I have no knowledge of this plane prior to building this kit.
Since I don't know much about B-57G, I closely follows other work in progress threads in the forum especially canberra kid's B-57G.
The following are some photos highlighting the changes I made since I starting the build a month ago.
Made a new tub with mostly frictional details using parts and panels from original kit, F-14 and F-16.
It's not accurate, but it do look better over the original cockpit.
Extend the nose by 5mm and stuff it full of epoxy putty and a heavy bolt.
Like what most of the guys had done, I also expand the width of the pod under the nose.
Beef up the size of the pod with more epoxy putty which also serve the purpose of adding more weight to the nose.
Some of the changes to the control surfaces.
Some changes to the original fan parts.
Pylons.
and other bits and pieces around the fuselage.
Looks good, a lot of effort going into this.
Definitely one to watch!
Tasty !
Thank's guys for watching.
A little bit of update, Primed and shade the bottom with mixture of various Vallejo primer.
Also add some details to the bare wing tip fuel tanks.
Edited by HwA
Some fine scratch and conversion work going on there
Hi guys, need help on the following questions on B-57G.
1) Will the air brakes on the wing deploy when those on the fuselage are in open position?
2) Do the landing light under the wing flip out while the aircraft taxi on the taxiway?
Done with cockpit. Next will be the stressful task of gluing canopy to the fuselage :fraidnot:
Very nice work......looking very spiffy indeed
rgds
mr b
I know this is a very 'thickie' question but how are you masking this? Clearly the camo edges are blu-tac or an equivalent but what is the clear masking film? Whatever, it works well!
Michael
Nice work HwA ,it well worth doing the extra work to correct the kit, it makes for a much better looking G, I just wish I could have air brushed the camo on mine.
John
Yes... another :thumbsup: from me on all of it :)
Thanks Mr B, Val, Canberra kid and Mike for your kind remarks.
I hope I don't mess up the whole thing during weathering.
Btw, is there any suggestion for white alphabet and number decals to replace those from the kit?
Airfix has the tail number printed in grey instead of white. :shrug:
Michael
Hi Michael, the "clear masking film" is normal clear scotch tape. They are not as flexible as masking tape but is useful to cover bigger surfaces.
These are the materials I use for masking.
Looks awesome. Love the camowork.
Oliver
Thanks Oliver.
Not much of update as It had been a rush to complete this model for a local event.
The decal I purchase on ebay took more than double of what it usually need to arrive from USA and only reach my mailbox 2 days before the submission date.
Manage to take photos tof both bombs and wheels this afternoon during the rush to complete it before the deadline this evening.
Will try to update with more photos after collecting it back from the event tomorrow.
Bombs from Hasegawa weapon set.
Attempt to modify kit's wheel to resemble those on B-57.
I had either shorten the nose landing gear too much or enlarge the chin pod too much. The clearance between the chin pod to the ground is only around 5mm now.
Wish that I had done a more thorough dry fit before cutting the nose gear. :doh:
The simple base for it which was complete 2 weeks ago.
Thank you Crowbar and those who "like" this thread.
I'm lucky to walk away with a 2nd place in the event. Model suffer some minor damages on the way home.
Will take some photos to post in the finishing line after repairing and touching up.
Congrats on the prize! The first placed model must have been mind blowing to beat this B-57! Thank you for sharing, a wonderful model.
