Correction needed to build a Martlet/Wildcat from Tamiya's F4F
Antoine
Well, it's been some times, years in fact, that I'm thinking about building an F4F wildcat, and as I've always had a soft spot for the FAA, the way to go has was martlet ... or wildcat ...
Don't know that much about the quality of hobbyboss kits, but I don't really mind, as I wanted to go tamiya's way.
I did read and re-read Bruce Archer's article in HS, but assessing the differences between aircraft was a bit difficult for me as first I'm not too familiar with certain word from english technical vocabulary (Cuffed???), and second I couldn't find the tamiya kit to see exactly what was there.
Things changed in the last few week, as I found at last the box I was searching for in one of my LHS in Taipei. I came back home, opened the box, and tried to understand.
So my aim is to build (not tomorrow maybe, but you never know) a martlet/wildcat from tamiya's kit, with the less possible transformation work. I don't mind to fill a few engraved panels, but I don't want to cast another cowling, you see.
So, here's so far my understanding of Bruce work compared to tamiya's F4F, and what's needed to obtain a martlet/wildcat from it.
I'll be happy to read comments and corrections about this, and also about further correction that I could have left aside, like differences in the cockpit maybe?
- What we have with Tamiya's kit
F4F-4
P&W R-1830-86 twin wasp
Cuffed curtiss electric three-blade (?) with stepped prop hub
Standard chord PW cowl (Long ?)
Three cowl flaps on each side
Carb intake on top
Two intercooler scoop inside the cowl
Folding wings
3 .50 per wings
Pitot F4F-4 style (under the wing edge)
- Then what is possible with minimum work?
Martlet I
Forget about it, need another cowl for the Cyclone
Martlet II
P&W R-1830-90 twin wasp
Cuffed curtiss electric three-blade (?) with domed prop hub
One large cowl flap on each side
No carb intake on top
No intercooler scoop inside the cowl
Folding wings
3 .50 per wings
Pitot F4F-4 style (under the wing edge), and specific angled pitot on AM964 to AM999
Corrections:
Change prop hub
Rescribe cowl flaps
Suppress carb and intercooler scoops
Change pitot if needed (See serial)
Martlet III (Ex-II)
P&W R-1830-76 twin wasp
One cowl flap on each side
Carb intake on top
Fixed wings
2 .50 per wings
Straight pitot
Corrections:
Change prop hub
Rescribe cowl flaps
Suppress engraved panel lines for folding wings system
Suppress 1 .50 in each wing (Outer?)
Change pitot
Martlet III (Ex-Greek)
Carb intake on top
Fixed wings
2 .50 per wings
Straight pitot
Corrections:
Rescribe cowl flaps
Suppress intercooler scoops
Change pitot
Wildcat IV
Forget about it, need another cowl for the Cyclone, and another prop.
Wildcat V
Four cowl flap on each side
Carb intake on top
Folding wings
4 .50 per wings
Corrections:
Rescribe cowl flaps
Edited by Antoine
Hi!
You really have two (actually three) options. The first is the Wildcat V. Remove the outer guns. Second are the AMxxx Martlet II, with the cowl mods mentioned and that unique pitot. The third are AJxxx serialed Martlet II with the F4F-4 style pitot. None of the mods are difficult.
Use the Hobby Boss kit for the Martlet III.
Bruce
Antoine, in my opinion you have distilled the Pratt and Whitney-engined Martlets very well!
One small item I would add is that some (if not all?) of the early Martlet II's with "AM" serials and angled pitots, have a long rearward extension of the fairing between the landing gear. I'm not sure anyone has yet figured out the function of this but it is fairly obvious. Some of these machines also have the serial painted rather curiously with periods after the letters! For example, "A.M.964".
"Cuffs" are extra pieces added near the root of a propeller blade, to widen its chord. Mr. Archer's article photos nicely show cuffed props on Mk II AJ148 and Mk III 3876; and an un-cuffed one on Mk IV FMx80.
Finally, I would again put this link that I just added to another post! You will find this very interesting, especially the final page of it:
http://www.geocities.jp/yoyuso/fm2/fm2.html
