Neal 112 Posted March 1, 2013 Share Posted March 1, 2013 (edited) I've finally decided what to do for the GB, as I took me nearly 5 months to complete a revell 1:144 tornado I wanted something simple that likely to get finished. As I've only decals for a single aircraft in the kits and I've not managed to track down any suitable alternative codes I'm planning a little dio; a patch of grassed airfield in 1940 one spitfire as a worn & weary aircraft cockpit open ready for the bell to ring. With the other as a clean, brand new aircraft just arrived from the factory still without its squadron codes. I've also want to have a go at some PE so there'll be a bike resting up against one of the aircraft. Edited April 22, 2013 by Neal Link to post Share on other sites
MPaul 397 Posted March 2, 2013 Share Posted March 2, 2013 Sounds good Neal. I have built a couple of the MicroWings kits and they are pretty good for the price. Look forward to seeing the end result. Link to post Share on other sites
Dazzio 839 Posted March 2, 2013 Share Posted March 2, 2013 I know the Spitfires will look good, it's that bike I am interested in!! Will be watching the (bike) build with great interest Kind Regards Dazz Link to post Share on other sites
Neal 112 Posted March 3, 2013 Author Share Posted March 3, 2013 (edited) Dazz, Agreed; there's quite a lot of light flash and I'm sure the Eduard set is more detailed but you can't fault the value for money with the revell kit. The bike scares me, the PE is exquisite, there are 6 parts to each bike but I have no idea how to paint the wheels and tyres, I don't think I'll be able to mask them as I think Tamiya tape will bend the spokes when I remove it; any help will be appreciated. Tonight has been spent tidying up the flash on the fuselage opening the cockpit door and scratch building a rough cockpit. I've not added anything to the side with the door as you'll never see it. The IP needs painting black and I'll add some tape harnesses to the seat Whilst the cockpit was drying I've started to tidy up the wings and drill out the cooler and radiator. Edited March 3, 2013 by Neal Link to post Share on other sites
Dazzio 839 Posted March 4, 2013 Share Posted March 4, 2013 (edited) I got some BrenGun pe parts for my hunter and they do look amazing. Am tempted with the crane thing they got too. The Spitfire is looking good mate, love the cockpit As for the tyres on the bike... I'm guessing maskol would bend it as you take it off, same for Tamiya tape... Pva glue?? What about blue tak?? If you leave it a while it turns hard and looses some of its tackyness (word? Spelling?), assuming you're just spraying then taking straight off. I'm guessing it could be done, cause it would stick as much thus eliminating the bending issue. Paper template?? hhmm... Kind Regards Dazz Edited March 4, 2013 by Dazzio Link to post Share on other sites
Neal 112 Posted March 6, 2013 Author Share Posted March 6, 2013 I got some BrenGun pe parts for my hunter and they do look amazing. Am tempted with the crane thing they got too. The Spitfire is looking good mate, love the cockpit As for the tyres on the bike... I'm guessing maskol would bend it as you take it off, same for Tamiya tape... Pva glue?? What about blue tak?? If you leave it a while it turns hard and looses some of its tackyness (word? Spelling?), assuming you're just spraying then taking straight off. I'm guessing it could be done, cause it would stick as much thus eliminating the bending issue. Paper template?? hhmm... Kind Regards Dazz Cheers Dazz, I've the Griffin / Brengun PE flaps set for the A-model lancaster and they look great too, and agree the crane is an interesting peice for a dio. The only thing I can think for the bike is to use tamiya tape really lightly applied. An hour this evening and the cockpit is nearly there; bit of floor structure, headrest, control column, tape belts and some ribs on the door side. It's got some Matt varnish on at the moment then I'll add some dry brushing and washes. The pics quite poor and shows up all the flaws, in reality it looks pretty good and I'm very pleased with it. Link to post Share on other sites
Dazzio 839 Posted March 6, 2013 Share Posted March 6, 2013 I got the flaps set for the Hunter, am kinda worried about using the PE tho. I've never used PE before. What about using some Tamiya tape, but sticking it down and bringing it up a few times to loose it's stickiness?? Love the work on the cockpit, bloody awesome!! Kind Regards Dazz Link to post Share on other sites
Neal 112 Posted March 11, 2013 Author Share Posted March 11, 2013 I got the flaps set for the Hunter, am kinda worried about using the PE tho. I've never used PE before. What about using some Tamiya tape, but sticking it down and bringing it up a few times to loose it's stickiness?? Love the work on the cockpit, bloody awesome!! Kind Regards Dazz Cheers Dazz, I'll give the tape idea a go. Cockpit dry brushed and given a coat of Florys dark wash. Seat attached and Fuselage closed up. Bottom half of the wings are a bit of a dogs dinner, so I've taken off the cooler to give me a better chance of cleaning it all up. The hole for the stand has been plugged with a bit of stretched sprue, I'll probably scratch a new cooler. Link to post Share on other sites
Neal 112 Posted March 12, 2013 Author Share Posted March 12, 2013 I've joined the upper and lower wings and after some careful sanding the fit is looking OK, although it'll still need a fair amount of filler at the front as there's a change in shape between the wing and fuselage. Link to post Share on other sites
Neal 112 Posted March 13, 2013 Author Share Posted March 13, 2013 All the main parts together now and the filling as sanding has started. I've drooped the elevators and enclosed the wheel wells with plasticard. Prop and UC have been deflashed, the wheel hubs have been sanded flat and dallied out a bit. Link to post Share on other sites
Neal 112 Posted March 18, 2013 Author Share Posted March 18, 2013 The wheel wells are all tidied up an painted then a round of filling, sanding and filling and the first of the paint can go on. The pictures don't do it any favours I'm afraid. I've cut the canopy and its in a bath of clear. Link to post Share on other sites
Dazzio 839 Posted March 19, 2013 Share Posted March 19, 2013 Looking good Neal Kind Regards, Dazz Link to post Share on other sites
Antony Robertson 48 Posted March 19, 2013 Share Posted March 19, 2013 Looking good. Antony Link to post Share on other sites
AnonymousDFB1 2,743 Posted March 19, 2013 Share Posted March 19, 2013 taking shape Neil Link to post Share on other sites
Neal 112 Posted March 20, 2013 Author Share Posted March 20, 2013 Looking good Neal Kind Regards, Dazz Looking good. Antony taking shape Neil All, thanks for the comments. The canopy is out of the klear and is drying. I've masked the relevant parts of the underside and the earth has gone one, this showed up loads of flaws so I recon I sanded most of it off again but looks ok after a second coat. Part of me wishes I'd started with a better kit as the finsih isnt going to be grear, but onwards and upwards. Gear all painted as well. Also made the cockpit door and added the internal detail. Link to post Share on other sites
Neal 112 Posted March 24, 2013 Author Share Posted March 24, 2013 Pretty self explainitary; olive drab on, canopy on, exhausts painted, masking removed. The canopy has a very poor shape, I've sanded it to try and make it less upright. I've also added the first coat of klear so might get the decals on during the week, so on the home straight with this one. I suspect the second spitfire might not make this GB as I want to get on with the bike. Link to post Share on other sites
Neal 112 Posted March 25, 2013 Author Share Posted March 25, 2013 (edited) Decals are on, wasn't really enjoying this build but its come alive now the decal are on. Matt coat later in the week and the weathering can start. With the decals drying I thought I'd make a start on the bike, suddenly i have a half inch long bike. This is my first go at PE and painting it with a brush its a bit rough and ready, but really pleased with it. Edited March 25, 2013 by Neal Link to post Share on other sites
AndyC 2,326 Posted March 25, 2013 Share Posted March 25, 2013 Great stuff Neal - that's amazing for 1/144. I love p/e and, yes, it's fiddly but the scale detail is awesome - that bike is ace! Link to post Share on other sites
Antony Robertson 48 Posted March 26, 2013 Share Posted March 26, 2013 The Spitfire looks great but that bike looks superb! Antony Link to post Share on other sites
AnonymousDFB1 2,743 Posted March 26, 2013 Share Posted March 26, 2013 1:144 bike, okaaaaaaayyyyyy. Nice one 1 Link to post Share on other sites
John_W 2,700 Posted March 26, 2013 Share Posted March 26, 2013 Awesome... Link to post Share on other sites
Neal 112 Posted March 26, 2013 Author Share Posted March 26, 2013 (edited) Awesome... Great stuff Neal - that's amazing for 1/144. I love p/e and, yes, it's fiddly but the scale detail is awesome - that bike is ace! The Spitfire looks great but that bike looks superb! Antony 1:144 bike, okaaaaaaayyyyyy. Nice oneAll, Thanks for the comments. I'm pretty sure most of it is down to the quality of the Brengun PE and I could probably do a better job next time, the good news is ther are 3 bikes still to go on the fret. A bit of carefull dry brushing will help a lot as well. One thing i did find was that the silver (revell aqua colour) really didn't want to go onto the PE, should I have primed first? Did wondrr about priming but I was worried that with too may coats of paint all the detail would've been lost. Next on the job list is to give the spit a Matt coat, as I'm looking for a worn appearance I'll do something I've tried previously which is to add some grey paint to the varnish to flatten back the bright decals and visually fade the paint a bit. I've been looking at some reference pics and there's always the trolley accumulator by the side if the aircraft. There isn't a 1:144 kit for this so I'm going to try to scratch build something. I haven't been able to track down any drawing but I've noticed that the trolley acc wheels appear to be pretty much the same diameter as those on a spitfire and hurricane, they're both about 28" in dia so I'll take some rough scale measurement from some pictures and see what I can do. Edited March 26, 2013 by Neal Link to post Share on other sites
Dan 282 Posted March 26, 2013 Share Posted March 26, 2013 Incredible! Link to post Share on other sites
Dazzio 839 Posted March 26, 2013 Share Posted March 26, 2013 That bike looks really cool Neal!! The spits are coming along nicely too Kind Regards Dazz Link to post Share on other sites
Neal 112 Posted March 26, 2013 Author Share Posted March 26, 2013 (edited) Incredible! Dan, thank you. That bike looks really cool Neal!! The spits are coming along nicely too Kind Regards Dazz Thanks Dazz, I was a bit unhappy with the spitfire but I think it'll turn out OK. Edited March 26, 2013 by Neal Link to post Share on other sites
