Hardtarget Posted April 9, 2013 Share Posted April 9, 2013 (edited) I shall start off with the black bunny scheme of VX-4 'Evaluators'. I shall be using masks and additional fret if its required as there is a fret included in this boxing. Edited July 15, 2013 by Hardtarget Link to comment Share on other sites More sharing options...
Giorgio N Posted April 12, 2013 Share Posted April 12, 2013 The 1/72 hasegawa PE parts are adequate and to be honest I don't know if I'd use a PE set for the consolles and panels. Where however a set can be useful is for the seatbelts.One thing to check: some tomcat boxes have PE parts that are slightly wider than the plastic parts where they are to be glued. Better check this and if needed trim the parts before painting.... guess how I know... Link to comment Share on other sites More sharing options...
Hardtarget Posted April 12, 2013 Author Share Posted April 12, 2013 Thanks G. ill make a mental note when im building the pit. The PE with the kit though 'should' fit snugly to the panels. Link to comment Share on other sites More sharing options...
Hardtarget Posted June 2, 2013 Author Share Posted June 2, 2013 Made a start yesterday, and swift progress it was with additional work today. Tub with bang seats. Still need to add the ejector handles but wanted to leave them off till the last min to prevent them falling off. Fuselage top and botom cemented in place with a few other parts attached ready to accomodate the intakes. Just beofre this stage everything got a coating of white seeing as most areas internally are just that. Prep work on the intakes. Main intakes cemented. All parts accounted for including which is not in the pic the intake fan. Rear end constructed with the added PE. The they all meet each other. Weight was added inside the nose cone Next up i think a bit of spraying. 1 Link to comment Share on other sites More sharing options...
Giorgio N Posted June 4, 2013 Share Posted June 4, 2013 Looking good ! And I see your tomcat fits better than the ones I've built before. Now I'm thinking it could be due to the modeller rather than the kit.. Link to comment Share on other sites More sharing options...
Hardtarget Posted June 4, 2013 Author Share Posted June 4, 2013 Looking good ! And I see your tomcat fits better than the ones I've built before. Now I'm thinking it could be due to the modeller rather than the kit.. I wouldnt say that, id put it down to luck Link to comment Share on other sites More sharing options...
Hardtarget Posted June 19, 2013 Author Share Posted June 19, 2013 About time for an update seeing ive made some progress. Out with the gun with tamiya x21 loaded. Grey sections painted along with the canopy (not in pic). U/C duly followed. Then it was the turn of the red 'mind your head and limbs' ID to be painted on. Engines next sprayed alcad and my own home brew burn iron (HU53 and Hu133) Engines cemented in place and the covers? Close up Ready for decals afer a light spray of klear. Link to comment Share on other sites More sharing options...
Parabat Posted June 19, 2013 Share Posted June 19, 2013 Looking good, I like your burnt iron mix. Link to comment Share on other sites More sharing options...
Hardtarget Posted July 12, 2013 Author Share Posted July 12, 2013 (edited) Update on the turkey. She has been decalled. So nearly there with some nav lights only remaining. Edited July 14, 2013 by Hardtarget Link to comment Share on other sites More sharing options...
Hardtarget Posted July 14, 2013 Author Share Posted July 14, 2013 (edited) Completed Kit: Hasegawa Scale: 1/72 Scheme: VX4 Evaluators 1980's AM: None Edited July 14, 2013 by Hardtarget 1 Link to comment Share on other sites More sharing options...
