trickyrich Posted June 1, 2013 Share Posted June 1, 2013 hi all, I’m after some help on an old chestnut that I know has caused some heated discussions both on this site and a few others. I see others have asked about bits and pieces of information on this subject before but this time I’m hoping once and for all (yeah right!) with this thread we can have some definitive answers.....maybe! FAA Avenger MkI/II (or Tarpon Mk I/II) versus TBF/TBM-1C Ok for starters, TBF-1C vs TBM-1C, so far form all he research I can find there was/is very little difference between the two. The TBF was manufactured by Grumman and the TBM was made under license by Eastern Aircraft (division of GM), plus for some bizarre reason each company decided to painted the interiors different, so this aside I can find no other differences between the two aircraft. I have read though that there was some issues with parts between the two different manufactured aircraft as they often weren’t interchangeable??? So for a coming build an Accurate Miniatures Grumman 1/48th TBF-1C is going to be the starting point. Tarpon (Avenger) Mk I/II vs TBF/TBM-1C First up the base model is going to be a -1C, so this will not have the single cowling mounted 30cal of the -1, but rather the wing mounted 50cal’s. This probably is the major noticeable difference other than the radio mast location changed between -1 and -1C. The Tarpon had a different Radio Observers windows, they were the round dome windows on each side rather than the flat ovals fitted to the TBF/TBM’s. Plus they had the second cockpit position for the Navigator, which had aircraft controls fitted (though it is mentioned that the control column was stored most of the time), in place of the radio gear normally found on the TBF/TBM’s. Other than those two details I cannot find any other major differences. Oh and for some reason they decided to change the name from Tarpon back to Avenger. Tarpon Mk I vs Tarpon Mk II Next the difference between are Tarpon Mk I and an Tarpon Mk II with respect to SEA operations and not Atlantic operations? Again only looking at the -1C aircraft (earlier TBF-1’s were also called Tarpon I’s), other than it seems the Grumman made aircraft are referred to as Tarpon Mk I’s and the eastern made as Tarpon Mk II’s. There seems to be very little differences between the two. I have an aircraft I want to build but again have run into this issue of whether it is a Mk I or Mk II! I have a set of Xtradecal markings for an Avenger II JZ257 of 849 NAS, HMS Victorious, British Pacific Fleet, Jan45. But a quick bit of research on the FAA archive web site shows this aircraft was actually an Mk I!! If anyone has a definitive guide to the aircraft serial numbers that would be a great help. I guess the main thing is to get the additional cockpit sorted out and correct as I can get it. I either have the bit required or can easily make them, I just need either some good photos (only have a couple) or some good draws showing some detail. Else I may just have to create something that looks the part....maybe! Have a few reference books, but there’s not a lot of info on the FAA Avenger/Tarpon. All help with any of these question/quires would be greatly appreciated and hopefully this won’t start a big argument! Link to comment Share on other sites More sharing options...
