Mike Mcellaney
Pz.Kpfw.V Panther Ausf. A.Tank 424,4th Company of I./Pz.Rgt.24
Well being inspired by Peter's build of a Panther from I./Pz.Rgt.24, and after looking at the reference site he linked to I did a little digging around in the stash and found the following
Dragons Panther A
WW II Production Resin tracks
Fruimetal Tracks
Aber upgrade set for the Panther
Eureka tow cables
7.5cm L/70 metal gun barrel
Atak Zimmerit
For reference I will be using the following
The link to the excellent web site Pete Marshall provided in his build thread
The 116. Panzer-Division's Panther Battalion, the I./Pz.Rgt.24 during the battle of Normandy
Panzer Tracks No 5-2 on the Panther A
And a Japanese language pictorial book on the Panther
So with that little lot together I will be attempting to build a Panther A from the 4th company of I./Pz.Rgt.24, the tank will be number 424
I will also incorporate the items of equipment and there location on the tank that identifies it as being from Pz.Rgt. 24
1. Spare road wheels mounted conical side out, one either side of the turret towards the rear, held in place with three bolts
2. The cleaning rod tube relocated to the rear deck, above the rear grills
3. Two spare Jerry cans mounted, one each on the inner face of the rear storage bins
4. Spare track mounted on the side of the turret, these were held in place with the "U" bolts normally used on the hull sides for the spare track
This tank was lost on the 24th of August 1944 at a spot called "le Pelican"
The I./ Pz.Rgt.24 was formed 23 July 1943 after the II./ Pz.Rgt.24 was renumbered, most of its officers, were from what was left of the 24th Pz.Div, which had almost been wiped out in the fighting at Stalingrad
It did not receive its 74 Panther tanks which were a mixture of late model A and early G until after D Day when OKW HQ realized the I./Pz.Rgt.24 did not have any Panthers
These were rushed to Mailly-le-Camp where the 24th were.
After carrying out training west of Amies, on the night of 19/20 July the 1./Pz.Rgt.24 set of for the front, they arrived at their assembly point on the 29th July west of Vire
Turret rear hatch showing the ID mark for the 4th Company
Edited by Mike Mcellaney
Ok first up date
All of the wheels removed and cleaned up
The hull cleaned up, suspension arms removed , cleaned and dry fitted, also Zimmerit added to the sides
I decided to go with the metal track rather than the resin ones, less clean up on the metal ones and they went together great
very nice start.... never used metal tracks but boy do they look good.....
Nice start Mike - Should be good to watch.
How's the resin Zimmerit to work with ?
Peter
Peter
The resin Zimmerit so far is nice to work with, will let you know when the project is complete if i still think so :D
I would say the hardest part is getting it of the resin backing sheet, this is where you need to sand it, and make sure it stays in one piece
Once that is done, its just fixing it to the model with PVA glue, with a touch of super glue around the edges
Thanks Mike - that's good to know - I will watch for the deleted expletives if it starts breaking up . I've only used Milliput so far which works, but i got it a bit thicker than i'd like, mind you only the second time i'd tried it, and it was better than the first go :winkgrin:
Right got all of the Zimmerit on, just a few problems with the backing sheet separating and having to piece together the resin squares
The worst being the rear plate that's it about 15 pieces
All I have to do now is go round, sand back the resin where its overlapped fill the joints where the plates meet and make them look like the Zimmerit
Nice Zim, and that barrel looks the business
Wow Mike! looking good dude!
She already looks great without some paint on!
Well its almost there now, just a few more bits left to put on before the primer coat which should be this weekend
Great job sofar. I can't wait to see it with some paint on. O, by the way thanks for the tip about using wood glue for the ATAK resin.
Fantastic mate. :goodjob:
This will be the last update before the tank hits the paint shop
The spare wheels and track links on the turret, Jerry Cans on the rear are only just held on with white tack at the moment, these will be painted of the vehicle to give a bit of color variation.
Well Mike you have all the bits to make a real cracker of a build, not letting us down so far mate, keep it up.
Regards
Dan
