Enzo the Magnificent Posted March 25, 2013 Share Posted March 25, 2013 I suppose I had better start my build thread, seeing as the GB is nearly over... No, it's not a late entry. I've been working on this since January. It will be an Air Superiority Blue F-15A, namely 73-089 of Det 1, 57 FWW based at Luke AFB in July 1975. At the time, this aircraft was engaged in flight tests of various weapon fits, including air-to-ground munitions. After service at Luke AFB, this aircraft was transferred to the Portland ANG and is now the gate guardian at McMinnville Evergreen Field. The kit is the Academy F-15C. It will be backdated by using a set of Aires turkey feather exhausts and a Pavla Escapac seat. Decals are from the superb Wolfpack sheet 72-050 Train Like You Fight. Here is the resin in close-up. More photos very quickly, as I have been putting stencil decals on it this evening... 1 Link to comment Share on other sites More sharing options...
SaintsPhil Posted March 26, 2013 Share Posted March 26, 2013 Interesting! I've never seen the 1/72 Academy offering 'up close'. 1 Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted March 26, 2013 Author Share Posted March 26, 2013 Interesting! I've never seen the 1/72 Academy offering 'up close'. It's not overly detailed especially in the cockpit and Bay 5 areas. The undercarriage bays are moulded with the doors closed. But it goes together nicely. Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted March 26, 2013 Author Share Posted March 26, 2013 Cockpit area. The cockpit itself was painted with Xtracrylix XA1131 Dark Gull Greay. Instrument decals from the kit. Bay was painted with Lifecolor UA136 Blue Aotake. Intake trunking and fuselage interior sprayed with alclad white primer Intake assemblies. The blue is Lifecolor UA037 FS35450 Air Superiority Blue. Main assembly complete. 1 Link to comment Share on other sites More sharing options...
HOUSTON Posted March 27, 2013 Share Posted March 27, 2013 Enzo, Looks quite AMAZING.. Brilliant start ..nice!! 1 Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted March 28, 2013 Share Posted March 28, 2013 Looking good Enzo 1 Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted March 28, 2013 Author Share Posted March 28, 2013 Undercarriage bays sprayed white with Alclad primer then maksed off by being filled with Copydex. The intakes are masked by being packed with tissue paper sealed with Copydex. Sprayed with Alclad grey primer Overall colour sprayed. The blue is Lifecolor UA037 FS35450 Air Superiority Blue. It looks very bright, doesn't it? 1 Link to comment Share on other sites More sharing options...
HOUSTON Posted March 28, 2013 Share Posted March 28, 2013 Awesome progress...keep it coming Enzo. Looking quite magnificent given its 1:72 scale. 1 Link to comment Share on other sites More sharing options...
AndyC Posted March 28, 2013 Share Posted March 28, 2013 I really wanted to do my 'A' in the GB as an Air Superiority Blue machine but I couldn't find suitable decals in 1/48 1 Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted April 4, 2013 Author Share Posted April 4, 2013 Stickers in progress! The Academy kit provides a fair number of the required stencils - in both the early full-colour and later toned down versions. However - as is usual with Academy decals - the adhesion isn't great, so I have touched the edge of each decal with a hairy stick loaded with Klear. This allows the Klear to flood under the decal by capillary action and seal it down. You still have a few minutes to change the position of the decal if necessary. One thing about the early Eagles was that they have large numbers of stencils all over the place. Therefore I have added extra stencils from various spare sheets, notably along the wing leading edge. This also helps provide a bit more interest. There is nothing worst than a large-ish model in a single colour - it can look so toylike. Needless to say, the Wolfpak decals went on flawlessly - as usual. I have also addedthe airbrake. This aircraft had the early spine on the airbrake which was fashioned from plastic card. I didn't sand the airbrake in fully as I wanted to show it as though it had just closed and hadn't seated fully when the aircraft was shut down. I'm not sure I succeeded. I think the next time I build an F-15 I'll sand it as normal. The natural metal areas were sprayed with Lifecolor LC74. Contrast panels were added with Alclad2 Dark Aluminium and Pale Burnt Metal Up on its gear. Starting to look better now. 1 Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted April 13, 2013 Author Share Posted April 13, 2013 Finished! The nose gear is a bit wibbly-wobbly. Sadly, SAC don't do a suitable white metal replacement set, so this model will spend the rest of its life on the display shelf jacked up on a couple of blocks of Lego. It's sat there now, next to a row of Phantoms. I'll definitely be building another one of these in the future 1 Link to comment Share on other sites More sharing options...
DaveJL Posted April 13, 2013 Share Posted April 13, 2013 Nice work mate, looks very retro! Dave 1 Link to comment Share on other sites More sharing options...
HOUSTON Posted June 22, 2015 Share Posted June 22, 2015 Enzo. . STUNNINGLY GORGEOUS. 1 Link to comment Share on other sites More sharing options...
