1/48 classic airframes d h hornet
brewerjerry
Hi All
I finally won a classic airframes sea hornet off e bay, only $30 inc shipping.
so what is it like ? any suggested mods needed ?
I am thinking of doing the F20 TT193
how accurate is this scheme ?
http://www.britsim.com/components/com_remository_files/file_image_1902/img_1902_03.jpg
cheers
Jerry
One of the better CA kits to put together. Not totally spot on, but does look like a Sea Hornet.
Never seen that scheme before.
Hi All
cheers
Jerry
hi Jerry
Pigsty beat me to it, here's the finished link tho
http://www.britmodeller.com/forums/index.php?/topic/234928568-de-havilland-sea-hornet-nf21-classic-airframes-148th-scale/
the one Sea Hornet that ended up in Canada for cold weather testing.
I think the centre section has survived IIRC
http://www.dhhornet50.net/index.php?f=data_home&a=3
Wing centre section from Sea Hornet F.20 TT193
some photos and background on the Canadian plane here
http://forum.keypublishing.com/showthread.php?15226-DH-Sea-Hornet-a-survivor
from post #50
... Sea Hornet F20 TT193 was sent out to Canada for winterisation trials in Edmonton, starting in December 1948. On completion the airframe was sold off, to save the cost of transporting it back, to Spartan Air Services as CF-GUO in July 1950...
seems the scheme above maybe correct, don't know if any photos exist. David Collins would be the chap who would know.
HTH
T
edited as noticed reference to scheme asked about.
Edited by Troy Smith
Hi All
cheers
Jerry
Hi Jerry,
This civilian scheme for TT193/CF-GUO is ok. I've probably got some more photo's showing it, including a very grainy colour one. I'll post them here later.
Hi All
cheers
Jerry
Hi Jerry,
As promised, here is a colour scan of CF-GUO in Spartan colours. Sorry its not great, but its the only colour one I've seen so far.
It looks like the flightsim colours are ok, but it won't have the rocket rails or arrestor hook fitted.
Edited by David A Collins
  • 2 months later...
I am rehabilitating a NF.Mk.21...kit wings are wrong..missing fold mechanism bumps and fold lines, tail wheel should be anti-shimmy style, main gear wells lack any detail, main gear legs lack detail, and that's for starters. I'd post a picture of my work in progress, but not sure how to do that as I'm a newbie.
cheers,
Ross
Since you've asked, one thing that has been observed, and I think I verified to my own (dis)satisfaction, is that the canopy isn't shaped quite right. I have the "old" ARBA [?] resin kit, and I'm hoping that I can use that (vac) canopy as a model to pull some new ones, since it seems to be more accurate. Or maybe I'll just have to become a sculptor...
bob
  • 5 years later...
Hello!
Sorry for the thread necromancy, but I'm trying to put together a little list of changes that are more or less needed for the good old Classic Airframe kit, since I intend to start it in 2 weeks time or so.
Since I currently only have the F.1/F.3 kit, I'll focus on that:
It seems that the fuselage for the F.3 might be a few mm too short, but figures range from 4-8mm.
Spinners are also too short, ranging from 1-4mm.
Main gear and wheel wells are either in the right position or needs to be moved up to 6mm rearwards, but not deep enough in any case since there is no cutout in the lower wing.
Radiator rear flap is not opened up, and there is no duct to speak of.
Tail wheel is not of the shimmy type.
Some say that the seat looks a bit iffy, maybe nicking one from a Eduard Spitfire could work?
New wheels and seatbelts will probably be ordered from Hannants very soon
Anything else?
Yeah, I've been through it a few times already. :)
Jonners also tells me that the fuselage is supposedly 20 feet from trailing edge to endpoint att the tail. That is 127mm i 1/48 scale and I measured the kit to be 121mm.
I reckon that two plugs att 3mm each should suffice. It does sound like a fun project!
Happy to help. I actually pulled my Trumpeter F Mk1 off the shelf of "Doom, Doom?, Doom???  This is far worse than doom, this is dread, cold clammy dread, lurking in your nightmares sheer blood curdling terror" and remembered why I had started work on it and why I had not continued.  Fortunately the box did have John A's plans within which is how I was able to confirm the fuselage length.  I will revisit the Trumpeter kit at first daybreak with a sharpened stake, garlic and some holy water.
Jonners :)
Jonners :)
Do you think that will be enough? I would have thought Caterpillar D9, plastic explosive and a box of matches might give a more satisfactory result ...
  • Haha 3
Actually you are right.
I say we take off, nuke the entire kit from orbit...it's the only way to be sure :)
Rippers
  • Haha 4
Don’t you think that‘s a bit over the top if you haven’t tried a silver crucifix first? Nukes should be reserved for the really hopeless Trumpeter cases, like the Attacker.
Or Lightning.
Or Wildcat.
Or Hellcat.
Or...
Now where’s the Single Malt?
