ft for Bombay and 108 ft for the Freighter, wing area 1340 sq.ft for the pre-war a/c and 1490 sq.ft for its post-war replacement. Moreover - although both wings feature identical section and taper ratio - the older one is a seven-spar design with straight leading edge and forward sweeping trailing edge. The Freighter wing is a simplified two-spar design with swept leading edge and straight trailing edge.
Thus no chance for the idea you propose :(
Hi, think Valom are releasing a 1/72 injection
Bristol Bombay later this year. I seem to
remember that there was originally some
commonality between Bombay and Freighter
wing design but think a conversion would be
extremely difficult!!
Cheers, Paul
