SA330 Puma
perdu
I did promise I'd post this but she's not so great
Lessons learnt during this one though so may be worth a discuss
First one... filing octagonal sides on a round tube is NOT easy :(
Anyway, the kit was bought at the club Christmas meeting as a charity build competition
It was wrapped in Chrissy paper and you have to make a lucky dip selection. The entry fee goes to the Children's Hospice as do any fines levied if you don't bring it back in February.
B U I L T !
As my favourite flying thingies are whirlywinged this was a serendipitous pick, oiut came a box of Airfixy bits labelled SA330 Puma.
I didnt begin modelling til the friday week before the club meet, naughty and the reason for my displeasure, I should have given it the decency of a few weeks of research and build time.
Step in Keefr with some gloriously detailed photos which saved my bacon, thanks Keith, next one will do your pics fuller justice, anyway
on with the motley
dede5745-a5c8-498a-be38-83f7b2584695_zps
7ee66720-2a74-49f2-b03d-8db9a78576fe_zps
531462dd-c63c-4a83-885b-8ed4d0ea1a3d_zps
9ef7b0e0-738a-43ab-a2d3-135dcc94ddd9_zps
d5d75a92-4807-447f-83a6-65c0f47f2a8d_zps
23736db8-1022-44af-be49-3559f9dd5602_zps
I know how bad the windows look, the whole damned thing filled up with dust after it was stuck down :(
I was in a bit of a panic about moving the model from one side of Metropolis to t'other in a box without its blooming flimsy undercart collapsing under it
So I had a bit of a think and came up with this, fit into a box in a cardboard template with a Puma sized cut out so the legs wouldn't move. The problem came about because after Keith gave me the photos of the aerial array on the nose I made it up and it became just a tad dangerous to have it flopping about
Here's how she looks in the cut out area
5bff602b-c693-4c70-a41c-276c391935a2_zps
And this is the cut out without a visitorf7580fc0-b907-4110-b734-9881dd49dd4e_zps
I didnt get any decent pictures of the filters, mostly because i didnt do a very good job on them IMO
I flattened a couple of drop tanks from my bombs box in an octagonal section then I used Humbrol Schwartztgrun painted Solar trim to represent the darker filtration holed areas, stuck them in place and used Squadron putty to fill around it. I also used Solartrim on the windscreen framing and the panelling around the intake filters
Home brewed transfers made with microsoft Word and reduced to fit and RAF door panel letters were lifted off a file on the net and reduced to the desired size as a picture image in Word again. Thank the lord Word allows you to set exactly the image size you need, I just get it close on screen the print a test shot so I can measure how much bigger or littler it needs to be
The starboatd decals will be removed now the meeting is over and re done with Klear and Tamiya Matt varnish rattle cans
The paint used was Tamiya XF58 Olive Green, brushed quite deliberately to give the faded look so often seen on RAF helos. I like it now, didn't before I started
I now understand that there is a RAF version which has the filters already, I will do a better version of that one later.
hack it apart please, that way I can use your ideas in future
Bill
Edited by perdu
