Started my next project - Trumpeter 1/32nd AV8B Harrier II
With an Aires pit
And Eduard Exterior etch
First phase adding the heat deflector plates to the fuselage sides - each one is 11 pieces of etch
Peter
I'll be following this one, I've been tempted by the GR7 repeatedly, but I can't afford it...
Looking forward to this one, good luck!
I love the way you've meticulously arranged your tools.
Thank God!! I love the 'used' look of your workspace. I'm ashamed to say I cleaned my modelling area up yesterday, as I got fed up with not being able to find various tools and implements under the piles of debris.
Looking forward to your build, the AM stuff looks amazing already.
Really looking forward to this one.......
Gonna be a looker that's for sure...........
ATB
Today's work on the Harrier - first the engine and intake. First the intake - needed some filler for some ejector pins, but it's sanded out happily
Then the engine - not spending a lot of time on this as it all disappears into the fuselage...
Then started dry fitting the pit - lots of sanding and dry fitting, but it does fit eventually
Then test fit the combing
Peter
Nice detail on the pit, should look the bizz once painted up.
Got a bit more done - first the nose wheel well with all the PE added
Then adding the PE to the nose gear
Sprayed the gloss white for the intake and unmasked
Sprayed and dirtied up the nose wheel well
Then finally sprayed and dirtied nose gear. More weathering later
Peter
Today's work after the expedition to the shed. First more work on the front gear, added some placard decals, picked out the piping and some more weathering
Then started painting the cockpit - first Alclad black primer, then a coat of Gunze H57 Aircraft grey
Then some weathering, picking out details and started painting the panels - still more work to do later
Peter
Looking good, I've got the same trumpy/aires in the stash, so watch with interest.
Nick
Today's work - finishing off the pit and closing the nose. 4 hours of painting and tweaking but I like it. The pit fits with a little 'brute' force, and gluing the nose in sections with CA.
Peter
my god that is a nice kit i was not aware of. i will be watching this. it makes me miss my old 24th airfix harrier gr1 from my childhood. id love another.
Looking really good - though I'm not sure about the colour of the landing gear/flaps panel forward of the throttle lever. From memory it is predominantly black (well, more charcoal) with a little yellow & black in places and steel coloured switches if you have a microscope handy. The gear lever looks to be a pretty good colour though.
Kirk
Edit: (Excellent) reference here: http://data.primeportal.net/hangar/luc_colin/harrier_gr.7/Harrier_GR.7_057.jpg
Edited by Kirk
Well this is officially abandoned for the moment - I opened up the bubble wrap containing the canopies. Queue language not suitable for minors.
Not a happy bunny, especially as the nose cone is also missing....
Well i'll be contacting Trumpeter, but I don't hold out a lot of hope.
Peter
Oh dear,...that's not good (<---master of understatement!)
Sorry to see the state of your canopy Peter. I hope Trumpeter come through so you can complete this project as it's looking very good indeed.
Umm,....I have one quick question......should the tie-down rings on the nose gear leg be that way up? :hmmm::unsure::shutup:
Good luck with getting your canopy sorted.
Cheers.
Now that is a shame im sure trumpeter will come up trumps (pun intended) when they are told their customer service had a chance to shine on the britmodeller membership.
Good luck I look forward to seeing progress when it happens
Cheers Rob
