Fairey Gannet AEW.3 - Welsh Models vacform
This should be my third, and final, entry for the group build.
Being a glutton for punishment I have decided to attempt a vacform kit and will attempt to build the Fairey Gannet AEW Mk.3 by Welsh Models.
Mike
Parts identified, separated and numbered ready for preparation and assembly.
Nice little touch, Welsh Models has included a seated pilot in white metal. I don't know of any other kit producer who includes a separate seated pilot in 1:144.
Mike
Just spent most of yesterday's spare time cutting out, assembling, filling and filing the AEW radome for this. It goes together very well, with minimal filling, and I'm very pleased with the result.
I'll post some images when the new server is fully operational.
cheers
Mike
I've made a start on the fuselage. The kit comes with some decent looking domed observation windows so I started to drill out the existing window positions.
Once I cleaned out the window openings, I cut out the vacformed domed windows and glued them in position.
On the real thing, this part of the cabin area is very dark so I painted over the back of the clear parts with Tamiya X-19 Smoke. It seems to have a better effect than just black.
I then did a dry fit test of the fuselage halves, just to make sure they aligned OK and that together they were the correct width. This is where a decent set of calipers, and a schematic to scale, are useful. The kit comes with a handy template, for aligning the wings correctly and I found it useful just for holding the model during the build.
Here is another view of the wing template; I've added a couple of odd plastic scraps to keep it in vertical.
And here is the template with the fuselage nicely positioned on it. Note the nice sheen on the back of the domed window.
I've now started on the AEW radome. The shape is quite complex and therefore this element comes in two parts. The parts are really smooth and difficult to handle, especially when sanding. To overcome this I made a little gripping handle and drilled two holes in the radome upper piece then, inserting the gripper into the radome, I was able to sand the part quite well.
This is my first full vacform kit build and I'm learning as I go along which is quite fun and frustrating at the same time!!
The underside of the radome is very smooth and there is no where to drill holes, for the gripper, without ruining the profile. So I just got on with this until the residue fell away
Finally I glued the radome together and, after some light sanding, it appears to look just right.
That's it for now. Will do some more tomorrow
Thanks for looking
Mike
Hi James,
This my first proper vacform build but I have dozens of WM kits; I just needed the courage to start one!
I'm learning so much from this that it shouldn't be long before I start another; probably the Beverley or the Argosy.
I'll post a few more images of progress tonight.
cheers
Mike
Most of today's work has been preparing the main wings and tailplane. Quite a lot of wet 'n dry work, interspersed with measuring/checking, and then more sanding.
Finally feel that the wings look correct and have glued them together. Once they had dried, I gave them a light sanding to remove any glue residue etc., and then attached them to the fuselage.
I used the template provided with the kit to check the wing alignment and they looked fine (to me!)
The tailplane pieces were next to be prepared, glued and then attached to the fuselage.
This is as far as I've been able to manage today. It sits on the template OK and I'll probably continue using the template as a rig to hold the model in place while I build up around it.
Last thing I did today was to apply some filler and then to sand it smooth once it had dried. It is now ready for the next stage which will probably be the tailfin assembly.
025_wings_filled_and_sanded_to_blend_wit
More tomorrow, thanks for looking
Mike
Great work, it's only when you see it in your hand you realise how minute it actually is.
Did you add any tabs to the joints or just butt them together?
Edited by Neal
Hi Neal,
there are tabs on each wing, you can just see one in the image above where I am sanding the wing. I just had to measure a similar position on the fuselage and drill out a slot to take it.
cheers
Mike
I'm not a 1/144th person but I'm really enjoying this. Tempted to get something like this from Welsh Models. Nice work mate :)
Gtreat there Mike, looks like the assembly jig was a great help in getting everything aligned. Good idea.
Colin
Someone asked me how I keep hold of the tiny flat parts, whilst sanding them. I find the easiest way is to attached double sided tape to the upper part and then stick it to my finger!
The tailfin has been assembled and fitted to the fuselage along with the radome. The front of the model is just flat with no detail however, on checking some images, I found that this area has very large intakes. I have scribed out a semblance of this, ready for the props to be added.
Front of Gannet showing intakes
There is a small gap along the join-line, where the radome is attached to the fuselage, and I have used Plastic Putty to fill this gap. I find Plastic Putty very useful, mainly because it has a fine spout for getting into small areas; and also that it is water soluble. This means that, once the filler has been applied, I can run a wet finger over the filler to smooth it to shape.
029_using_av_plastic_putty_to_fill_joins
Not a brilliant photo but it does show the smooth finish of the Plastic Putty. This is before any sanding has taken place to get it really smooth and blended in.
That's it for now, I hope to be able to get more done this weekend.
Mike
  • 1 month later...
I've just checked the calendar and realised I need to get on with this! I've been distracted by my SS-25 Sickle transporter build.
The fuselage has had a light dusting of Humbrol Beige Green, over Tamiya white primer. The upper sides of the wings and tailplanes have been sprayed with Humbrol Ocean Grey - I found that EDSG was too dark at this small scale so I used a slightly lighter grey.
I plan to represent an aircraft of 849 'B' Flight attached to HMS Ark Royal during her seventh commission 1974-76. These aircraft had a nice flashy black/yellow tail; this means quite a bit of masking to get these colours on. Instead of masking the whole model, I stuck it in a bag and sealed it up with just the tail exposed. The model was then subjected to various sprays of Tamiya white, followed after selective masking by Tamiya yellow; and finally a spray of Halfords satin black.
Removing the tape shows the flashes appear to coming out OK
Well that seems to have come out OK. I need to make a small white circle with a little bee in it and then place that in the centre of the flash.
Sorry about the odd colour of the photo's; the grey of the wings is really quite dark - taking the pictures in the evening gets all my settings wrong.
The next stage is to populate the cockpit with a seat and head pad etc., and then I'll get to work on the dreaded contra-rotating props and spinner!
cheers
Mike
Going nicely I see. I think this'll be a little beauty. I've got the main airframe components together on mine and I was pleased at how the radome fit. I've attached the prop spinner and I was thinking of using the blades of the Aeroclub props designed for the Welsh Models Varsity. I've made a rod for my own back there as I now have to drill the spinner in such a way that the blades are evenly spaced and at right angles to the next. I'll be very interested to see how you handle its detail painting and markings.
Best of luck,
Joseph
Edited by JosephLalor
Hi Joseph,
I spoke to Densil of Welsh Models about the props and he recommended their ATR 42 set as they are just about right. The tips would need some slight fining down.
I bought a pair and will be attempting those next.
cheers
Mike
