bootneck
Fairey Gannet AEW.3 - Welsh Models vacform
WOW, this is nice!
Vacform AND 1/144...........hmmm. have just finished my first 1/144, they're nice but just tooo small, either that or my fingers are too big!
Lovely job though, like the "tools" you made for sanding.
I have continued with building the tailfin flash, plus added the little bee ('B' Flight, HMS Ark Royal).
The bee is a scan from an image, resized down to 1:144 and then printed onto decal paper.
I had to source the low-viz style roundels from the Xtradecal Hawker Hunter set. Bit of a shame really as there are only two of those low-viz types in that size available on the sheet and planned to use them on a future Hunter build.
I'm now searching around for the large 047 c/n to place on the fuselage just behind the props. In this scale the digits are 4.5mm high by 3.5mm wide.
I may have some from an Anigrand kit so will check and update later.
Just checking the model and can see that there are some areas of paint demarcation overlap. I'll do some tidying up ready for the next instalment.
cheers
Mike
Hi Joseph,
I spoke to Densil of Welsh Models about the props and he recommended their ATR 42 set as they are just about right. The tips would need some slight fining down.
I bought a pair and will be attempting those next.
cheers
Mike
Thanks, Mike. I'll check that out.
Joseph
This is going right down to the wire - assuming I've still got until midnight tomorrow (28th) to finish!!
The spinners and props are done. I was going to do the props with just the yellow tips; however I found images that show this aircraft had the 'alternating' white markings whilst on HMS Ark Royal with the "Bee" flash on the tail.
The kit needed a small indentation filed, into the lower fuselage, to accept my scratchbuilt tail hook.
The kit comes with an ejection seat but these aircraft did not have them. I've scratchbuilt a seat pan and headrest.
Just waiting for the canopy and the wheels to be completed, painted and fitted. Hopefully I can get them done by tomorrow????
Canopy painted but needs cutting out and fitting. Hope it will fit first time!
This is going to be a really fiddly bit of work to cut out to fit exactly.
That's it for now. I need to get some rest, especially my eyes! :hypnotised:
Mike
That's fantastic, I had no idea vacforms could be so small - in my head I associate them with bigness :)
I think I've just scraped in at the 11th hour with this!!
Finally got the wheels on
Front check for alignment
The canopy was a real problem to fit (nothing wrong with the canopy - just me!), so I split the canopy and fitted it open.
Overhead view from behind, to show that the spinners were still yellow tipped on the rear of the props.
Same view but on a small base which I painted up today while waiting for some parts to dry
On the port forward catapult
Parked
Rear view
I have really enjoyed building this. I have a load of vacforms but have not had the courage to start one until this GB kickstarted me into it.
I've already started on a fresh build, a Buccaneer this time so that it can sit with my Gannet.
Thanks for following my build and for providing your ongoing support; it inspires one to continue when you receive encouragement along the way.
cheers and thanks
Mike
I'm now going back to having half finished models all over the place!!
Excellent! Just adding a drop of dark grey/black to accentuate the moveable parts would have enhanced the effect!
Thanks, I've now got a bottle of dark wash and may just give your suggestion a try.
cheers
Mike
Just started cutting out my Welsh Models Gannet when I came across your build - fabulous job! Hope I can come somewhere near it.
Sorry about the threadomancy but I've just started a few vacform kits and this little thread has been an excellent tutorial for me. In no particular order hey are a Rareplanes Curtiss SBC4 Helldiver, an Airmodel Sukhoi SU 7 (both 1/72) and a little Hawker hunter in 144, a Welsh Models kits.
Your Gannet is lovely!
Viv
